Question about Quasar SP-3235 32" TV
T.v.shuts off. i have a 32" quasar that shuts off ,sometimes pretty often and then at times not veary often . it will always come back on after about 5 minutes or so. any help would be apprecitad.
  • 814 Answers
This television is experiencing a component breakdown. This is probably from a overheating problem. The break down component is probably a capacitor. The component has lot its ability to control it operations.When it fails the television goes into the protection mode. This allows the component to cool down and to heal itself temporarily. This will not last and you will need to have the television test for faulty components.The repair of this should not be too expensive.You should call a service center and ask for a estimate of the repair cost before taking it in to be repaired. You may be able to do the repair if you have some experience working with electronic test equipment and tools. you will need a large work space, screw drivers, soldering iron and some test equipment.A digital multimeter will be needed to test some components, if a solid state component has become faulty. Usually a diode or transistor.The repair will require good soldering must visually inspect the circuit boards and replace faulty components as found. Remember these are high temperature components and need to be replaced with the same high temperature ratings. You may want to try cooling the television with a constant cool air flow to save it from further damaged. I hope this information helps you with your problem.
Posted on Jun 10, 2009
Why did my Quasar TV (1993) picture go out again, blue line across the screen? We had it repaired, 3 months later no picture, same blue line.
Sounds to me like something else is causing those parts to fail. It should be under warranty but depends on the repair shop. Why not just buy a new one.
Here are some choices for a new one:
RCA 42 LED42C45RQ Class LED 1080p 60Hz 3 4 ultra slim HDTV
Why did my Quasar TV 1993 picture go out again blue line across the screen...
LG 24 Class 23 6 Diag LED 720p HDTV Black
RCA LED32G30RQ 32 720p 60Hz Class LED HDTV Walmart com
May 29, 2016 | Quasar Televison & Video
Quasar SP3235 Manual Download
Download Quasar SP-3235 Color Television Manual
Have you misplaced your Quasar SP-3235 Color Television Owners Manual?
Would you like a digital, searchable, pdf version of the Quasar SP-3235 Color Television Users Guide?
Follow this link
to download a pdf version of the Quasar SP-3235 Color Television manual.
I hope that helps.
on May 04, 2010 | Quasar SP-3235 32" TV
Dark Picture Quasar QC-33SX51H
try to adjust the brightness and if it wouldint do, replave the CRT socket
Mar 30, 2013 | Quasar SP-3220 32" TV
It shuts its self off picture is still great everything works great it just makes a loud pop and shuts its self off i can turn it back on after a few minutes sometimes it shuts off again minutes later and...
saw a similar problem w/a Samsung and eventually the Focus Transformer gave out w/a big electric pop sound and all power went out. So it's probably related to a problem with high voltage and Flyback issue. Hope that helps a little.
Oct 02, 2009 | Televison & Video
Access code
Hold power and action at the same time for 10 seconds
May 30, 2009 | Quasar SP-3235 32" TV
Quasar palmcorder
reset ur camcorder...
Apr 30, 2008 | Quasar VM-L152 Camcorder
Turns off randomly
mine does also does yours click at random times and the screen goes out in small places for a split second?
Apr 02, 2008 | JVC AV-32020 32" TV
Pic problem
Quasar TV SP3232. Picture disappears but comes back by striking the TV . The sound keeps coming. Perhaps something is loose
Dec 23, 2007 | Quasar SP-3235 32" TV
TV turns off by itself
You are having a dry joint problem especially in the power supply. Resolder the joints in the power supply and else where. whenever your tv heats up the solder expand and break contacts. when your tv cools down the solder joints makes contact. If u dont understand, please seek professional help.
Dec 16, 2006 | Quasar SP-3235 32" TV
Quasar SP-3235 32" TV Logo
66 people viewed this question
Top Quasar Televison & Video Experts
Are you a Quasar Televison and Video Expert? Answer questions, earn points and help others
