Question about Apple iPod nano
I pugged in my ipod at one of the school computers to charge it. i clicked the eject button for my device on the screen and waited for the computer to tell me it was safe to unplug it. after i did i noticed the screen hadn't changed from the, "do not disconect" screen and it was still in the dimmed power saver mode. i tried every button; turning it off; pugging it in to my computer; plugging it in to my stereo. Nothing is working, it's frozen. I was thinking about taking it back and getting a new one, what should i do?
  • 3 Answers
Try re syncing.
it sometimes it erases all of the music and adds the stuff on the school pc good luck
Posted on Mar 14, 2009
How to unlock an ipod
Apple's iPod touch, a portable music player with a touchscreen display, is powered by a built-in rechargeable battery that provides up to 40 hours of audio playback and up to seven hours of video playback when fully charged. To conserve power, the iPod touch locks by default after a minute of not being used. If you want to use your iPod touch after it locks, you will need to unlock it. You might need to type a password, depending on how you've configured the device.
Press the "Home" button, located below the screen, or press the silver "Sleep/Wake" switch located at the top of the device. Swipe a finger across the "Slide to Unlock" slider on the screen. The iPod touch unlocks. Press the "Home" button or press the "Sleep/Wake" switch when you have enabled passcode protection on your iPod, then swipe a finger across the "Slide to Unlock" slider on the screen. The "Enter a Passcode" message appears. Type in your passcode, and then tap "OK." The iPod touch unlocks. Forgot Your Password b> Connect the iPod Touch to your computer using the USB cable. Wait for iTunes to open and sync with your computer. Eject your iPod Touch from the computer by clicking the "Eject" icon beside the iPod's entry in the "Devices" section of iTunes. Disconnect your iPod Touch from the USB cable. Your iPod Touch will be turned on and will be unlocked. Tap the "General" menu on the iPod Touch. Tap "Passcode Lock," and then tap either "Turn Passcode Off" or "Change Passcode." If you tap "Change Passcode," you can then enter a new passcode.
Mar 04, 2013 | Apple iPod touch
I have finished downloading songs from computor to ipod; Ipod reads eject before disconnecting
What Windows OS are you using? From Windows 7 and older versions of Windows, there will be a "Safely Remove Hardware" icon in the bottom right corner next to the time. Click on this and choose the IPod. Alternatively, double-click on the Computer (My Computer) icon and choose the IPod under Devices with Removable Storage. Right click on the IPod's icon and choose Eject or left click on the icon and click Eject in the Menu bar of the window.
In Windows 8, you will find these same icons on the desktop screen. There may be a similar option on the Start Screen; however, I'm not positive where that would be.
If you fail to use the Eject feature and remove the device's USB connection to the computer, you risk corrupting the data on the IPod's drive. The computer could still be writing data to the device.
I hope this helps.
(If you have a system with a Unix or Chrome OS, please add a comment with your OS.)
Feb 22, 2013 | Audio Players & Recorders
How do i reset an ipod
Step 1:
There are many iPods each having there own specific method of restore them WHAT MODEL ? The iPod A1136 is the fifth generation iPod from Apple that uses a click wheel to scroll through your device's media library, and may occasionally lock up when you attempt to play a song or display a photo. This error error occurs when the hard disk is unable to access the information and stalls while opening a file. A reset of the device usually corrects the problem, as it clears the device's memory and any errors. Check your iPod's buttons to determine if the cause is due to a hardware error before resetting the device, as the problem may be due to the iPod's hold switch. Slide the hold switch at the top of the iPod to the right, and slide it back to the left to ensure the switch is in the off position. Hold down the center button in the click wheel, and at the same time hold down "Menu" on the click wheel. Continue to hold the iPod's buttons until the device's screen shuts off, turns back on and shows the Apple logo. Plug the iPod's connector cable into the dock connector on the bottom of the iPod. Plug the other end of the cable into your computer's USB or FireWire port to charge the iPod. Wait at least two hours for the iPod to charge. Launch iTunes on the computer, and click "Controls" of the iTunes menu. Click "Eject iPod" in the sub-menu to disconnect the device. The iPod takes four hours to completely charge its battery.
Feb 17, 2013 | Apple iPod Audio Players & Recorders
My ipod wont turn back on
You have not stated any model no. which makes it hard to provide a solution.
Hope this helps.
Jan 24, 2013 | Apple iPod Audio Players & Recorders
How do i unlock my ipod touch
Hope it helps
Jan 23, 2013 | Apple iPod Touch Fifth-Generation
REBOOT IPOD
which model ipod they all have different ways to reset usually through iTunes
Hope this helps.
Jan 20, 2013 | Apple iPod Audio Players & Recorders
HOW TO UNLOK THE A1136 IPOD
click start control panel scroll to folder options tick in the box to show hidden files and holders
connect your Ipod to your computer
click start click click on you Ipod to open
then go Ipod controls device there should be a folder saying locked
right click select rename to open or delete the folder your Ipod should now be open
or you might do a factory reset
hope this helps
Oct 18, 2012 | Apple Ipod Video 5.5 Gen Black 30gb Mp3...
hope this helps
Oct 18, 2012 | Apple iPod MA446LL/A MP3 Player
Ipod is disabled
Attach a USB connector to the iPod and plug it into a USB connection on a computer for power, or into a stand alone USB charger plugged into a power strip for electrical power.
Pick up the iPod. Move the "Hold" switch at the top of the iPod to the "Locked" position so that an orange color appears by the switch. Return the switch to the "Unlocked" position.
Repeat this process.
Press and hold the "Home" button and the button at the top right corner together if using a fifth generation iPod, iPod Nano, iPod Mini or iPod with a click wheel.
Press and hold the "Menu" button and the "Play/Pause" button together if using an iPod Touch. Press and hold the "Menu" button and the "OK" button together if using an older iPod.
Continue holding the buttons together until the screen flashes and then displays the iPod name and the Apple logo.
Release the buttons.
Wait as the iPod resets itself and turns itself back on.
or
Plug the iPod USB cable into the bottom of your iPod.
Plug the other end of the iPod USB cable into a free USB port on your Mac or PC.
Open the iTunes application by using the dock icon on a Mac or the start menu on a PC.
Click on the name of your iPod under the "Devices" list in the main iTunes window.
Click on the "Sync" button to create a connection between the computer and the iPod.
Click on the eject symbol after the syncing process is complete, and then unplug your iPod from the computer.
The lock code has been reset; when you go to disable the iPod again, you will be prompted to choose a new four-digit code.
hope this helps
Sep 15, 2012 | Computers & Internet
Does not comes on
Try doing this: Toggle the hold switch and put it back in the off position. Then press and hold the center button and the menu button simultaneously for ten seconds and the apple symbol should come up on the screen. Then it should work like normal. Hope this helps you!
Jun 16, 2009 | Apple iPod nano
Apple iPod nano Logo
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Computer Repairing
Computer Repairing
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
