Question about GE WBSR3140DW Top Load Washer
I can't get the lid off a Whirlpool Quiet Wash washer. I'm trying to replace the lid switch. Help Steve
  • 40 Answers
Take putty knife and release 2clips in front between top and front panel about 2 to 3 inches from both edges push knife forward in gap and pull panel forward do this on both sides take a flashlight and you can see the clips then take the two screws on both sides that hold top panel on out then pull up on front of top panel then tap right side of top panel to unhook it from control panel be careful control panel will break easy then you will see a two wire connector holding going into control panel disconnect it and top panel is loose then change your switch
Posted on Mar 10, 2009
My whirlpool front loader wont final spin
Check door switch: If the lid switch is bad it will not drain or spin. Try this test: With lid open let it finish wash cycle. Press lid switch down with screwdriver. Washer should begin draining. Release switch. Motor should stop. Press switch a second time. Washer should start spinning as it continues to drain. If motor doesn't come on while lid switch is pressed, replace the switch. Or
http://www.youtube.com/watch?v=TB_W6sPdzkM
Pl click if helped
Apr 05, 2013 | Whirlpool Washing Machines
I have the Imperial Series Quiet Wash I My washer goes off on every cycle and I have to press the lid for the washer to kick in
Probably the 'lid switch' needs to be adjusted. This is the switch which stops the machine when the lid is lifted. Should be a simple fix ...Good luck.....Nomess
Apr 20, 2010 | Whirlpool Washing Machines
Whirlpool Ultimate Care II Quiet Wash fills and does not drain
Check your lid switch. If your washer fills and doesn't do anything, or stops right after the wash cycle and then does not advance to the rinse cycle or drain, the problem is commonly caused by a lid switch malfunction. The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r385198-replacing_lid_switch
If the switch requires replacement, a new one can be purchased on line at searspartsdirect.com, pcappliancerepair.com, repairclinic.com, appliancepartspros.com. Just use your model number as your search criteria. All these sites offer competitive pricing, so shop all them for the best price.
NOTE: Some washer models have the lid switch located near either the left or right hinge of the lid. This type of switch is activated by a rod on the hinge pin. If not functioning, it can often be adjusted by bending the hinge rod until it engages the switch.
If you have questions, please let me know. I hope this helps you.
Jul 20, 2009 | Washing Machines
Whirlpool Ultimate Care II Washing Machine Rinse cycle not workin
Most of these spin related problems are attributed to a lid switch malfunction. A washer that fills and doesn't do anything, or stops right after the wash cycle and then does not advance to the rinse cycle and drain is commonly caused by a lid switch. The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
Let me know if you need further assistance. I hope this helps you.
Jun 30, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Washing machine starts, fills and then stops
This problem is usually attributed to a lid switch malfunction. The lid switch is mounted under the washer top casing on the right hand side. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If the lid switch is broken, the following link explains the steps necessary to replace it:
http://www.fixya.com/support/r385199-replacing_lid_switch_whirlpool_top
A replacement lid switch may be purchased on line at searspartsdirect.com. Just type in your model number and look under the "Top and Cabinet" heading for item number 11. The lid strike will be listed as item 20.
If you do not wish to purchase parts on line, use the part numbers provided and go to your nearest appliance parts retailer. These are standard parts they should have in their inventory.
If you have questions, or if you require additional assistance, please let me know. I hope this helps you.
Jan 18, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool LSR7133KQ0 no pumpout, rinse, or spin.
NO...the problem you are describing are the typical symptoms of a lid switch malfunction. The lid switch shuts the washer off when you open the lid while the drum is spinning. This is a safety feature to prevent injury from moving parts if you decide to add a garment or stick your hands in the tub for some reason while it is in operation. On some model Whirpool's the washer WILL work initially for the wash cycle, then stop when it gets to the rinse cycle. I would recommend you check your lid switch to make it is not loose or broken. Your washer is also equipped with a lid strike (a small plastic piece on the lid that activates the switch) make sure it is not broken off or missing. This will give the same symptoms of a broken lid switch.
If you require a replacement switch, they can be ordered on line at searspartsdirect.com, or you can go to your nearest appliance parts retailer. The part number for the switch is 3949247. The lid strike (if required) is part number 358684. If you need instructions on how to replace the lid switch, you can use this link if you like:
I don't know how savvy you are, so I thought I would add the instructions just in case. I hope you find all this information helpful. Let me know if you require additional assistance.
Sep 25, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
GE WBSR3140DW Top Load Washer Logo
88 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
