You can go to http://www.dlink.com/ and search for you routers model #. The model # is probably going to start with DI-xxxxx . You can then download the firmware and then upload to the router from you computer.
We have a 3000 sq ft split level house, so range is critical (could we extend range with antennas,...
(More)
We have a 3000 sq ft split level house, so range is critical (could we extend range with antennas, access points)?
Stability and reliability are also critical
We use a comcast cable modem
Must support mixed environment - 2 Macs connecting wirelessly, 2 PCs (1 with a wired connection)
We all want to be able to share a printer (which will connect to router with a wired connection)
Network attached storage, media streaming - I'm not worried about these now, looking for basic connectivity. Though would be great if I could grow into this in the future...
What port number is associated with the printer port? I am trying to use the USR5461 router with...
(More)
What port number is associated with the printer port? I am trying to use the USR5461 router with Windows 7. I've configured a standard TCP /IP port using the router's default name of 192.168.2.1:1631/printers/My_Printer. Windows offers a default port number of 9100, but trying to print using the combination of this name and number does not work--no data is received at the printer at all. Any suggestions? Thanks for your help.
