Question about Lenovo X61S GL L7500 1GB/80 12.1 BT F VBE PC Notebook
Will not transfer vision to projector
From some reason, it wouldn't transfer vision to a projector and sometime crash when i attempt to do it.
  • 50 Answers
Its a software problem. Just format your machine and reinstall operating system and drivers.After you can try it.
Posted on Mar 12, 2009
LC-x50 has double vision or shadowing. What can cause this?
several reasons : 1.check cables, if too long and poor quality you get echoes in signal and shadows in the projected picture.
2.feed the right solution to the projector and adjust in menu pc adjustment the item FINE Sync. native resolution is 1024 x 768.
Jan 16, 2011 | Eiki LC-X50M Projector
Sony Projector won't turn on
Its because bulb ballast circuit problem.You have to replace it
Jul 09, 2010 | Sony VPL-ES3 Multimedia Projector
Adobe photoshop 7 either stops working and closes or causes my computer to freeze up completly
There are many reasons why a computer may freeze or completely crash. The most common reason is an overload in the memory. Computers have a set amount of memory to work with (this is their RAM, or "Random Access Memory"). If you attempt to do more with the computer than it's capable of handling at one time, it may "crash" in an attempt to save itself. Generally, the cause of this is generally that too many programs are running at once for the computer to handle. If you are not using a program, close it. Conflicts between programs are other well-known reasons for crashes. Programs such as virus detectors are notorious for conflicting with other applications and utilities. If you notice that crashes are occurring while the same two programs are running, try to avoid running these two programs at the same time.
What Can I Do?
  1. Take Notes
    Your first step should be to pay attention to what was happening at the time of the freeze or crash. Try to isolate the program that may be causing problems (this can help prevent a further, more damaging, crash). Is there a history of problems with a particular program (or combination of programs) on your computer? Were too many programs running at once? Was it a particular task you were trying to do? See if you can form a hypothesis about the cause. By understanding what may have caused it this time, you can attempt to avoid future, similar occurrences.
  2. Try to End the Program
    Windows provides a "Task Manager" that lists all current programs in operation. In Windows 9x & ME, this menu is brought up by pressing Ctrl + Alt + Delete at the same time. In Windows 2000, after pressing Ctrl + Alt + Delete, click the "Task List" button. In this menu, you can attempt to individually close programs that are causing problems. If programs are unresponsive, Windows will attempt to notify you of this in the Task Manager.
    If you are able to effectively close the program causing problems, save your work in all other open programs, and reboot your computer. This will help to prevent further crashes, and give your system a clean slate to work from again.
  3. Reboot
    If you are not able to effectively close the program in question, you have several options. Please note that any changes in unsaved documents WILL be lost in a system reboot. With the Task Manager open, try pressing Ctrl + Alt + Delete once more. Windows will attempt to reboot itself.
    If the Task Manager does not respond, you still have a few options. Check your computer's tower to see if there is a "Reset" button (it will be in the general area of the normal "Power" button, and should be slightly smaller than it). Press the "Reset" button, and your computer should reboot.
    If you are unable to find the "Reset" button or do not have one, there is one final option to pursue. Find the "Power" button on your computer's tower. Press and hold this button. You will need to hold it for a few seconds (sometimes up to ten full seconds). At some point, your computer should shut down completely. If nothing happens, keep holding the button. Do not press and let go without giving the computer a fair chance to shut down.
Sep 07, 2009 | Adobe Photoshop 7.0 for PC
Double vision my NEC MT1055 lcd projector has double vision on the menus - looks like the menu was burned in a half in to the left
looks like one of your lcd panels is ghosting. If remember correctly your going to be asked to replace the whole prism.
Aug 28, 2009 | NEC MultiSync MT1055 Multimedia Projector
Wont download all my songs!
check the options to see if the option to allow songs with digital media rights is enabled. This sometime prohibits the songs from being downloaded to the player if they were downloaded from itunes or rhapsody.
Feb 23, 2008 | Creative Labs ZEN Vision:M Digital Media...
Double vision display
sounds like you have one or more bad LCD panels in the projector. replacement of the panels will fix the problem, but the cost of the panels is around 500.00 each; there are three panels.
Dec 18, 2007 | Panasonic PT L557U Multimedia Projector
Double Image
It's may be the video cable from the PC. I had the exact same problem with my Epson projector today. Treat y
Oct 06, 2006 | Epson PowerLite 5000 Multimedia Projector
Lenovo X61S GL L7500 1GB/80 12.1 BT F VBE PC Notebook Logo
169 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
