Question about Lexmark X340n All-In-One Laser Printer
How do i receive a fax?
Lexmark Fax Machine x5340 - how do I set it up to receive a fax???
  • ncarolina_ma Mar 09, 2009
    Thank you so very much!!!!!! Mr. Smithbrother
    President:
  • 2,692 Answers
Here is the link for your Manual for instructions. .
http://www.lexmark.com/publications/pdfs/2007/5300/en.html
Posted on Mar 09, 2009
I have a lexmark X5340 copy,scan and fax but my toshia laptop does not X5340 but X543 brand how can i hook it up to it
If you follow the link and download the drivers and install, your printer will work properly
http://support.lexmark.com/index?productCode=LEXMARK_X5340&page=driversdownloads&linkSelected=node2%5Esubnode2&locale=EN&userlocale=EN_UK
don't forget to set this printer as default in the printers folder in your control panel
Feb 18, 2011 | Computers & Internet
Which direction to place paper to send a fax
Here's an article in the Lexmark website on How to Scan a Document on the Lexmark X5410, X5450 and X5470 All-In-One Printer. Just click on this link: http://bit.ly/bA62lS. Hope this helps.
Jul 06, 2010 | Lexmark X5470 All-In-One InkJet Printer
I lost my fax instructions for phone hook up for my Lexmark X5340
Here you go M8!
THere you will find the users manual. Download it and you will be fine.
Good luck to you
Please take a moment and rate my answer
Nic
Feb 08, 2009 | Lexmark X5470 All-In-One InkJet Printer
I am trying to set my fax machine
Tried turning on the "auto answer" button on the control panel? :-)
Jan 06, 2009 | Lexmark X6170 All-In-One InkJet Printer
I can not receive a fax
First, make sure the phone line to the fax is plugged into the LINE socket, NOT THE PHONE socket on the machine. Next, try calling your fax machine from a cell phone to see if the fax answers. If no answer, you may have to go into FAX SETTINGS or FAX SETUP from the Lexmark menu. You may have to change any or all of the following: RINGER SETTINGS, AUTO RECEIVE, RECEIVE MODE, TONE/PULSE DIALING, OVERSEAS MODE, ETC. Trial and error getting the Lexmark to answer calls from the cell is probably the easiest way. BEFORE YOU START, print out or write down each setting you may change. This way, if it does not work, you can go back to the original setting.
Nov 23, 2008 | Lexmark Office Equipment & Supplies
Not receiving any faxes but sending
Note: check your equipment for:
Fax machine must be connected to an answer machine
Receiving a fax automatically:
1 Make sure the Fax Auto Answer light is on.
2 To set the number of telephone rings before the printer automatically receives faxes,
Receiving a fax with an answering machine
When a telephone ring is detected, the answering machine picks up the call.
If the printer detects a fax, it receives the fax and disconnects the answering machine.
If the printer does not detect a fax, the answering machine receives the call.
2 Set the answering machine to answer incoming calls before the printer does.
For example, if you set the answering machine to answer calls after three rings, set the printer to answer calls
after five rings.
3 To set the number of telephone rings before the printer automatically receives faxes.
Oct 31, 2008 | Lexmark X5470 All-In-One InkJet Printer
Hp 5610 won't receive fax from lexmark fax
Are you able to receive faxes from others from the same location, if not just ask her to consult her service provider and ask to get the no checked of yours why is it that you she is not able to send fax to you only as your fax machine is capable of sending and receiving fax from others it should be dsome issue with her service provider.
If it was your All-In-One printer thrn you should not have received faxes from any one, not a specific number.
Good Luck
Aug 19, 2008 | HP Officejet 5610 All-In-One InkJet...
How do I set up my X7170 to receive a FAX?
Link
Receiving a fax You can choose to receive a fax automatically, manually, or through an answering machine.
Note: For your All-In-One to receive a color fax, the machine from which you are receiving must also support color faxes.
Automatically Recommended for a dedicated fax line
Your All-In-One automatically accepts incoming faxes using the automatic answering mode. When the Auto Answer light is on, the All-In-One receives a fax after the specified number of rings set in the Options menu.
To set a number of rings for the automatic answering mode:
  1. On the control panel, press Mode repeatedly until Fax is selected.
  2. Press Options until ANSWER FAX WHEN appears.
  3. Press + to choose After 1 ring, After 2 rings, After 3 rings (default), or After 5 rings.
  4. Press Select.
  5. Make sure the Auto Answer light on the All-In-One is on.
When the number of rings that you set is detected, the All-In-One automatically receives your fax.
Manually Recommended for a shared fax and telephone line
You can choose which incoming faxes to accept by setting your All-In-One to manual answering mode.
  1. Make sure the All-In-One Auto Answer light is off.
  2. Press *9* on the telephone after you answer the telephone and hear fax tones.
  3. Hang up the telephone.
The All-In-One receives your fax.
Answering machine Recommended for a shared fax and telephone line
To receive a fax with an answering machine connected to your All-In-One, set the answering machine to answer incoming calls before the All-In-One does. For example, if you set the answering machine to answer calls after 3 rings, set the All-In-One to answer calls after 5 rings.
  3. Press + until After 5 rings appears.
  4. Press Select.
When a ring is detected, the answering machine picks up the call.
  • If a fax is detected, the All-In-One receives the fax and disconnects the answering machine.
  • If not, the answering machine completes the call.
Note: You must set up the equipment as shown in connecting to an answering machine.
May 21, 2008 | Lexmark X7170 All-In-One InkJet Printer
Lexmark X340n All-In-One Laser Printer Logo
128 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
