Question about Sony Playstation 3 (PS3) Console
When i turn on my ps3 it comes up ''hard disc drive is corrupt''
My PS3 has done this before. If it is like mine then all you have to do is wipe all the memory and restart the system which should be one of the options it can give you if you click past the "Hard drive disc is corrupt screen." This can happen because you might of shut down the system by accident when it was saving a game thus the hard drive becomes corrupted. You won't lose any online info but you will lose memory to saved games and thing else that is saved on the HDD like Demo Games. I hope this helps you. If not then I am very sorry and I am sure it will be fixed if not by my advice.
Posted on Mar 09, 2009
Hard disc corrupted on ps3
timbateson
If you are getting the corrupted hard drive message this means that you have corrupted data on your hard drive. The link below will help you address this.
http://www.fixya.com/support/r4853494-fix_playstation_3_corrupted_hard_drive
Let me know if you have any more problems or questions
Issken
http://www.fixya.com/users/issken
Aug 29, 2010 | Sony Playstation 3 (PS3) Console
Playstation 3 says the hard disc file is corrupted
i have been scanning these answers for hours trying to find something that worked. i didnt want to buy another hard drive or enclosure to plug it into my pc so i tried this..... It worked first time, i just turned the system on waited for it to start getting into the loop then pulled the hard drive. it read error on the screen, the ps3 turned off. i turned it off at the power switch, plugged the hard drive back in and turned it back on and it worked first time, went straight to first time setup! im well pleased!
Jul 24, 2010 | Sony Playstation 3 (PS3) Console
Hard disks file is corrupted
Has it asked you to reformat the hard disc? If you have tried that and it still doesn't work then you may need a new hard drive. Don't worry, for $20-$50 (US) you should be able to fix it. Without knowing what happened before that it's hard to say. But my best guess is that the hard drive is internally damaged in some way. Just take off the small panel on the left side, remove the screw, use the little handle and gently pull to the right then out. It should be a Seagate SATA hard drive 20, 40, 60, or 80GB. Just buy a new one from your local store or online. Make sure that you mark the bad one before you get the new one near it so you don't get tem mixed up. Then remove the 4 little screws on the mountinng cage, switch hard drives, install back into PS3 and it will give you the format screen again. Click yes and it will format, turn off, back on, and you should be all set!!
May 04, 2010 | Sony Playstation 3 (PS3) Console
Hard disc corrupt
johnharnetty
If the PS3's built in repair will not fix the issue then you will need to pull the hard drive and format it on a computer. The link below will take you through the process. Note if you still have trouble then there is something wrong with the hard drive and you will need to replace it.
Issken
Apr 18, 2010 | Sony Playstation 3 (PS3) Console
Playstation 3 message "hard disc file system is corrupted..."
Your hard drive may have gone bad. Maybe try using a different hard drive. Once you put it in, the system data should install itself.
Apr 13, 2010 | Sony Playstation 3 (PS3) Console
Hard disc corrupted on my p3
etha125
If you are getting the corrupted drive message this means that you have corrupted data on the hard drive or there is something wrong with the drive its self. The link below will help you address the corrupted data.
Issken
Feb 13, 2010 | Sony Playstation 3 (PS3) Console
On our PS3 corrupt data message
Replace the hard drive as the data may be in a bad sector. I would suggest you use the sony method of carrying this out and not doing it yourself as it can viod the warranty or if you want to just purchase another hard drive.
the data is in a bad area of the disk and thus cannot be recovered. Now you can try something cleaver by take out the hard drive and run spinright on it you can get spin right at www.grc.com now i know for a fact spin right does repair corupted data by moving it out of the bad sector.
Or
Replace the disc itself these people at www.videogamerepair.com witch I found in our directory does save this kinda stuff.
So your pretty much have two choices here.
Thanks and I do hope this was Very Helpful to you!
Dec 15, 2009 | Sony Playstation 3 (PS3) Console
Donald
If the hard drive will not reformat itself, then it needs to be replaced.
Aug 21, 2009 | Sony Playstation 3 (PS3) Console
Corrupted disc
lesrobertsho
If you are getting the corrupted drive message and the built in PS3 options are fixing the drive then you will have to pull the drive and format it externally with a computer. The link below will help you do this.
Issken
Sep 05, 2008 | Sony Playstation 3 (PS3) Console
Hard disc file corrupted-how do you repair?
you need a new hard drive. this will void your warranty but you can replace your original hard drive with another one of the same type (IDE / SATA) and all you should have to do is pop in the drive and it will ask to reformat the drive, say yes and let it go. then you can start playing your games again. if that dosn't work then your firmware is corrupt/damaged and you will need a new ps3. just take the hard disk out and use it in your computer or sell it on ebay. other than that, keep the busted ps3 for spare parts in case the 'new' one needs a new bluray drive in the somewhat near future.
Aug 11, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
