Question about Bosch 24 in. SHU43 Built-in Dishwasher
Water standing at the end of the cycle in my Bosch dish washer
About an inch of water stands at the end of the cycle on my Bisch SHU43C
  • Anonymous Mar 17, 2014
    bosch classic dish washer says end
  • 27 Answers
Where is the water is it visible above the filter plate or is it in the bottom of the sump
if its in the bottom of the sump thats normal it will always leave water in the sump
Posted on Mar 13, 2009
I have a bosch dish washer with a E15 error and warning light to check water flow
E15 fault is water into base and has activated the anti flooding device.
You will need to remove the water from base and investigate for leaks.
Jul 10, 2014 | Bosch 24 in. SGS43C12 Classixx...
Just got a new Bosch dishwasher (forget which model). After the dishwashing cycle has ended (even long after), the dishwasher and dishes are still wet. Was this an installation problem? Thanks
Hi -
I can't see how any installation problem would cause this - if the dishes are still wet at the end of the cycle, you'll probably find the water isn't heating during the wash cycle. The dishwasher uses steam to heat the washing compartment and dry the dishes. It would appear that the dishwasher isn't heating water internally.
Even if the washer was accidentally connected to the cold water supply ** (see note), this shouldn't happen as regardless of the water supply temperature, the washer should still heat the water to the correct temperature internally.
** UK dishwashers should be connected to the cold water supply. For US installations, dishwashers are commonly connected to the hot water supply. For other locations, please consult your installation instructions.
I suggest you start a regular wash cycle and leave it to run for 10-15 minutes. Then open the door and test the temperature of the water in the base of the washer by hand. The water should be hot and there should be steam present in the washer when you open the door.
If the water is cold or only warm, the water isn't being heated internally or isn't heating to the correct temperature, in which case you should contact the retailer or Bosch Service immediately for a replacement. Do not accept an offer of repair on a brand new washer!
Additionally, do not attempt to repair the dishwasher yourself when under warrantly as this will invalidate the warranty.
Hope this helps. If you need further assistance, please let me know your location and the model number of the washer. This should be laser-etched into the top of the door if you can't find it on any of your paperwork.
Regards, BElectric
Apr 27, 2011 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
Dishwasher not completely draining
Make sure the drain screen is not clogged at the bottom of the dishwasher or that you water drianline is not pinched or clogged behund the dish washer. if you are confidant in doing this you may be able to troubleshoot it. It possibly could be a water pump issue too.
May 16, 2010 | Dishwashers
Same problem. 2-3 inches of water left in the dishwasher at end.
Inspect for plugged drain screen. Sometimes you have to take apart the bottom area for access...
Sep 18, 2009 | Bosch 24 in. SGS47E02 Exxcel Free-standing...
Standing water at end of cycle
It is normal for a small amount of water to remain after each loadof dishes is cleaned.
Is the water clear or cloudy?
Is there an odor?
How deep is the water? Less the two inches?
Post back with your findings here. OK?
Apr 16, 2009 | Dishwashers
Water not coming in
Hi jane_taylor4
The water valve could be bad. Depending on how old the dish washer is there was some prolems with the older water valves. the water vavle is the most common problem with the bosch dishwashers when water will not come in.
Sep 21, 2008 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
Dishes are not coming out fully clean
first if the pump is running and you can hear it washing it should clean now hot water cleans dishes not the washer the hotter the better at least 130-135 degrees modern dish washers use less water than older models so if you don't get the water as hot as you can stand it at the sink before you turn the washer on you can fill it with cold water second its important that you use jet dry and if your dishes aren't dry at the end of the cycle then on most washers you can turn the disp up for more hope that helps let me know
Dec 01, 2007 | Bosch 24 in. SHU53 Built-in Dishwasher
Bosch 24 in. SHU43 Built-in Dishwasher Logo
609 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
