Question about Dell Dimension 5100C (D51CL1) PC Desktop
Adding old hard drive to new pc!
Right first time problem tried alot but cant work it out hoping some one will save me!! I previously had a dimension 3000 (dell) with 2 hard drives. i had a seagate 30gb hard drive as the slave which i had all my music stored on. that computer got a virus so i fresh installed and music was still on seagate hd. I now have a dimension 5100 which supports basically sata harddrive and the sea gate is ntfs, i would like my music on this computer and have connected the seagate in the slot between the cd drive and the floppy disk drive and have connected the right jumpers, power cable and its set as slave. So here is my problem my computer isnt detecting the hard drive, i tried looking in the system start up, in device manager etc etc i cant find n e way to get it to read it! can some one please help would be really appreciated and thank you for reading this !!!! since it isnt the best piece of literature ever written!
  • yeboi Mar 09, 2009
    thats another problem because of the placing off the hard drive, im not 100% sure how to connect them iv tried finding a dummies guide or any guidance to how to do this! the first drive is sata but the second 1 is IDE my previous pc was all ide so it was plug and play! any ideas thanks for writing back so quickly and trying to help!!
    Genius:
  • 1,605 Answers
The seagate HHD (secondary drive) need to be on the same cable as the primary HHD. unless you haev SATA. then it is need to be connected to the second SATA connector on the mother board.
go to BIOS setup and make sure the BIOS know there are 2 HHD.
you should be good to go.
Posted on Mar 09, 2009
  • Frank
    Frank Mar 10, 2009
    the connctor on end IDE cable is the primary, the connector in the middle is the secondary.
    you have to enable the auto detect in the BIOS for secondary IDE.
    configure the CDROM as primary drive and the HHD as secondary drive.
    if you set it up correctly, you should see the CDROM as secondary Primary and the HHD is secondary secondary drive.
Dell Dimension 1100 hard drive activity light on constantly and hard drive making noise, lagging
Try to create an other user and login with that user, then check if the issue still happen.
Jan 03, 2013 | Dell Dimension 1100 PC Desktop
1. VIDEO FILES TAKE MUCH TOO LONG TO LOAD.....EG. A 5 MINUTE VIDEO FILE CAN TAKE 12 TO 15 MINUTES TO LOAD. 2. i CANT SEEM TO GET ANY AUDIO HELP!!!
Try "K-Lite Codec" pack to help with your audio problem. This should help unless there is a problem with your audio driver. It may be worth checking this in Device Manager. The loading time may be due to your graphics card, or lack of it. If you are not using a graphics card then all of the decoding of your video file is being done by your main processor, and in these instances the more memory your system has the better. You don't say if you are laoding the file from hard drive or the internet. If it is the internet then the previous hardware limitations apply, but it may just be your internet bandwidth. Try downloading from the internet to your hard drive first before playing. This may save your media withdrawal system. Hope this helps.
Apr 04, 2011 | Dell Dimension 3000 PC Desktop
Forgot my password and can't get on
HAD THE SAME PROBLEM WENT ON LINE FOR ALL THE ANSWERS, I FEEL THE BEST WAY WITHOUT LOSING ANYTHING ON YOUR HARD DRIVE WOULD BE TO BUY ANOTHER HARD DRIVE AND AND INSTALL IT TO MASTER AND YOUR OLD TO SLAVE THE DIRECTION TO THE NEW HAR DRIVE WILL WALK YOU THROUGH IT.YOU'LL HAVE ALL YOUR PERSONAL STUFF AND AND EXTRA HARD DRIVE BUT HIS TIME YOU CAN USE AND USB MEMORY CHIP TO SAVE YOUR PASSWORD AND IF YOU EVER FORGET IT THE USB WILL SAVE YOU CYA
Feb 22, 2011 | Dell Dimension E310 PC Desktop
I cant seem to use my 320 gb mobile hard drive. when i connect it to the usb, my laptop reads it but i cant save files into it..help me please.
try to connect your device into your pc and then, try to save files again, if this doesnt work, try to reformat your hard drive, im sorry to say that all your previous files will be deleted upon the format. after this, make partitions to hard drive. then save some of your files into it. if that doesn't work either, try a disk scan to check if your hard drive has bad sectors.
Nov 01, 2010 | Western Digital Elements powered by WD 320...
I have a new pc. so my files and pictures are all gone. I have most of the same pictures on my Myspace account but dont know how to transfer them into a stored file on my pc to send them. any ideas
You can always right click on the photos and save picture "save picture as"
If you still have the old PC you could remove the hard drive and fit it to the new PC or fit it into a caddy to connect via USB
Aug 20, 2010 | Dell Dimension 4600 PC Desktop
I need to add hard drive space, my disc is full...increasing the ram is not enough right?
RAM and Hard drive are distinct issues, if there is some error about the Virtual Memory Low, then Increasing the RAM is better option.
But if you are sure that the Hard drive is full, then definitely the solution lies in upgrading to a larger one, or adding an other one, with the old.
Regards, WAQAR.
Dec 22, 2009 | Dell Dimension 4600 PC Desktop
I have a Dell 8400 that the hard drive is about at capacity. I have an external hard drive but I need the primary drive to have more space so I am thinking about adding a second internal hard drive. Can I...
A better recommendation is to use a program like Acronis, to copy your current OS image from the existing drive to a New larger drive, and install the larger cloned drive as the C: and format the old drive as D: for extra storage. If you don't feel comfortable doing it, that is a project that Geek Squad should be able to do for you.
Nov 29, 2009 | Dell Dimension 8400 PC Desktop
Steps to add new hard drive to my dell dimension 2300
YOu can refer to this site..they are all the same procedure in adding hard drive in a computer.
http://www.infohq.com/Computer/adding-second-hard-drive-review.htm
melnavz
Nov 10, 2008 | Dell Dimension 2300 PC Desktop
Dell Hard Drive
If possible go here:
http://housecall.trendmicro.com/
Scan your entire hard drive and let Trend take care of the dirty work. Being quarantined doesn't mean deleted. You should ditch Norton and Get AVG. Its free and just as good.
Let's hope for the best
Mar 11, 2008 | Dell Dimension 4600 PC Desktop
Dell Dimension 5100C (D51CL1) PC Desktop Logo
237 people viewed this question
Alun Cox
