Question about Husqvarna Viking 1
Viking#1+ Embroidery Card into programmable card
Embroidery machine Viking #1+, have couple od pre-programmed cards that are corrupted. how do i convert them into programmable??
thank you, maria
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 87 Answers
You cannot convert a #'d embrodiery card collection to areadable/writeable card. If it has like #2 or #3 etc. on it, it's a read only card.
Posted on Mar 19, 2009
Problem with Viking Scandinavia 400 embroidery machine
it's possible that part of the computer is mal-functioning or going out
having the machine checked would tell what it is for sure
Mar 20, 2012 | Husqvarna Viking 1
Hello, I am hoping you can help me with this. I have recently installed 3D Professional (ver.7.2.51.1) running with Vista. Everything runs, with no apparent issues at this time. I had to get a parallel...
I dont believe the parallel reader writer will work with Vista. You need to purchase a Husqvarna USB reader writer and problem will be solved.
Good Luck
Oct 17, 2010 | Husqvarna Viking 1
Where do I GET the blank disk for this machine
Does the machine use an ATA PC card, or a memory card and card reader.
ATA PC cards are sold with electronics and computer supplies.
The memory card has to be compatible with both the card reader and the format of the embroidery machine. These are sold at places such as Allbrands online or at the Viking dealer.
May 08, 2010 | Husqvarna Viking 1
Husqvarna Embroidery card reader/writer
Hi - I think you have a Viking Designer 1, which has a slot for a floppy disk on the side of the machine. If so, you need to purchase embroidery software that supports file type .sv1, and you will need to buy floppy disks.
You can buy embroidery software from Viking that will allow you to write design files onto floppy disks, but you can find other embroidery software packages that support the D1 which cost quite a bit less - make sure that file type .sv1 is supported before you buy.
Viking does sell designs that come on a D1 floppy disk. You can just pop the floppy into the machine, select you design, and go. You can find Viking designs online from time to time, but before you buy, ask if a floppy is included - the newer Viking design packages come with a DVD but might not include the floppy for the D1.
Hope this helps, Ginny
If you have a Viking #1+, you won't be able to use floppy disks with your machine. Please repost and I'll tell you what to look for.
Jan 30, 2009 | Sewing Machines
I am trying to embroider something for the first time on my viking #1 husqvarna. Do I need presser foot Q/ or R/ .If it's R,I can't find it-what does it look like? I need someone to walk me thru the steps...
embroider on #1+:
If it's a #1+ I recommend the Q (the spring works better) it's hard to put on, but worth it.
Here we go:
1>Turn off machine (always when installing or removing embroidery unit)
2>Install Q Foot. Always leave presser foot pressure (on left end of machine) at 6 for presser foot Q
3>Insert Embroidery Card
4>Insert Embroidery cassette (matching #’s with card)
5>turn on machine
6>Turn on embroidery unit (on cassette)
7>Select design
7>Thread for color 1
8>press reverse to start the machine embroidering....weeeeeeeee!
Jan 18, 2009 | Husqvarna Viking 1
#1 Viking Embroidery #13 Set.
Use any card that has the On/Off in the bottom right og the card (1). You have to know what number is you design so you can push that number after selecting on/off. Make sure you programmed emb card is in the machine. You can use another card if you do not have the generic numbered card with on/off and the hoop positioning E on the right side of the numbers 1 to 35 designs.
Sew Technologist
Apr 16, 2008 | Husqvarna Viking 1
Turn machine off, install embroidery unit, card and button pad. Turn on the machine, press the "on" button on the keypad to turn on the embroidery unit. Select the design that you want to stitch using the keypad, thread the colors in order from the list in the book, change colors when the machine stops and prompts for the next color.
Mar 27, 2008 | Husqvarna Viking 1
Husqvarna 1+ programmable card
To the second poster with the malfunctioning "card" - do you mean the insert panel/card (overlay) with "E" on it? If so then there is no programmable feature to it. The overlay has notches in the left edge that presses a pattern of leaf switches on the left behind the case and it uses internal designs in memory. If on the other hand you mean that little memory card that you can use with the reader/writer and goes with the "0" (zero) card/overlay then you can get them from a Husq-Viking dealer, or keep an eye on used ones on ebay.
Most dealers sell the "programmable" as a "0" (zero) card set where you get the zero cassette/panel/overlay and the little programmable embroidery card as a set. Most reader-writer sets, either the older parallel port type or the newer 3D/4D USB one will come with one many times. You need to check the dealers and see what they have to offer. The programmable embroidery card is still rather pricey. I'm looking into whether there is some generic type memory card that might work too but have yet to find one and may not since the HV programmable card is likely proprietary since it goes back to the early 90's.
Mar 13, 2008 | Husqvarna Viking 1
Finding affordable Box and Card that will work with Viking 1+
You will need a keypad card that goes along with one of the original Husqvarna embroidery cards. This keypad gives you the controls for using the embroidery unit and selecting your designs.
Jan 29, 2008 | Husqvarna Viking 1
Sewing Machines Logo
453 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
