Question about Toshiba Tecra 9100 Notebook
Flashing Charging Light on AC Power
When I connect my Laptop to the AC adapter, the charging led flashes quickly and the pc will not power up even if I take the battery out. I have tried 3 different batteries and 2 AC chargers. When I put the original battery in it does not flash but quickly goes from orange to green and when I press the power button all of the LED's go out and nothing happens so I assume the battery is at the end of it's life and there is not enough power to start the system. I think the problem is the power regulator as the system will not work even with the battery taken out and the constant flashing is because there isn't enough power to give a steady charge rate.
    Master:
  • 404 Answers
Shortage on the motherboard, needs new motherboard.
Posted on Mar 09, 2009
Troubleshoot no power supply even the charger is connected
What to Do if Your Laptop Is Plugged In but Not Charging ...
www.pcmag.com > Reviews > Laptops & Notebooks
PC MagazineAnd no battery charging. ... but some problems may require a visit to a repair shop oreven a full-blown ... Get ready, boys and girls, it's time to go troubleshooting. ...Check the AC adapter brick and verify that any removable cords are fully ...
Laptop Won't Power On - Troubleshooting a AC/DC Adapter ...
www.ifitjams.com/lappower.htm
Troubleshooting problems where the laptop won't power, adapter LED is off ... When your laptop won't turn on with the AC power adapter plugged in, many ... SOme laptops even feature a power button that lights when the power is turned on.
Sony VAIO® - Some troubleshooting steps to help you if ...
? 2:56
https://www.youtube.com/watch?v=IsbMD-Ddcp0
Feb 3, 2012 - Uploaded by SonyListens
Sony VAIO® - Some troubleshooting steps to help you if your VAIO will not power on. SonyListens ..... I have a VAIO laptop & the AC adapter isn't charging the battery. Help? Oh yeah ... It's as if it isn't even plugged in. I've tried ...
Laptop Won't Come On Even When Connecte
Dec 30, 2015 | Computers & Internet
Flashing yellow light
attery power LED off, and Caps Lock/Num Lock off Battery or AC Adapter AC adapter not connected or failure
Battery low charge or failure Battery power LED blinking Battery Insufficient charge on the battery c02983514.gif When new computer is used for first time, the white LED light for the AC power connector blinks. Battery is still in "Shipping Mode", the light continues to blink even when AC power is connected.
To resolve, turn off notebook, connect AC power and allow battery to charge for at least 30 minutes, then start computer.
Dec 20, 2013 | HP Pavilion ze4300 Notebook
My hp laptop don't turn on even the charger is
When you connect the power adapter into the laptop, does the power LED light up? If not then - The battery adapter or the adapter's power lead or the laptop's power socket could be faulty. Check power adapter's DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard. This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Mar 02, 2013 | Computers & Internet
Toshiba Laptop no longer charges battery
Aug 07, 2012 | Toshiba Satellite L555DS7930 Notebook
My sons power pack died leaving laptop with dead battery. small light flashing orange at the front .i bought a replacement power pack making sure it was for his model.plugged it in and nothing it wont...
You may have a DC connector problem:
Symptoms of a broken power jack
1. If you wiggle the power cord or the AC Adapter connector on the back of the laptop, the power LED and battery charge LED start to flicker.
2. Battery will not charge in the laptop.
3. Laptop runs fine off a charged battery.
4. With the AC Adapter connected the laptop appears to be dead.
No power LED or battery charge LED activity.
5. Laptop randomly powers off without any warning.
If your laptop is out of warranty, then you can fix the problem by re-soldering DC-IN jack on the system board. If it
May 25, 2011 | Advent 4211c Notebook
About my emachine laptop model d725,cannot charge even my batt is new
Feb 24, 2011 | Computers & Internet
My Acer aspire 4935 is not recognizing the AC adapter. When ever I shutdown the system and connects the AC adapter, it works and the charging LED lights up. Once I press the power button to boot the...
Problem description:The battery charges only when the laptop turned off. The battery charge LED lights up as normal and the battery gets charged to 100% while the laptop is off.
When the laptop is turned on, the battery charge LED goes off even if the adapter is still plugged in.
Possible cause:1. AC power adapter failure.
2. Battery failure.
3. Broken/loose power jack.
4. Motherboard failure.
Possible troubleshooting steps and repair solution:1. This problem could be related to a faulty AC power adapter. It's possible that the AC adapter doesn't provide enough power when plugged into the laptop. To find out if this is your problem, you'll have to test the laptop with another working adapter.Replace the adapter if needed.
http://www.chargerbuy.com/replacement-acer-aspire-9400-ac-adapter-19v-3-42a.html
2. There is a slight chance that you have bad battery. Test the laptop with a know good battery and replace the faulty one if needed.
3. The battery charge problem could be related to the power jack. Maybe the jack is broken or not making good contact with the motherboard. It is necessary to remove the motherboard and take a closer look at the power jack. Resolder or replace the jack if needed.
4. If the power jack is in a good working shape and new power adapter with battery do not fix the problem, most likely you have a faulty motherboard. Replace the motherboard if needed.
Feb 09, 2011 | Acer Aspire 4730-4947 Notebook
My toshiba satellite pro doesn't work , even with charger in , it doesn't turn on , its like all the power is gone :o ?
You may have a bad DC connection:
If your laptop is out of warranty, then you can fix the problem by resoldering DC-IN jack on the system board. If it
Dec 16, 2010 | Toshiba Satellite A60 Notebook
My IBM T20 won't start up, i tried to place the AC adapter but it is not charging. when I pressed the turn on button, not even a light is flashing. what should I do.
Whenyou connect the power adapter into the laptop, does the power LED light up? Ifnot then - The battery adapter or the adapter's power lead or the laptop's powersocket could be faulty. Check power adapter's DCplug that connects into the laptop power socket with a multi-meter, the voltageshould be slightly higher than the voltage that is printed on the label on thebottom of the adapter. If the voltage is zero or way below the voltage that isprinted on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK thenconnect it to the laptop and power it up, then look at the power/batterycharging LED light and wriggle the power plug in the laptop's powersocket. If the power/battery LED light flashes and in a certain position thisLED light stays firm, then the power socket is either faulty or it has a drysolder joint where it is connected to the motherboard. This can be repaired but itrequires the laptop to be completely dismantled to get at this power socket andrepair. If you cannot DIY then I suggest you get a quote first.
Nov 03, 2010 | IBM ThinkPad T20 2647 Notebook
Toshiba Tecra 9100 Notebook Logo
515 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
