Question about Compaq Deskpro EN PC Desktop
Changed old hard d for new one know my pc dont work
I changed my older hard drive with a newe one know my pc doesnt whant to work one detail is that my pc is not equipped with a cd rom drive
Not having had any formal training in repair,,,I would instal a CD/R drive onto the ribbon in the B socket on the motherboard. Make sure the CD/R is jumpered master or Cable select and on the last connector
Posted on Jun 12, 2009
    Master:
  • 404 Answers
What data is in the new one
Posted on Mar 09, 2009
New 1tb hard drive not recognized in bios
it is like putting a new stereo in a totalled car,
May 29, 2015 | Hitachi Computers & Internet
My laptop died so i bought a new one. i took the hard drive out and put it into a hard drive enclosure and have connected it to my new one by usb. my new laptop doesnt recognise that anything is there...
You may have to change the settings on the old hard drive. Keep in mind, the old hard drive was a Master. Since there's already a Master in your new machine, you may have a conflict. Look for jumper settings on the old hard drive to set it to Slave. You can also go into your BIOS and assign the older hard drive as a slave.
Sep 08, 2011 | Computers & Internet
I have an older dell computer and teh hard disk is
No the O.S. will not still be n the system. You will have to reload it. If you have the original disk, that is. Also take ALL of the pertinent info. you want and load to a disk. Such as, pictures, documents, all downloads you have put in the system including the setup. If you don't know how,email me and I can help. Otherwise,insert a blank C.D.,wait for auto play, select the programs, and or pic. or doc.s. right click and choose send to unless you have the option of "burn to" then use that one. I hoped this helps.
Jul 20, 2010 | Dell Dimension 2400 PC Desktop
Have a HP SR1010V, 33GB HD - XP Home. Want to 1) replace HD with a 100-200GB HD OR 2) ADD a 100-200GB HD and 3) ADD a DVD drive. What is best way to copy data to a new HD and to boot the new HD. Rather...
The easiest route would be to install the new hard drive in place of the old hard drive and place the old hard drive below the new hard drive and make it a secondary hard drive or slave drive. Once you have them installed this way you can install Windows XP Home to the new hard drive once you have it installed to the hard drive then you can copy everything from your old hard drive to the new one. Once you have everything copied from the old hard drive you can then format it within Windows to have 33GBs of space to store anything you wish. If you need more detailed instructions don't hesitate to reply.
May 19, 2010 | HP Compaq Presario SR1010V (568656) PC...
Whant to know video card compatibility (spec) i whant to use my old hp vectra vl 400 as a living room pc on my 50'' plasma screen and i whant to have a s-video out sorry for my english iam french steve
Bonjour mon ami... I am in Nuve Zealand.. You are going to need an older type card, if memory serves it needs to be AGP, These are a little old for things there days, and while they will output to a TV, the quality is NOT going to be very good... But in saying that you still get acceptable results, i would guess you will use XP SP2, as your OS? This will drive any card you choose well. I have included a link below to help you choose an AGP card, that suits your purpose and price range.. Bon Chance
http://www.diamondmm.com/howtobuyvideocard.php
Feb 25, 2010 | HP Vectra VL400 PC Desktop
Upgrade hard drive in panasonic toughbook cf-50
1 - Using a stack of DVD RW blank disks, or a large capacity USB Flash/Jump Drive, back up your Laptop computer completely. If necessary, Use WinZIP to ensue that everything has been compressed into the smallest capacity possible.
2 - When you are certain that you have backed up the drive completely, remove the older drive
3 - Line up the new drive and the old drive and ensure the jumpers are set to the same settings as they were set on the older HDD.
4 - Once you are sure, you then restore everything from the back-up drive for the old hdd to the new disk drive.
5 - Test to ensure that everything from the old drive has been backed up from the old drive to the new drive.
6 - If you are comfortable that your backup has been completly restored from the backup meda to the new, larger hard drive, then be certain that you have restored from the older drive to the new drive, tighten all screws and cables, then close all ports and ensure that everything has been done properly by and for you.
7 - Be certain that you have created the same user accounts in the new drive as you had on the older drive.
8 - Now, power off the new drive while in the laptop. Wait about 30 seconds to one minute, then restart the new hard disk drive.
9 Test everything, to be sure that everything works properly. Go through everything from the top of the menu to the bottom of the menu. Try all accessories, try all applications. Ensure that all works right and that the applications work as they used to work, when it was on the old drive.
10 - Remember, you have a warranty on the new HDD, so be sure that you have tested everything to ensure that it all works properly, before you sign off on this new drive.
11 - Once you are certain that it all works correctly, you can then be sure that it is working properly and competely, because only you know if things are working correctly as they should be.
12 - Then you can sign off and you can be sure that things work properly.
13 - As carpenters say ... measure twice; cut once. You can only do this one time, so if you measure it more than one tim, you can be certain that you will get it done correctly and be happy that you did it right. from beginning to end.
Have fun. Don't be too serious about it, but do be careful, and get it right. Remember, get it right the first time, and you will be pleased with the results at the end.
Jun 22, 2009 | Panasonic Computers & Internet
Cant reinstall windows because it sayd it cant find a hard drive
two things, check your jumper setting, if it is an IDE hard driver.
Second the computer usually won't recognize the Hard drive until it is formatted for the first time. Did the computer stop and say it could not find hard drive ? and you got F1 to continue, well if you did, just continue. Error 655D is a registry screw up, unplug your usb stuff if you can. remember your drivers aren't installed yet (usb requires drivers-once windows is reinstalling your get the drivers...good luck if you need any more help, just let us know
May 09, 2009 | Dell XPS™ 600 PC Desktop
Averatec 6200 rw dvd drive doesnt work
YEs, typically that sound means the Hard Drive crashed. Although you may be able to still use it, its not recomended. Hopefully you backed up you important files because most likely they are un-recoverable. Does the laptop boot at all? If so, do you get a hard drive not found error? any errors?
You can easily replace a hard drive on a laptop. usually you just remove a small screw and pull the old hard drive out and replace with a new one.
Go to any computer store or if you can, order one online as it may be cheaper.
Order a new one, get one with more hard drive space if you want, especially if you have alot of files.
Make sure its the right type of Hard drive as well. I.E. SATA or IDE. If you dont know, then take your old hard drive with you to a computer store with knowledgable techs who can get you the right one. Typicall you can get an 80 gig hard drive for under $60 depending if its a SATA or IDE and what speed it is.
Keep the old one untill you know the new one is the right one in case you have to compare it again with another one.
You will have to re-install your operating system ( Windows XP, Vista, ETC. )
then once all that is done, you will have to go through the task of re-installing all your software, printers and files.
Hope you kept that re-install disk that came with the laptop, that has your hardware drivers and Operating system on it.
Dont be affraid to look at the specifications of the laptop in the owners manual or to take that with you when you go looking for a new hard drive.
Being knowledgable about what your looking for helps to keep sales people from selling you more than what your looking for.
Tigerdirect.com and Newegg.com are two placethat have the item your looking for and usually at a good price.
Good luck.
Dec 01, 2008 | Averatec 6200 Notebook
Toshiba laptops satellite 4090
Hi, The laptop you purchased is an older model. It will use most any IDE laptop hard drive. The drive you mentioned from your Dell will work in it. You will need to pull the hard drive and put the sliders or hardware off the old one on to the new one. Look here for more info on your laptop. Look under portables.
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp?nav=Download
Nov 30, 2008 | Toshiba Satellite 4090XDVD Notebook
Compaq Deskpro EN PC Desktop Logo
56 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
