Question about ASUS Eee 4G Notebook
My eeepc keeps keeps changing from upper case to lower case with out my changing it as you can imagine this makes pssswords impossible....HELP
On a brother ce 4000 the bobbin case keeps moving and slipping out of place
There is an adjustment on the upper left and lower right of the case. The upper adjustment is to stop the upper part of the case from sliding out. It turns a little clockwise to do this.
The lower right adjustment keeps the case from rotating and to keep it from falling out. To adjust do this:
Lower right adjustment - Loosen screw on left side of adjustment.
Move adjustment upwards while trying to rotate the bobbin case. It should come to a point where it will not rotate but don't make it super tight against the bobbin case. Just tight enough to allow a thread to move under the adjustment part and the case where they touch.
Aug 28, 2016 | Brother Sewing Machines
I change the news blade for Juki MO2516N serger but it doesn't cut the fabric. Please advise me how to fix it. Thanks, Van
hi there,
which blade you change? upper or lower one?
for lower one just make the top surface for blade aqual with throat plat.
for upper lower turn handwheel to make blade at lowest position in that time the upper lower must be lower than lower blade by arround 2.5mm and keep in your main the two blade also must be very close no space between it.
best regards
ashraf abozid
aabozid@hotmail.com
CAIRO - EGYPT
Jun 14, 2011 | Juki MO6714 Mechanical Sewing Machine
Hello, When typing on my Mo Droid if I want my caps to stay on how do I get that to work.....I tried holding it down but maybe I am not doing it properly?
If you are typing using the touchscreen, the upper-case arrow, touched once, will upper-case the next letter you type and then back to lower case. It you touch the upper-case arrow twice in a row, you should see a green light come on directly over it. That keeps the caps lock on.
If you are using the slide-out keyboard, touch the upper case key once and you should see a triangle underneath the cursor on the screen. That will upper case the next letter you type. To get it to stay in upper case, hit the upper case button again and the triangle should change to a > symbol, point up, underneath the cursor. That should keep it in upper case mode. Don't hold the upper case button down, as that won't do anything. A third press returns it to normal (lower case).
Jun 14, 2010 | Motorola Mobility Droid (2 GB) Cell Phone
Eeepc authentication failure
make sure caps-lock hasn't messed your password input
Aug 28, 2009 | Asus Eee 701Sd Notebook
Top thread keeps getting wrapped around bobbin case on LX-3125
You should hold the end of the thread coming through the needle until the thread has grasped the bobbin thread.
Jun 30, 2009 | Sewing Machines
Kyboard is erratic and doesn't work and the system flashing
sound like your Language / Regional settings. Sometimes the settings get changed, for whatever reason. Check Language and regional setting under control panel. Make sure under regional options and advanced tab are set to English (United States). If this does not help you should seek a repair shop that can check and replace the keyboard for you.
If this helps please rate my solution.
May 10, 2009 | ASUS Eee 4G Notebook
Does not stitch lower thread
Make sure when you thread the machine you have the thread seated into the tension assembly on top, then make sure you have the threading ports locked and the switch in the proper place for each looper threading, the machine will only partially thread if you do not have the port locked and it will even still sew although not properly.
May 25, 2008 | Baby Lock Imagine
Casio g-shock watch
http://world.casio.com/wat/download/en/manual/
try for the manual from here.
riz.
Nov 06, 2007 | Casio G-SHOCK 200M DW5600E1V Wrist Watch
ASUS Eee 4G Notebook Logo
23 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
