Question about Compaq Presario V4000 Notebook
DSS-5+ Connection I have the DSS-%+ 4 way and my main system work and whem I try to connect the labtop I do not have connection. I have been trying to used all the ports but still have the same responce. the light goes yellow. Please advice
I'd like to use my canton DSS 303 as a computer speaker and i don't know whether i can or how
It doesn't know or care what feeds it if the interface is compatible.
http://hifi-ring.com/2008/03/30/canton_dss-303_digital_sound_station_for_ipod.html
" ...via the 3.5mm line-in connection". Find a stereo cable that matches whatever you have on the PC end and 3.5 mm on the DSS.
Sep 09, 2011 | Canton DSS 303 Mutimedia Series Audio...
Trying to connect with a wired connection that works because i know i use it for my xbox but it says something like code error 51420
not every USB to Ethernet adapter works for the Wii. Here's what I've found from Nintendo's site. You may need to connect with your Wi-Fi and update it first.
Error Code: 51420
The Wii console is not able to connect to your wired router or modem.
1. If your connection worked previously, check to see if there is a Wii System Update that you have not aquired. To get the latest Wii System Update:
1. From the Wii's main menu, select the Wii icon along the bottom left of the screen.
2. Select "Wii Settings".
3. Click the left arrow to get to Wii System Settings 3
4. Choose "Wii System Update"
5. Choose "Yes" to connect to the internet and perform a Wii system update.
2. Make sure that you are using the Wii LAN Adapter made by Nintendo (click here for a picture and connection steps). LAN adapters not made by Nintendo likely will not work with the Wii console.
3. Check to make sure you are not running the Wii LAN Adapter from a USB hub (a device that connects multiple USB products through a single device), as this will likely not work. Connect the USB Connector directly to the modem or router.
4. Ensure that the Wii LAN Adapter setup is correct, and that the Wii LAN Adapter was connected with the console turned off. For step by step connection instructions, please click here.
5. Check to see if the ethernet cable you are using is not working properly, by connecting another ethernet cable from your router/modem to the Wii LAN Adapter. If the connection works using a different cable, then the problem was with the first cable.
6. If possible, try another Wii LAN Adapter. If you are unable to try another Wii LAN Adapter, or are still receiving this error code, please call 1-800-255-3700 for assistance.
Apr 03, 2011 | Nintendo Wii Console
I have direct tv and I am trying to hook my wii up so I can watch netflix it is giving me an error 51420
Error Code: 51420
http://www.nintendo.com/consumer/wfc/en_na/ds/results.jsp?error_code=51420&system=Wii&locale=en_US
Apr 01, 2011 | Nintendo Wii Console
Connecting to matchmaker server is not working
Try resetting your modem and PS3's internet connections..
Turn off PS3 system..
1: Reset your modem by unplugging it from the main power source.
2: After a few minutes, plug modem power back into modem. Allow all connections to configure
3: Turn on PS3 system.
4: Go to "Settings" then scroll all the way down to "Network Settings"
5: Make sure that the "internet connection" (the second menu) is "Enabled"
6: Go to "Internet Connection Settings" and go through the motions again.
Good luck.
Jan 24, 2011 | Sony Playstation 3 (PS3) Console
Connecting to matchmaking server error message
Try resetting your internet connection settings:
Good luck.
Input signals Marantz SR4003
There are four digital connectors on the back of the unit: 2 optical and 2 coaxial. They are marked a s 1 2 3 4. 1 and 2 are optical, 3 and 4 - coaxial. Also you have front optical connector marked as F.
You can connect 5 digital sources to your receiver. For example, connect your DVD to input 2 (optical) by optical cable and connect your DSS to input 3 by coaxial cable. Assign DVD to digital 2 and DSS to digital 3 in input setup menu.
Aug 14, 2009 | Marantz SR5001
Lc-42d62u 42in.
This is a common issue with HDMI. Try unplugging the TV for 2 monutes and also reset the cable box as well by inplugging.
Feb 10, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
D-link dss-5 setup (please help!)
you need to make sure that DHCP is enabled in the router settings and that your network cards TCP/IP is set to obtain an ip address automatically.
Also check that your computers workgroup is the same as your friends eg, Home or Workgroup.
Nov 03, 2007 | D-Link Express EtherNetwork DSS-5+...
Connection of p910 with PC through DCU-11 failed
hi sounds like you need more configuration to the connection look here in the manual for connecting to other devices: http://www.sonyericsson.com/downloads/P910a_UG_R2a_AE.pdf page 134 and 154 (cable) good luck
Feb 27, 2006 | Sony Ericsson P910
Compaq Presario V4000 Notebook Logo
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
