Question about Toshiba E-STUDIO 550 Copier
Toshiba e-studio550 service code CD1, PLEASE help me to fix the problem and if there is any service call to reset it, thanks
  • Toshiba Master
  • 643 Answers
CD1 indicates Abnormal drum cleaning brush motor.
U need to perform followings:
(1)Check if the cleaning brush, recovery toner transport auger and recycle toner transport auger are not locked (no extraneous material or toner clod in both the toner transport sections at the cleaner unit and recycle toner unit.
(2) Check if the connector on the LGC board and connector pins are not disconnected.
(3) Replace the cleaning brush drive motor and recycle toner transport motor.
(4) Replace the LGC board.
Posted on Mar 10, 2009
  • didi2005 Mar 31, 2009
    Finisher not attached properly also will affect the MFP.
    Problem Solver:
  • 10 Answers
Remove transport unit( transfer belt ) inside you will need to clean brush an dmake sure youcould turn brush witout any tightness..after you need to look in the waste toner bottle and see if it's full..if it's full empty it and run test mode 03- 116 ( used toner motor on ) make sure toner its coming out of this waste auger that goes in the waste bottle.turn off motor by entering 166.
this will help by cleaning the auger that carry waste toner from tranfer belt ***'y to the waste toner bottle...
Posted on Jul 16, 2009
How to fix error code C280 for toshiba studio 355
Check home position sensor connector, replace home position sensor, replace SLG board
Apr 25, 2017 | Toshiba Office Equipment & Supplies
Toshiba e-studio 650 suferring code cd1 appears while copying start pls solution
CD1 is a brush lock, check the cleaning unit and clean it out, check gears on the back of cleaning unit that rotate the brush.
Dec 07, 2014 | Toshiba Office Equipment & Supplies
I made my laptop to go for factory seeting. when i used recovery cd1 between installation it gave error message that cannot copy some files like PREINST2.SWM and is giving option retry, skip and cancel. i...
Damaged install CD probably.  Toshiba might send you a new one if you ask nicely.  Alternately, you could download a generic copy of vista from the net; install it; then go to Toshiba's site to get all the drivers for your particular laptop model of laptop.  Install all the drivers and you're good to go.
Mar 03, 2010 | Toshiba Satellite A135-S4527 Notebook
C46 appeared on my toshiba e-studio 550 copier
C46 indicates Abnormal pressure roller thermistor during a ready state.
Perform following inspection:
1.. Clear the status counter.
Change the current status counter value (08-400) “3” or “8” to “0”.
If happen again, perform following inspection:
1. Check the pressure roller thermistor.
(1) Check if the connector is not disconnected.
(2) Check if the pressure roller thermistor closely touches the surface of the pressure roller.
(3) Check if the harness of the pressure roller thermistor is not open-circuited.
2. Check the LGC board.
(1) Check if the connector J334 is not disconnected.
(2) Check if the conductor pattern on the LGC board is not short- or open-circuited.
(3) Replace the LGC board.
Mar 05, 2009 | Toshiba E-STUDIO 550 Copier
Toshiba Satellite A135-S2276 bios password resetting.
Toshiba will have it fixed free of charge:
Read this Toshiba bulletin:
your model is listed in the bulletin:
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/bulletin.jsp?soid=1863789
If the problem has already occurred on your computer, then please make arrangements with a Toshiba Authorized Service Provider to have this problem fixed at no charge. To locate a Toshiba Authorized Service Provider (ASP), please visit Toshiba's Global ASP Locator at http://pcrepair.toshiba.com
copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Dec 06, 2008 | Toshiba Satellite A135-S2276 Notebook
I need help
If the phone displays the message "personalization code blocked", then the phone is blocked due to too many wrong unlocking attempts. I recommend you to contact the service provider or visit the site Unlocking4U.com and contact them about your issue to fix it.
Unlock Phone Unlock Codes Cell Phone Unlocking Service Online Unlocking 4
Dec 11, 2017 | Toshiba TS 10 Cellular Phone
Restore windows
Did you reformat the hard drive? Try to turn off your computer and re-do your setup
Jul 31, 2008 | Toshiba Satellite A135-S4527 Notebook
Toshiba estudio35 trouble code
Try 08-600 sub code of 2. This is a reanitilazation of the HDD it may help you out. If it errors and does't tell you to reboot then your hdd is shot. after this code you will lose all fax presets and templates stored on machine. also just try a reboot.
Apr 20, 2008 | Toshiba e-Studio 350 Copier
707 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
