Question about Hitachi 61SBX59B 61" Rear Projection Television
Hitachi Ultra Vision 61UWX10BB Will not power up Red led flashes
Can some one help? I replaced the IC's with STK-150's and tv powered up and worked but turned off with in 3 mins. Now I am back to the orginal problem, power led flashed 4 times and will not power up. Blank screen with no sound. I removed the red, green, and blue wire connectors to the Convergence board but no change. Why did the IC repair make the tv work for 3 mins? Thanks, Shawn
  • Hitachi Master
  • 5,568 Answers
Your repair didn't address the failure. It is much more likely (in the absence of video and sound) that the power supply has failed.
The items you replaced affect convergence and have nothing to do with the audio section or the set's ability to receive signal. The power supply failure will diasable everything.
Look for a separate board with larger-than-average components, some cylindrical (capacitors), some block-shaped (chokes and transformers). And you may be able to recognize its relationship to the AC input line.
Locate the assembly number which may be on a paper label or just printed in ink on the board; any that appear to have been part of the etched traces will be only the empty board number, not the assembly.
Removing and replacing this assembly can be done by most everyone using a little common sense and just plugging in the connectors where they belong. Call your Hitachi service center and ask about potential repair or replacement costs. If you can score a new board, don't throw away the old one since the new board will be as crappy as the original. This way, you will have time and opportunity to find an independent reapir service for these and have a spare on hand for . . . sorry, the next failure. These things aren't 'your father's TV', they die much more often.
Posted on May 25, 2009
Hitachi 43UWX10B HDTV Used to work great, now when I turn it on the power led flashes and no picture. What steps do I need to take to further trouble shoot this issue?
Replace the STK ICs,they are big black IC they will have PN# on them Replace Both ICs STK392-110s use 120s
Mats Electronics 1-800-628-1118
Oct 29, 2010 | Hitachi 43UWX10B 43" Rear Projection...
I have red convergance problem.. This is the second time I have replaced all diodes and the stk chips. they dont have any 110 stk chips so i am using 150 stk chips. I replaced all diods and now RK 62...
Alot of techs recommend using the higher wattage ICs to replace the stock ones, which is never a good idea since the resistors get stressed. Upgrading to the STK394-160 IC is the only upgrade Hitachi recommends but then the values of the resistors need to be changed since the stock resistors will not work with the upgraded ICs
Oct 09, 2010 | Hitachi 61HDX98B 61" Rear Projection...
Red and green waves...double vision ...how old...how valueble...hitachi 43FDX01B
Try adjusting the convergence. If it won't move see below- (or hitting Magic Focus for some Hitachi’s)
This sounds like convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually $200-$400 Be sure to vote/rate me if this helped Thanks!
See link for more detail
http://www.ehow.com/how_4575598_yourself-projection-tv-repair-convergence.html
Nov 05, 2009 | Hitachi 43FDX01B TV
Hitachi 51UWX20B no sound, no picture, blinking green LED
The 392-150 is a higher current device then the 110---you can use either--this is normal in the hitachi sets---I usually replace both with 150's---check the led that does not light---should indicate which voltage source is bad---if it is one of the 2 voltages for the convergence ic's(one is a positive and the other a negative voltage) then the convergence Ic's may be bad---look for any discolored resistors around the ic's---one way to tell if it is a convergence ic is to de-solder both ic's and see if the set turns on(the convergence will be out the window) but if it comes on change both and do the alignments with the Hitachi remote. By the way----the led should have a location number printed on the top of the circuit board.
Aug 07, 2009 | Hitachi 51SWX20B 51" Rear Projection...
TV Want Power up
This tv have different causes for no power.
Can you tell me if any light on the chassis is off?, if so, let me know the location part number.
Common problem is IC output ( short) or convergence STKs ICs.
Thank you
Jul 26, 2009 | Hitachi 43FDX01B TV
No sound, no picture, blinking LED.
You must use the original stk 392-110 and stk 392-150 and do not mix them up. There is one of each.
All the suggestions about substituting other ICs for 110's are Bullplop, except for Hitachi manufacturers upgrade with changed resistor values included.
Oct 25, 2008 | Hitachi 46F500 46" Rear Projection...
PT-51HX40b BP819
Only use the same part number when replacing convergence amps, or you will need to replace all of the power resistors with recommended values for the convergence amps subsituted.
Dec 08, 2007 | Panasonic PT-51HX40 51" Rear Projection...
Hitachi 65xwx20b convergence
Your message says you "replaced stk392-150", did you replace both of the stk`s or just one of them??? One is for RGB vertical the other is for RGB horizontal, you should always replace both stk`s as a set, Hitachi recommends you use a "replacement kit"
part number X480306", this kit includes both stk`s with a new & supposedly improved set of stk`s as well as all resistors that are required for proper set-up, they strongly recommend you change all of the parts in their kit. The only other thing besides IC`s & resistors that could cause your problem is:
1) bad dcu output (you need a scope to check this)
2) you`ve lost either the +15 volt line or the -15 volt line to the IC`s, "Fxxx" chemical fuse open in power supply.
Dec 01, 2007 | Televison & Video
No power on Hitachi 50UX588
Most likely have a regulator problem. Remove rear cover, look down on the main chassis, turn tv on watch the board to have some colored led's lit, usually a red one and couple of green. If the red is out, its your regulator, if a green one other problems off the circuit with green led are causing the tv not to power up.
Jul 22, 2007 | Hitachi 50GX49B 50" Rear Projection...
Hitachi 61SBX59B 61" Rear Projection Television Logo
208 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
