Question about Whirlpool Duet GHW9150P Front Load Washer
Boot of the front loader washer
Heard a big bang. my tub seemed very loose. could it be that the boot is not attached to the tub?
  • Anonymous Mar 10, 2009
    heard a big bang then a severe clunking sound on the spin thought it was the towels being out of balance, took all but three out and still have the severe clunking on the spin
    President:
  • Whirlpool Master
  • 2,651 Answers
Not nessacerily, the bopot off would create leaks not noise, you can remove the lower aceess panel(3 screws across the bottom of unit) and have a look inperhaps one or more of the suspension/shock absorbers) has let loose
Posted on Mar 09, 2009
My kenmore elite top loader has a loud banging noise when spinning
Disconnect power to the washer then tape the lid closed. Lay the washer carefully on its front panel on a padded surface then check the four suspension spring/rod assembly. Make sure the suspension doors are properly attached to the outer tub to prevent an off balance situation that may lead to the banging of the basket to the outer tub during the spin cycle. Also ensure the machine is balanced and properly or evenly seated on the floor.
May 07, 2010 | Washing Machines
My MAH9700 Front Loader washer is shaking a lot and making a loud banging noise when spinning.
unscrew the 4 screws inside the detergent dispenser and lift the top and see if the counterweight on the tub is loose,otherwise it may be the drum bearings going bad on the inner drum
Apr 01, 2010 | Maytag Neptune MAH9700 Front Load Washer
Sears 440723 front loader bangs when spinning. Tub rotates smoothly but seems very loose
Check the Vibration damper rods to be sure that...
1. They are there and mount is solid.
2. If they are broken in 1/2.
3. The plastic knuckle mounts are not missing/broken.
4. There is oil in the shock absorber/spring section of the rods.
Also - there are suspension springs on the bottom of the tub that could be broken and/or missing.
Replace/repair as necessary.
IF THIS IS A BRAND NEW INSTALLATION - be sure you have removed the basket shipping pins (4) that secure the tub during shipping.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jun 17, 2009 | Kenmore 44102 Front Load Washer
Front loader making loud noise with spin cycle
It may be something that was in the wash and fell thru the holes in the inner drum. Check all the plastic agitators and make sure they are all secure and an attach bolt has not backed out of one and rubbing the outer tub. It will wear a hole in it fast if it is.
Usually when the bearings go bad, it gets very loud on the spin cycle, like a loud roar and sometimes clothes will have rust or grease stains on them.
I just replaced my tub bearings on my Frigidare and spent about $60. They are all pretty much the same. On mine they only list the complete rear outer tub assembly with bearings, but you can knock the old bearings and seal out and match them up at a bearing supply house or you can buy online. Online seems much cheaper. If you buy bearings, make sure you get ones with a -2rs on the end of the part number. ex. 6308-2rs. They are sealed and hold up much better in water environment.
I would give it a try, the junk man doesn't care if it comes in pieces or one big piece.
There are a couple online articles that can probably help you. Do a google search for 'washer rear tub bearings"
Jan 29, 2009 | GE WPXH214A Front Load Washer
Tub is very loose bangs and wobbles
suspect basket support broke basket will need replaceing and possible rear tub section if bearing/seal damaged overloading not usually not the cause
Nov 27, 2008 | Kenmore 43052 Front Load Washer
Banging and small leaking
Is this a front loader you have? the banging could be broken shocks.
Mar 11, 2008 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Washer tub bangs
Click on "troubleshooting" above and type "banging" after clicking "find solution", i have a couple of postings there. You could also read others.
Dec 02, 2007 | Kenmore Elite 45986 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
123 people viewed this question
Dan Webster
Dan Webster
Sal De
