I have some wires that came off on the outside unit and I can't figure out what goes where???
  • Perry Putnam
    Perry Putnam May 11, 2010
    What's the brand and model number for the unit and is it a heat pump or straight a/c?
  • 400 Answers
You have not said what model this is for. But as a rule, you have indoor to outdoor wiring, if you open the indoor unit they are labelled 1,2,3,4,5. The indoor wiring must correspond to the outdoor unit. So whatever is wired to 1 indoor must be same on outdoor.
Posted on Mar 10, 2009
I have a commax intercom (dp - 2hp model). There are two wires connected from the bell outside to the connectors 1 & 2 on the unit inside and the bell is working. There are another two wires connected to...
you just said where everything goes, so what's the question?
connector 5 goes to your gat actuator, 6 is power for the unit, obviously there will be 2 wires for each for a complete circuit.
Oct 04, 2013 | Radio Communications
In middle of concert epiphone stopped, took it apart where plug goes in wire came off , but can't figure out where to solder it back, it is one wire with outside ground?
If it is a coax with a wire in the center and a shield outside, the wire will attach to the contact that touches the tip of your plug you insert. The shield will attaach to the part that touches the sleeve of you plug. inspect the jack carefully as they can be foolers. When stripping the insulation back un-braid the shield a little to be able to solder it to the jack. Use a pair of needlenose and a helper to keep soldering heat from going up the braid and melting the insulation of the internal wire. Test unit before putting cover on.
Apr 25, 2011 | Epiphone Les Paul 100 Electric Guitar
I have a blue wire that doesn't appear to do anything.
If the wire goes from the thermostat to the heat pump outside and has no connections in the air handler, then it is most likely 1 of 2 wires.
The first would be the reversing valve wire. This wire energizes the reversing valve at the appropriate time....either during a call for heat or cool.
The other would be an outdoor thermostat. Some much older thermostats and units had a "T" terminal that hooked to an outdoor thermistor. If that is the case, you can simply remove this wire from the set-up. The days of using an outdoor thermostat to control efficiency are long behind us.
Jan 09, 2010 | Heating & Cooling
Trying to figure out thermostat wiring diagham on a split system
Typical Thermostat Wiring for 4 or 5 wire Heat/Cool Thermostat (not heat pumps)
4 Wire Termostat
R = Red One Side of 24 volt Transformer
G = Green Blower
Y = Yellow Cool
W = White Heat
5 Wire Thermostat
with one transformer for both units
Rc One Side of 24 volt Transformer
Rh Jumper Rc to Rh
G = Green Blower
Y = Yellow Cool
W = White Heat
5 Wire Thermostat
With 2 transformers one for indoor unit
And one for outdoor unit
Rc = Red One Side of (outside) 24 volt (outside transformer)
G = Green Blower (outside transformer)
Y = Yellow Cool (outside transformer)
Rh = Blue One side of (inside) 24 volt (inside transformer)
W = White Heat (inside transformer)
COOLING ONLY Thermostat
G = Green Blower
Y = Yellow Cool
HEATING ONLY
R or Rh One Side of 24 volt Transformer
W = White Heat
Jan 05, 2010 | Heating & Cooling
I need wiring manual for goodman mini split.
outside unit L1 and L2 are load (input 240vac)
then you have control voltage, usually yellow and blue (24vac) this connects to some 18/2 thermostat wire which goes inside as white and red.
note: this unit may only need 24v control which is 2 wires from the inside unit and also 3 wires 2 hot 1 ground for line voltage.
STANDARD WIRING
on the inside unit you have green, white, blue and red control wires.
on your thermostat you have white, red, yellow and green
you run the wire from the outside unit to the inside unit. then run a 18/4 wire to the thermostat if wired and join the following wires.
inside unit thermostat outside unit
green------------------------green
white-------------------------white
red----------------------------red
blue-------------------------------------------------------blue
yellow--------------------yellow
Oct 08, 2009 | Heating & Cooling
CONNECT AC TO AIR HANDLER
Wire tstat normaly> Take the Y off the tstat and it goes to the outside unit. The other wire from the outside init goes to the common off the transformer. This is marked with blue,brown or black. Russ
Jul 23, 2009 | Goodman Heating & Cooling
Need to connect 3 wires from pole to 2 wires in unit
It sounds like a 120 volt line coming in from the pole. Red is the hot wire, white the common or neutral wire, and the green ground. Hook the red and white to the two main wire lugs in the unit and the green goes to the frame or ground lug that will tie to the frame.
Jul 12, 2009 | Heating & Cooling
Trying to figure where all the wires connect on a/c contacter?
The two wires coming from your inside unit. They are the low voltage wires go on either side of the contactor coil. You should not have two blues on one side. see if the black wire comes from inside unit. Rus
Jun 25, 2009 | Coleman Heating & Cooling
My carrier air con unit is a problem
There is a low voltage wiring problem. Make sure your t-stat wire is in the correct positions and that you have not removed the jumper wire at the t-stat. There should only be 2 control wires leaving the airhandler and going to the condenser unit outside. Unless it is a heatpump. One wire goes to common and the other goes to the Y terminal. W terminal is for heat. The unit will cut off if you have the unit calling for heat and cool at the same time.
Jan 05, 2009 | Carrier 38CKC042 Air Conditioner
Heating & Cooling Logo
90 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
