Question about AmcorAire UCHW-H12AF2 Split System Air Conditioner
Blower fan runs at one speed - very low
I just had a Amcoraire UCHW-H12AF2 uni installed and everything seems to work OK but the inside unit blower motor. It runs at one speed only and that is very slow. I had the contractor recheck the wiring and that all looks good. Can you help with this problem?
  • 547 Answers
Replace the controls thank you for useing fixya please rate me
Posted on Mar 09, 2009
  • 583 Answers
Its the motor control unit faulty.that unit is located on the board that has to check.as from where the motor gets current/votlage.
Can you operate an amcoraire duo UCHW-H12AF2 without a remote control?
The unit will run @ 75 degrees without the remote. Go to Ebay.com
Search Amcoraire Remote Control, you will find what you need.
Jun 24, 2011 | AmcorAire UCHW-H12AF2 Split System Air...
Air circulator not working on unit
We stock a complete line of replacement parts for Amcoraire Mini Splt Systems.
Support@Pridiom.com
201-266-8234 option2
May 28, 2010 | AmcorAire UCHW-H12AF2 Split System Air...
Fan Motor Replacment for YDK-16-4-L
We had the motor go out on our unit. My father diassembled the blower while on the wall. He pulled the motor out and found that the bearings were cheap and unsealed. He replaced them with sealed and higher grade bearings from Grainger. He reassembled the unit and it worked. It sounds quieter.
Jan 20, 2010 | AmcorAire UCHW-H12AF2 Split System Air...
WE have Amcoraire Mini split unit heat pumps. One is
P 4 code means problem with the outdoor unit, Most likely low on refrigerant. Check all copper pipe connections for leaks first, then add refrigerant after checking pressures.
Jan 17, 2010 | AmcorAire UCHW-H12AF2 Split System Air...
E4 message no cool air. Heat is fine, fan and
If the fan inside works , the unit is probably low in refrigerant , or the filter is clogh with dirt.
Sep 27, 2009 | AmcorAire UCHW-H12AF2 Split System Air...
Low cool air
Because the model numbers are based on the country in which you bought the unit, you will have to do the research yourself on the error code for your unit. Once you find out what the error code is you can determine if low refrigerant caused the problem. Here is the contact info website to download your manual.
http://www.amcoraire.com/index.html
Apr 03, 2009 | AmcorAire UCHW-H12AF2 Split System Air...
Inside blower fan barely running
Look at the control board for dip switches also the black lead(fast) should be on ac terminal. If the indoor coil is too small or there is restrictced air flow can also cause this problem,
Mar 09, 2009 | AmcorAire UCHW-H12AF2 Split System Air...
There is a sensor on the indoor coil that needs to reach a certain temp before the fan speed will increase. Sounds like the unit is undercharged if the sensor isn't reaching the temp it needs to.
Mar 09, 2009 | AmcorAire UCHW-H24AF2 Split System Air...
AmcorAire  UCHW-H12AF2 Split System Air Conditioner Logo
51 people viewed this question
Top Amcor Heating & Cooling Experts
AJMAL KHAN
Michael Youngman
Michael Youngman
Are you an Amcor Heating and Cooling Expert? Answer questions, earn points and help others
