Question about SuperMicro SLI BRIDGE AOC-SLIB - FOR NVIDIA SLI VGA CARD Graphic Card
Computer and speakers are not interacting. The power is OK, connection to computer is Ok and I can not her sound.
  • Thomas F. Schneider May 11, 2010
    New problen? Just started out of the blue,or started after somethng changed? If so , what changed?   PS sound is not on the Video card?
  • 50 Answers
Verify that the audio card is in the Device Manager list and has NO conflicts. If it is in the list with NO conflicts, verify that the cord from the speakers is in the correct output on the audio card (typically GREEN output). If you DO NOT see the audio card in the Device Manager list or it has some type of symbol ( ? or ! ) next to it, try restarting the PC and enter the SETUP menu (or BIOS). Go to integrated peripherals and check to see if the on-board audio is enabled/disabled (if you have a motherboard with on-board audio, and no other audio expansion cards in the system, this option should be enabled, and just the opposite if there is an expansion audio card). Save and exit, let system boot up. You should now be able to see the device in the Device Manager. Next open SOUNDS AND AUDIO DEVICES in the CONTROL PANEL, and verify that there is a bound sound device to the system. Reinstall drivers and restart (if you bought this PC from a manufacturer, there should be a disc with these drivers on it) . If none of this works, you may need a new audio card.
Posted on Mar 11, 2009
Woofer stopped working
If power problem then change power socket. If power come then may be sound plug problem so you check it. If power ok, then not correct connect to PC. So you check it which point you are connect to woofer. If externally ok then open PC and check your sound driver proper work or not go to control panel- click sound and audio and check it your software working or not. And one time full computer scan and clean virus. If not solved go to computer technician and take support.
Oct 26, 2013 | Altec Lansing Acs340 Computer Speakers
Hi! I have a problem with desktop speakers, buzzing sound without reproduction from sound card...other speakers work properly, so obviosly it is a problem with the speakers..the power suply is ok, diode is...
Are this powered speakers connect to the same mains power socket as the computer.
If not you may be getting an earth loop which causes a humming sound.
Connect these speakers to the same power outlet, if you have not sufficient outlets use a power board.
Apr 26, 2011 | Teac PowerMax 160 Desktop Speakers,...
There is no sound. I have connected it to my new Toshiba laptop
Hello there,
When you plugged it into your laptop, turned it on and increase the volume, do you hear only a humming sound from the speakers? Try to plug the speaker to an mp3 player as well to test if it still doesnt give out any sound. If it still doesnt, then your speaker must have a wiring connection problem inside that needs resoldering. Here I supposed that your laptop's internal speakers is working and is able to work with other audio devices like a headset or an earphone.
Dec 20, 2010 | Insignia 2.0 Speaker System (2-Piece)
My computer ask that we install the sonic driver, how do I do it.
kindly get an headphone attached with a microphone so you can interact with your system and better still enjoy your lectures . but if the problem is that the system does not have a sound device in the system then you have to download the sound from the internet. ok
rate this solution..
May 07, 2010 | Sonic EV SonicXS Computer Speakers
My harman kardon soundsticks base light flickers, no sound
Ok this needs careful observation to determine this type of problem
Please unplug these speakers and plug it into an mp3 player and write back to me if the speakers work ok? I'll tell you more from there
Mar 15, 2010 | Harman Kardon SoundSticks II Computer...
Green light on speakers and sub. No sound - only hissing noise
open volume control & remove check from mute button.
start-program-acessories-entertainment-volume control.
Sep 17, 2009 | Audio Players & Recorders
How to connect the speakers to my pc
here's the step to connect to yur PC my dear,, just read it 1 The hardwareUnpack the speakers and the cables (included with the speakers) out of the suitcase.
2 I use the speakers with a video 1. Plug the power supply in the speakers.
3. Connect the main speaker with the video.
3 I use the speakers with a computer 1. Plug the power supply in the speakers.
2. Connect the speakers to each other.
3. Connect the main speaker with the computer.
4. Press the 'ON/OFF' button.
4 The softwareIf you use a laptop make sure your volume settings are OK.
Go to Start > Control Panel > Sounds and Audio Devices.
Dec 06, 2008 | Acer 90.00012.30B Computer Speakers
Logitech z2300.
Make sure you you have turned on both of the power buttons the one on the remote should be pushed down and there is also one on the back of the subwoofer just above the power cord connection. Hope that helps if not just let me know
Nov 28, 2008 | Logitech Z-2300 2.1 Computer Speaker...
ok if im getting what your saying
the port of the computer for line in is not recognizing the sound of your sterio
ok there should be extra jack on speaker wire that should goto line in on computer
computers dont find these jacks cause there already predetermind when the cards drivers was installed
hook the jack to line out speaker out port if the speakers are powered find the power on them turn up
then goto your sound setup get to your volume controls and find the volume controls that are muted and or turned down even in advanced settings
if you recently changed your sound card you also want to be in the sounds setup and make sure that the propper software driver is connected and not the old one still in its place sometimes new drivers dont set the old drivers aside but it adds to the sound setup list
you will find the sound setup in control panel
also there is that slight chance you will have to reinstall software again
hope this has some help for you seeing i have no way of actually seeing the speakers in person and how they work
May 17, 2008 | Altec Lansing VS2121 Computer Speakers
About computer speakers
1 st check u r speakers ..........are they o k or not..
i think ur speakers r shot or not working......
to check u r speakers u can use any other audio source like a walkman,other computer. etc....
if u find that ur speakers are ok them u should check u r volume controle on ur computer u r volume is mute...
if u problem still reman then follow these steps..
1.check u r all cable connection ....they should be properly attached
2.go to u r computrs controie panal.. sound & audio device..
4.check  u r all audio driver r working properly or not....
5.if volume is mute...get off the mute..
i m 100% sure u r problem will be solved man..
dont forget to tell me u r problem solved or not
best regards & best of luck..
Oct 25, 2007 | Audio Players & Recorders
Computers & Internet Logo
83 people viewed this question
Top SuperMicro Computers & Internet Experts
Are you a SuperMicro Computer and Internet Expert? Answer questions, earn points and help others
