Question about Estate TAWX700JQ Top Load Washer
Washer won't drain
Estate washer won't complete cycle because it will not drain. I blew air through the hose and it bubbled in the basket. i sucked through the hose, and some water came out, but not much. there appears to be no clog in the hose, but still no draining?
    President:
  • Estate Master
  • 2,651 Answers
Soundslike a problem with the lid switch, if it thinks the doors not closing then the unit will not drain.yo dont hear the motor running do you?
Posted on Mar 09, 2009
  • Ron Coons
    Ron Coons Mar 10, 2009
    next thing to losten for then is as you open and close the lid you should hear a "clicking" sound, if not that tells me that the lid switch is not being activated and prbably needs replacing
My front loading Crosley washing machine is showing error code 21. What does that code mean?
Can't remember the exact error code, but my crosley front loader would not spin. I found out this was because all the water was not being pumped out. I wash a lot of dog blankets and found out the drain basket was completely blocked. I was able to remove and clean from the back and this fixed my problem. I guess it could be the pump but check this basket first. The way I did it from the back was hard so I suspect there is a better way to access the basket.
Jun 23, 2014 | Crosley CW5000 Front Load Washer
Won't drain
the problem is either your pump or your hoses. this an easy fix. all you need is a screwdriver and a bucket to catch water. 1st unplug the machine and remove the drain hose from the drain. then try to drain the water from the washer by plugging it back in and setting the washer to drain. if no water comes out of your drain hose then you know your plumbing is ok. next put the drain hose back in the drain and take the cabinet of your washer. you will see your pump with 2 hoses connecting to it. one hose connects to the basket and the other to the drain. disconnect the hose coming from the basket and if water comes out then you know the basket is not blocked with any article of clothing. if both check out ok your problem would be the pump. write down the model and serial number to your washer and buy a pump. they are only about 15.00. remove the old and install the new. having a repairman like me install would cost about 150.00, so i advise you to do it yourself or have a friend help.
Jun 24, 2011 | Washing Machines
Washer will not fill in rinse cycle.
hi, When the washer acts up in the rinse cycle, will it try and fill and then the water starts going out the drain hose? If this is the case, the drain hose is either needs to be raised to be as high as the top of the washer or, it needs to have a loose fitting where it goes into the drain pipe so it can have air **** back into the drain hose after it releases the wash water.
i know this is a lot of info that might not even be the answer but, I am giving you the most common fix. Please let me know if I have answered your question or let me know if I can assist you further.
If this does not seem to be the answer, maybe I need clarification.
Vic
Jul 12, 2009 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
Flashing F2
“F02” (Drain Problem)
Select PAUSE/CANCEL twice to cancel the cycle. Unplug
washer or disconnect power.
Check the following:
Is the drain hose kinked?
Is the drain hose frozen?
Is the drain hose clogged?
Is the drain hose more than 96" (2.4 m) above the floor?
After running this check list, plug back up and try a complete cycle using cold water and no detergent. Sudding can mimic a drainage issue as well. make sure you are using the correct HE detergent to prevent over sudding.
Feb 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Matyag Atlantis washer didn't drain
it could be a bad timer on the machine which tells it to change cycles i had the same problem and had to call them to come fix it. if this part is bad then it will go through asll cycles and never change cycles does that make sense?
Dec 28, 2008 | Maytag Atlantis MAV6000 Top Load Washer
NEC NFL-1065 washing machine won't drain or spin
I had the same problem , I replaced the pump havent had the problem again. Then the heater element blew, (kept triping the house fuse) replaced that, then the door would'nt lock everytime, now it will fill up then give a code "E8" I think it's the mother board
Oct 25, 2008 | Washing Machines
Maytag Atlantis top loading Washer
try using compressed air at a low PSI (40-80) blowing through the drain hose backwards. besides that you will have to axcess inside parts to disasemble and clean the pump/hoses...
Jan 23, 2008 | Maytag Atlantis MAV6451 Top Load Washer
Water keeps going and going and going!
the water is draining back to the ocean. The drain hose was not emptied properly from its last use. Put the machine in spin cycle (about 5 minutes) only to spin out the water from the outer tub completely and retry washer. If still problem, then visual check drain hose that it still has a "rising" section higher in altitude than the water level of inner tub (when working properly) before it makes a U-turn downward to send back to the ocean. You can also test the drain hose by putting machine in fill mode and crimping off the hose (fold hose over) to simulate a good drain hose. At this test, you should not "feel" water running through the hose if successfully crimped.
Jun 21, 2007 | Estate TAWS800JQ Top Load Washer
Estate TAWX700JQ Top Load Washer Logo
100 people viewed this question
Top Estate Washing Machines Experts
Dan Webster
Dan Webster
dweatherby
Are you an Estate Washing Machine Expert? Answer questions, earn points and help others
