Question about Whirlpool MH7155XM Microwave Oven
Whirlpool microwave oven mh7155xmb0 not venting
We have this unit for 5 years. It used to draw steam from the range below into and thru the filters, but does not now. Filters are cleaned. The unit is setup for outside venting thru a duct which goes out thru the roof. Since there is no draw of the steam at all, I suspect some malfunction inside the unit. Fan motor runs on all 4 speeds.
    Brigadier General:
  • 4,088 Answers
Possibly a bird built a nest (swallows) in or on the roof vent. Make sure the fan turns freely when off. Check the vent tube that goes up to the roof--if flex-tubing, it may have collapsed and pinched off the air flow (it may be too long). Make sure that a one-way valve which should be near the exit of the hood is free to move when air flow pushes on it. This valve is supposed to prevent back-flow of air into the house. Hope this helps!
Posted on Nov 17, 2009
GE Spacemaker XL1800 vent fan doesn't pull air from beneath
On the exhaust system (top of unit) there is a small metal 'damper' that is most likely stuck shut. If that is all clear then you have a problem in the duct work of the home.
Feb 23, 2014 | GE XL1800 1100 Watts Microwave Oven
The vent fan does not draw air from stovetop
There is a wire mesh filter and a carbon filter on the under side of the unit. IF they are plugged then it wont draw air. The other issue is this unit has a dual option for installing the fan. One is to vent to the outside and the other is to vent to the inside, if the fan is not installed for the correct usage, you have no airflow either.
Oct 19, 2017 | GE JVM2070 Microwave Oven
Frigidaire microwave oven
Hello - This may or may not be specifically for your model, however these are generics instructions that I found.
To replace the light bulb to the over the range microwave you will need to follow the steps below:
1. To replace light bulb, first disconnect power to the microwave oven at the circuit breaker panel or by unplugging.
2. Remove the vent grill mounting screws.
3. Pull the vent grill away from the unit.
4. Remove the charcoal filter by pushing it inwards, then turn and pull it away from the unit.
5. Open light cover located behind filter mounting by carefully pulling up on the front edge.
6. Remove old light bulb and replace only with equivalent 30 watt bulb available from part distributor. Bulbs are also available at most hardware stores or lighting centers.
7. Replacing the microwave oven light cover by carefully pushing into place. Replace the charcoal filter. Push the vent grill back into place (engaging both the bottom and top tabs) and replace the vent grill mounting screws.
Note: DO NOT USE BULB LARGER THAN 30 WATTS.
Oct 27, 2012 | Frigidaire FMV152K Microwave Oven
Ge spacemakerxl microwave jvm1650 vent is not drawing air
It is possible, you have removed and checked the filters, still the intake is low even without the protective filters. The system will need to be taken apart to find the opstruction, or as you said a hole in the venting mechanism.
Jul 04, 2012 | GE JVM1650 1000 Watts Microwave Oven
I dont have a vent for above range microwave oven
It doesn't have to vent outside. These are designed to recirculate the filtered air back into the room. If you cook without a range hood now it will work fine for you.
Eric
Oct 29, 2009 | Whirlpool MH7140XF Microwave Oven
I was given a Whirlpool microwave. I think it's 6
Not really over the short term, if the vent discharges back into the room. If it is of the type that discharges through the ceiling, you could have grease build up in the vent over time. I found replacement generic filters the other day at Lowe's. But, I wasn't looking for filters at the time. Check there or a similar store.
Good luck,
--W/D--
Jul 20, 2009 | Whirlpool 1.6 Cu. Ft. Over-the-Range...
Maytag microwave just died.
Take it back to the store and make them do something about them. If they dont then file a complaint with the BBB no reason for you to have to deal with this when it is there problem. It sounds like there is a venting issue and more going on
May 19, 2009 | Maytag Appliances Over-the-Range Microwave...
Recirculating over the range micro does not take care of steam
Mayny reason. Does it vent outside? If not you are not getting a great amount of air flow. Are you filters clean? Dirty filters will stop max air movement. These are not the best machines for moving air but they sure are great spacemakers. Not sure if this can be fixed by any means other than a true vent hood.
Jan 26, 2009 | Maytag MMV4205 Microwave Oven
Vent motor turns on, but does not draw air in as it should...
the vent tube in back may not have been changed over they can be vented or ventless but you must switch the flap in back you had the answer in your question ... good job,,..lol
Jan 13, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Fan on over the range microwave does not have enough suction to **** the steam from stove through the microwave. Does the blower get turned a certain way for this to work? Is there a .pdf operational...
This may be caused by a weak fan, improper installation, clogged filters, blocked air ducts, or a blocked outside vent.
Assuming yours is a Whirlpool, you can download Whirlpool owner's manuals and installation instructions here.
This will help you check the mounting and setup, as well as helping you check the filters to see where the problem lies.
Please write back with your brand and model number if you yours is not Whirlpool.
Jan 02, 2009 | Whirlpool MH1170XS Microwave Oven
Whirlpool MH7155XM Microwave Oven Logo
240 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
