Question about Samsung DVD-VR357
Fan runs all the time and is loud
When I turn on the DVD player the fan starts running and is loud and doesn't stop running
Purchase a new fan and install it, they wear out.
Posted on Mar 17, 2009
2007 VW Jetta, A/C fan under the hood running non stop
hav air system checked--compressor cud be failn or fan motor bearings wearing out--make sure u hav enuf freon in the unit
Jul 02, 2013 | Cars & Trucks
Laptop making loud fan noise like its overheating,
Go buy a can of compressed air and blow out the fans and vents. That should get it running quiet again.
Jun 08, 2012 | Acer Aspire 5336-2524 Intel Celeron 900...
Cooling fan continues to run after engine shut off.
The fan runs for a short time, after ignition off, to continue to cool the hot engine.
Dec 10, 2017 | 2005 Dodge Stratus
When the receiver powers up just the fan seems to go on. Resetting by holding the i/o will turn the yellow light off but doesn't turn the fan off and comes back on after you release the i/o...
Hello Joe, my name is Becki, with DISH Network. You will want to make sure that the receiver is in a well ventilated area, and that there is nothing heavy sitting directly on it. The receiver's fan can start running constatntly if the unit starts to overheat. You may also want to try putting the receiver out on the floor for a few hours to cool down. You can also try to unplug the receiver from the power source for 10 seconds, that can be a more thourough reset than holding the power button down. The fan will run while starting the receiver up, for about 5 minutes, then it should stop running loudly. If you continue to have problems, please let me know!
Becki Barned
DISH Network Customer Service
becki.barned@dishnetwork.com
Jul 13, 2011 | DISH Network ViP 612
Does the fan in the DVD video recorder/ video cassette recorder\r\nD-VR7KC2 always run even when the machine is turned off?
No, the fan is not meant to run all the time, and not with the unit in standby. The fan in many DVD recorders is usually only meant to be active whenever a disc is loaded and is either recorded or played back - the fan is designed to circulate the airflow for the DVD drive and its associated digital controller circuit. If the fan is still running even after you ejected all discs/tapes, and turned the unit off at the front, then it will require a service technician's attention in a fully equipped workshop. If the fan does not run when the unit is in standby, then you have no fault; it is a normal condition.
Apr 04, 2011 | Toshiba Televison & Video
Desktop computer fan runs constantly
Desktop fans do run constantly, you cannot avoid this.
The reason they get loud is because there will be a build up of dust on the fan blades.
To rectify this problem turn off the computer and remove the power cord from the rear. Then you need to remove the side panel from the base unit to expose the motherboard.
You will see that inside the case it is full of dust. Look at the CPU fan (the fan on the motherboard) also take notice of any case fans too, they are at the back.
To clean the fans and the case you can use a clean dry paintbrush or compressed air.
Once the inside of the case is cleaned you will see a noticeable drop in noise.
Regards.
Jul 03, 2010 | HP Compaq Presario SR2150NX PC Desktop
Why is my system running so loud?
The 2 most common causes of noise are the DVD drive and the fans.
If it does it continuously, check the fans. Make sure you are giving it adequate ventilation (atleast 12 inches in the back and 3-4 on the sides minimum) because if the fans are running that loud it's an indication that your 360 is running hotter than it should. If it only starts happening when you insert a game/dvd disk it could be the DVD drives motor running harder. This is a more complex issue to tackle and not recommended for the unexperienced. The only simple trick I can think of at the moment with the DVD drive is to change the consoles position, if it's vertical, lay it down and vice versa. Hope this helps or atleast narrows it down for you.
Dec 27, 2009 | Microsoft Xbox 360 Console
Sony vgn-s460: screen blinks, fan runs very loud
Possible clock timing of CPU is wrong. Is it two fan on this laptop? Maybe one is not functioning. Plus check your power supply if gives correct power!.. If none of this , it comes to the MB and possible a CAPS making problem. Need expert.
JMC
Aug 06, 2009 | Sony VAIO VGN-S460 Notebook
Fridge motor is loud when doors closed stops when open-3.5 yrs old- first time same problem fixed with replacing sensor 2/08 now sensor broken again???
the fan goes off when door opened and when closes it will turn back on is normal operation of fan and door control --as to noise --fan may be failing ---iced over ----if seal failing will cause unit to run more and allows more moisture into evap which can cause more ice over
Apr 25, 2017 | LG LRFD22850 Bottom Freezer Refrigerator...
Really Loud Fan Noise
They have a bad issue with that. The fans fail all the time inm those clarions... I can sell you a used fan for $40 or if youd like me to repair your unit you could send it to me and i will repair it for a total of $200. ampman out!
Dec 13, 2006 | Clarion VRX755VD Car DVD Player
Samsung DVD-VR357 Logo
148 people viewed this question
Jerry Greenberg
Jerry Greenberg
