Question about Dell Dimension 5100C (D51CL1) PC Desktop
Any 1 can help me connect my 2nd IDE dirve?
I have dimension 5100, it has sata hard drives and room for another 1, my hard drive of choice with all my music is IDE, and i have put it under the cd drive and above the floppy disc drive! and connected it but it doesnt pick it up in BIOS or on the computer any 1 kno how i can resolve this !! please help
  • 2 more comments
  • yeboi Mar 09, 2009
    i did....
  • yeboi Mar 10, 2009
    mate no offence but its not a mp3 player its a HHD? and no it doesnt come up in disc management or in my computer
  • yeboi Mar 25, 2009
    ye i fixed it now sorry. i set the hard drive to master and the dvd drive to slave that was the only problem! dunno why i didnt think of it! i thought the dvd should of been the master and the HDD the slave thanks n e way for ur help.
  • eagle338
    eagle338 May 11, 2010
    Change the jumper setting on your second hard drive to slave or cable selectmode. I think both of your hard drives are set to master
  • 4,889 Answers
Glad to hear it!
Posted on Mar 26, 2009
    Master:
  • 404 Answers
Did you plug power aswell as the ide cable?
Posted on Mar 09, 2009
  • 2 more comments
  • lotfi bouakaz
    lotfi bouakaz Mar 09, 2009
    drive its already connected.
    click on start, right click on my computer and go to manage
    in the table select, "storage" then "disk management"
    in that table find the drive that relates to your mp3 player
    if its not there "buy a new mp3 this is faulty" if its there
    then right click on it and select "new partition"
    you just next next everything and then format it and after
    a while it shows "healthy2
    unplug it, plug it back on and that's it your drive is fully working
    now move what ever you want to it just like before.
  • lotfi bouakaz
    lotfi bouakaz Mar 10, 2009
    if it doesnt come up in disk managment. you havent connected it well or its faulty
  • lotfi bouakaz
    lotfi bouakaz Mar 11, 2009
    idiot you are
  • lotfi bouakaz
    lotfi bouakaz Mar 26, 2009
    i dont know who wrote the word "idiot you are" it was realy not me I think its someone who used my pc . sorry dude but i apologise it wasn't me
I dont have a hard drive, can i use any hard drive
I looked up the specs on that device. See below. The specs call for IDE. You will only be able to use an IDE harddrive drive. You can pick IDE drives up pretty cheap from TigerDirect, Amazon, NewEgg or most local tech computer/tech stores.
http://support.dell.com/support/edocs/systems/dim2400/en/sm_en/specs.htm
Oct 21, 2012 | Dell Dimension 2400 PC Desktop
What is the maximum drive size I can install on my SATA controller?
Looks like at least 400Gb see below.
Product Details for 5100 400Gb Desktop SATA Hard Drive This SATA Hard Drive is used and has been tested for proper functionality.
Dell Dimension 5100 400Gb Desktop SATA Hard Drive.
Hope that helps.
Feb 25, 2011 | Dell Dimension 5100 (D51L1) PC Desktop
How do you connect the cables or jumpers?
the leads from your ((motherboard to your hard drive)) they might have a 40 pin on the hard drive or a sata they just push on to make a connection make sure they have a secure connection
The BIOS is AMI. Under ADVANCED SETUP:
The options listed for 1st,2nd ,3rd Boot device include:
IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ?
? single or master :::::
master with slave ::'::
???????????????? slave? :::':
note the plastic jumper is ' located at the rear of the hard drive next to the IDE/SATA lead/s
hope this helps
?don't forget to vote
Feb 08, 2011 | Western Digital Caviar SE WD3200JS...
1st, my desktop (dell Dimension 5100) had been not used for several months. When turned on, the green error code lights 3, 4 and a flashing battery appeared, along with a beeping noise. I read up on the...
I assume your new computer has IDE controller on the motherboard.
Yes you can install your old hard drive into your new computer as a Slave hard drive.
If the old hard drive is installed on the 2nd IDE controller and it is the only device on the controller then the jumper and be master or slave, but connect the hard drive at the last connector on the IDE cable.
Oct 18, 2010 | Dell Dimension 5100 (D51L1) PC Desktop
Is this hard drive sata or ide
It is SATA - Serial ATA (DELL Dimension 4700)
Jan 17, 2009 | Dell Dimension 4700 PC Desktop
Dell dimension 3000 hard dirve what type do i need to install a sata pata or ide
Hi
Dell Dimension 3000 accepts IDE hard drive. Any modern IDE drive should be fine
Check out Dell Dimension 3000 Service Manual for spec and how to remove and install parts.
Mike
Aug 21, 2008 | Dell Dimension 3000® Pentium® 4...
Slave drive into Dell Dimension 5100
Yes it does. It may not have an IDE cable if using SATA hard drive, but it does have a port on the motherboard to plug in the cable you take from your 4600.
Don't forget to rate your answers please!
Jun 07, 2008 | Dell Dimension 4600 PC Desktop
Hard drive
According to http://reviews.zdnet.co.uk/hardware/desktops/0,1000000973,10004197,00.htm this tower has Serial ATA, or SATA. Just to confirm, you can easily pop open the case and take a look at the hard-drives. If you see a wide thin ribbon-like cable connecting to your hard-drive then you need an Ultra ATA (or just ATA or IDE) drive. It looks like this:
If a thinner red cable connects to your drive, then that is SATA. It looks like this:
May 13, 2008 | Dell Dimension 8300 PC Desktop
Trying to put a hard drive into a working computer
I am assuming you mean a Dimension 5100 (desktop) and not an Inspiron 55100 (laptop). The Dimension uses SATA drives and as such your second, working system will need an SATA port to connect to. You should take the data cable from the non-working system with the drive since, if there is an extra SATA port on your working system, it will more than likely not have a cable attached to it. Each SATA port only supports the connection of a single drive. There may not be an additional SATA port on the working machine, in which case you're SOL (unless it uses the same HAL as the other, but that's another story).
Feb 23, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Dell Dimension 5100C (D51CL1) PC Desktop Logo
129 people viewed this question
Alun Cox
