Question about Honda Air Tools & Compressors
I want to clean the carburetor on my air compressor that has a honda motor 5.5 hp. How do I clean it????
    Scholar:
  • 104 Answers
WHY do you want to clean the carb? If you have no problem, leave it alone. If you are concerned about old fuel in it, there is a bowl on bottom of the carb about 2" in Doameter. There is a bolt in the middle of the bowl that retains it. ( 10mm as I recall) remove the bolt and bowel. Clean out the bowl with a little mineral spirits or solvet and reassemble.
Note, turn off the fuel from the fuel tank before removin g the bowl
good luck
Posted on Mar 17, 2009
Motor will not idle down
Your carburetor is the problem. Either have it serviced or get a new carburetor. You can service it yourself, you will need carburetor cleaner, very thin gauged wire, air compressor if you have one to blow out the ports etc..
Also you can check out you tube for videos on how to clean a 4 cycle carburetor
Nov 05, 2015 | Ryobi Gas Pressure Washer: 3100 psi 2.5...
Why is there gas in crankcase
Hello Ricky, I would check the carburetor needle valve and seat along with the carburetor float. You could get lucky and just need to clean the crud out of the carburetor float bowl.
Nov 04, 2015 | Honda Es 6500 Gas Generator Electric Start...
Westward 5.5 hp air compressor only runs on choke
remove carburetor, remove float bowl, carefully clean clogged fuel passages with carb cleaner, replace.
Sep 25, 2014 | Air Tools & Compressors
Why does my Dewalt d55270 keep shutting off when I take it off choke?
The jets in the carburetor are restricted... remove bowl nut and clean out the carburetor use fine wire to wire out the jets and purge the old gas. Most have honda carbs and the jets are very fine holed and they are threaded into the base of the carb neck ...
Aug 30, 2014 | Dewalt D55270 Air Compressor 5.5Hp 8 Gal
Engine will not start
Spray some either into the air filter. If it starts and runs for a few seconds then it is not getting fuel. If it won't start it may be getting too much fuel. Verify that there are no vacuum leaks and that the bowl of the carb has gas in it.
Apr 13, 2014 | Honda Horizontal OHV Engine 270cc, GX...
Looking for information on 1988 honda vlx radiator
Instructions
    • 1 Remove the motorcycle's carburetor and clean it with carburetor cleaner, getting rid of any and all grime and deposits within. If necessary, use an air compressor with a small tip to blow out any clogged lines within the carburetor.
    • 2 Check the motorcycle's fuel tank for old fuel. Drain the fuel tank completely and refill the tank with fresh fuel. Old gasoline isn't good for most motors, especially older ones.
    • 3 Remove the motorcycle's seat by unscrewing the two mounting bolts on both sides of the back of the seat with a 12 mm socket wrench. Pop off the top of the air box and remove the bike's air filter. Clean this thoroughly in hot, soapy water. Rinse it off, let it air-dry then apply air filter oil before reinstalling it in the motorcycle.
    • 4 Check the tire pressure and integrity of both tires on the motorcycle. If either tire is flat, leaking air or overly worn, replace the tire and tube.
    • 5 Change the motorcycle's oil. Warm the bike up, then remove the oil drain plug underneath the transmission and drain the oil. While the drain plug is still loose, fill the oil reservoir until oil begins to run out of the plug. This means the reservoir is full. Tighten the drain plug.
Jan 20, 2013 | Honda VT 600 C Shadow Motorcycles
How to get more hp out of a honda 5.5hp engine
Your compressor was designed to produce 11.8 acfm at 90 psi turning neer max rpm (depending on pully combination between 800 ~1100 rpm ) with max pressure of 135psi. At 3600rpm the engine is producing max hp of 5 to 5.5. More power would not really produce more air without potentially destroying the compressor pump by over-reving. If your compressor is not functioning properly you will not get good air flow. Check instruction manual for time period to fill tank from empty. Could be 2 ~3 min. It is takes longer then problems. You can tell how your pump is doing by periodocally checking the length of time to fill tank. The next size range of gas compressor is about 8~9 hp with four cylinder pump and will deliver about 17 cfm.
Mar 15, 2011 | Ingersoll Rand SS3J5.5GH Wb Ir Portable...
I have an Ingersoll Rand Type 30 air compressor. Model #234. I was given this unit because the motor had gone bad. I would like to replace the motor and use it but I was not given the bad motor with the...
One dealer for your model compressor is Northern. They are very good at replacement parts. If you do not have 3 phase power, you could shop around for 5 to 7 hp 220 v motor making sure that the motor mount will align with your plate. Pully size depends on dia. of pulley on the pump. Most pumps turn between 550 min to 1100 rpm depending on the power available and cfm requirements. Most motors turn at 1725 rpm so for example if your compressor has a 14 in. pulley then you motor will need a 5 in. pulley to turn it about 620 rpm. The larger the pulley at the motor the higher cfm produced but more amps used. Motor speed x pulley dia. divided by compressor pulley dia. To obtain more efficiency and highest cfm you will need 3 phase. Good place to see motors and two piece pulley combnations is www.grainger.com. Good luck
Sep 25, 2010 | Ingersoll Rand Type 30 Reciprocating Air...
Why did my craftsman 5 hp 240 volt 125 psi air
your motor overheated from too low a voltage if theres a manual reset try this,also replace the two motor start and run capacitors on the motor body
Dec 24, 2009 | Air Tools & Compressors
Honda Pressure Washer HP 5 not starting
You can try spraying some carburetor cleaner into the carb. If it starts for a minute, your carburetor need cleaning. When you added new gas did you remove the old gas first? Is the air filter clean?
Jul 18, 2009 | Honda 8 HP Engine
Air Tools & Compressors Logo
166 people viewed this question
Top Honda Air Tools & Compressors Experts
John Trevino
Renee Knafel-Bullock
Are you a Honda Air Tool and Compressor Expert? Answer questions, earn points and help others
