Question about Sony Televison & Video
I am getting blue shadowing long the bottom and left side of the screen. I just replaced the bulb thinking that was the problem. it helped but it's still there
  • Sony Master
  • 3,459 Answers
Do not adjust any knobs as instucted in the previous thread if you TV have a convergence problem. Doing so will only make things worse. The blog does however show you how to fix other common problems with these sets.
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your I am getting blue shadowing long the bottom and - 2c07611.png chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Posted on Mar 15, 2009
    Scholar:
  • 41 Answers
I don't know what the deal is with that but I can pretty much tell you that the site that Jean posted is not going to fix it. Is this a DLP set? I assume it is since you changed the bulb. If this is a DLP set, her posting is totally inappropriate. Hope this helps
Posted on Mar 13, 2009
    Scholar:
  • 29 Answers
Http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
Go to this Blog. It "should " solve the problem.
Really, Really simple, do it your self solution !!
Instructions and pictures included :D
Ken , the poster of that Blog writes........
"The problem is with the convergence via the voltage on the
color ray gun tubes that get out of adjustment.
They are also known as retrace lines."............
This blog covers many makes and models with many
issues solved, just with that one solution
Give it a try, it's FREE and SIMPLE :D
Hope the blog helps you also :)
Jean
Posted on Mar 12, 2009
Blue shadow
No. I would suspect it being a Optical Block issue. I is not a pretty repair not to mention the cost factor. If you could get in touch with Hitachi Customer Service they could lead you to s service facility that could comfirm what I think.
Jun 22, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
Blue Shadow
YOU CAN TRY TO ADJUST THE COVERSION POINTS USING THE MENU OPTIONS IF THIS DOES NOT WORK THEN YOUR CONVERSION CHIPS HAVE TO BE REPLACED IT COST AROUND 200 TO 250 DOLLARD
Dec 20, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Shadow issues
You need to replace both convergence ICs they are both STK392-110 you can get replacement ICs at the following link with free instalation Instructions with pictures. Here is the link.
http://servicemanuals.vstore.ca/
Jul 09, 2008 | Philips 50P8341 50" Rear Projection...
Growing Blue Shadow
Hi, please try to replace the cable, try another input source and reseat or replace the bulb . If issue still present upon doing those steps you may need to call epson tech. support at 562-276-1300 so that they can verify whether your projector is under warranty or not and give some great option regarding your projector.
Tirzo
Jun 05, 2008 | Epson EMP-740 Multimedia Projector
Blue dots and blue color
my sony is 4yrs also it has blue dots on the left side from top to bottom and a blue blob on rt. bottom corner no longer under warr. please send repair solution.
Jan 12, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
Blue shadow
colored shadows indicate to me a convergence or focus issue. convergence issues can occur on one part of screen. and most recognizable around letters. this might could be adjusted by a technician
Dec 07, 2007 | Hitachi 57F500 57" Rear Projection...
Yellow and Blue shadow on left side of screen
Blue convergence off = needs convergence IC's replaced =
Would you like step - by - step how to ??????
Nov 07, 2007 | Toshiba 51H84 51" Rear Projection...
Left side of television just started having a shadowing problem?
I have the same problem and was told by a technician that I need to replace the light engine. Probably around $ 700.00.
Oct 15, 2007 | Samsung HL-R6167W 61" HDTV
Blue and red shadows on screen
This sounds like one of the convergence IC's has cracked loose or burned out, and should be replaced and realigned by someone with experience.
Jun 26, 2007 | Hitachi 50UX57B 50" Rear Projection...
SHADOWING
jesus have you move that tv thats new to me but surely techman know about.....good luck
Aug 08, 2006 | Optoma RD50 50" Rear Projection HDTV-Ready...
Televison & Video Logo
118 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
