Question about HP Pavilion dv6000z Notebook
My laptop display only shows half a screen. The rest shows a white background with thin black lines. I can attach an external monitor and see everything without an issue.
  • Anonymous Apr 06, 2009
    My Labtop is only showing half of the screen and the rest is black. How can i fix this problem?
  • Anonymous Apr 19, 2009
    my screen has jolted sideways and slightly down a bit, so now i cant see the windows bar at the bottom. 1/4 of the left side of my screen is plain black and it won't go back. is there a way to move it back?
I have solve the problem for my hp nx7300. mine used to show everything that should be shown on the screen but had the screen placed in a Conner so small. i solved this by uninstalling the monitor and unknown device drivers. i have then installed the unknown device as a blue-tooth adapter to avoid this problem recurring. hope this sorts out some people's problem. the other half screen with half completely not shown has to do with the cable connecting the monitor and the CPU. remember solving this for my friend by cleaning the connection port.
Posted on Sep 05, 2009
My laptop drop half screen... Is it loose cable or need sort inside laptop???
Posted on Mar 13, 2012
This happens to mine a week after I got it I just restored my laptop to a week ago and it's fine now
Posted on Mar 28, 2011
  • 1,602 Answers
THE HORIZANTAL WENT OUT OF THE MONITOR, BASICLY IT NEEDS TO BE FIXED OR REPAIRED OR BUY A NEW ONE.
Posted on Mar 14, 2009
Half black screen with white lines
check the display on external monitor, if its ok , then its fault of either the display cable that gives display to the lcd of laptop or the screen becomes faulty
Feb 07, 2013 | Toshiba Satellite A105 Notebook
HP pavillion dv9000 has black horizontal lines across screen and looks like a snowy background
Sounds like the screen is going bad. Isolate the problem by plugging an external monitor to the laptop. Borrow a monitor from a neighbor, friend, relative or co-worker to plug to the laptop. It can be any kind of monitor even the old big fat crt monitors as long as it has a vga cable to connect to your computer's vga port. If the Borrowed monitor does not show the black lines and snowy background, that proves your video card is ok and the problem is your lcd screen. If the borrowed monitor shows the same black lines ans snowy background it means your video card inside the computer has the issue.
The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
May 18, 2012 | HP Compaq Business Notebook nx7000
Screen is white with black vertical lines upon booting up. I can't get beyond this screen.
The video card (built-in on the motherboard) maybe faulty or the LCD screen is faulty.
Connect an external monitor to the video port of your laptop, power up the monitor first then boot up your laptop. If the video card id OK then the laptop will automatically divert the video to the external monitor. Then the problem is a faulty LCD screen.
If the external monitor also displays black vertical lines then you have a faulty video card and since it is part of the motherboard it is impossible to fix.
Feb 11, 2012 | Acer Aspire One Netbook 8.9" Notebook
My Toshiba p105-s6064 display screen is only showing half of my desktop, the other half goes black or flickers various colors. Do I need to replace the display screen or the video card?
Try connecting to an external monitor if display screen is only showing half of my desktop, the other half goes black or flickershalf of my desktop, the other half goes black or flickers various colors then it is the video card if not....have ur display screen changed.
Nov 10, 2009 | Toshiba Satellite P105-S6064 Notebook
My toshiba laptop has a thick white line down the screen
The normal cause of lines across the LCD of a laptop is a damaged video cable. The unusual cause would be the video card itself.
To determine which item is at fault, you need only attach an external monitor to your laptop's video-out, and then swap your monitor view to 'both' or mirrored (usually just the function key (FN), plus one of the Fkeys...look for an off-blue picture of a monitor on the Fkeys).
If the lines across the screen also appear on an external monitor, then the video card is damaged.
If the lines only appear on the laptop's LCD, but not the external monitor, then just the laptop's internal video cable is damaged.
Hope this helps.
Aug 21, 2009 | Toshiba Satellite p105-S6114 Notebook
Computer Turn then a flash of white type with a black background
connect your machine in an external monitor to check if the display is okay on the external monitor. if yes, the problem would the the LCD screen from your laptop. you might need to replace it. also, check if the video driver is correctly installed. if not, re-insatall your video driver. if there's no display on both panel i suspected it's a motherboard faulty.
May 25, 2009 | Computers & Internet
Vertical lines in my laptop screen
Try connecting an external monitor to the Dell Inspiron 9300 and see if the vertical line is also present on the monitor. If the monitor display is fine, then your laptop’s LCD display panel is defective. If the monitor also displays the vertical line, then your problem is with either the video card or motherboard located inside your laptop.
Not sure if the Compaq Presario has an external monitor plug, but if it does the above procedure can be applied to that one as well.
Your responses are intended to improve the level of service provided. Please rate your experience.
Thank You.
Oct 19, 2008 | Dell Inspiron 9300 Notebook
Lcd display
Try connecting your laptop to an external monitor.Connect it with a vga cable to your monitor and press Fn+ monitor key(I don't know what it is for acer) to switch displays.If there are no lines on the external monitor then the problem is due to the notebook lcd.If there are lines then it is due to a driver.Reinstalling the driver should fix that then.
Aug 24, 2008 | Acer Aspire 4315 Notebook
Screen
Problem with motherboard display unit.you need to repair the unit.
May 28, 2008 | Computers & Internet
HP Pavilion dv6000z Notebook Logo
6,825 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
