Question about Electrolux Refrigerators
NEED MANUAL FOR GLHS68EEPWO BROKE THE ARM FOR THE WATER DISPENSER
    President:
  • Electrolux Master
  • 2,651 Answers
Ill assume that the dispensor paddlle is what broke and it is white?? if this is the case hewres the part number, 5304433612.. no real manual available for changing procedure. but the front dispensor panel unscrrews and lifts off allowin youacees tot he armature.
Posted on Mar 09, 2009
Smeg dose not takein water
Is the dispenser door opening.....f not the the dispenser is faulty
It the dispenser is opening but the product dose remain plugged in the cavity, the top wash arm may not be turning.
Clean out all of the particles blocking the top spray arm holes and spin the arm to ensure ti turns freely.
Also check that there aren't any items placed it the top rack that could stop the arm from rotating freely.
Product not coming out of the dispenser id usually always due to the top spray arm . if it is blocked with particles you may not have been cleaning the filter in the sump properly and 'bits' of food ate passing th filter, Make sure the filter in the sump is well firmly in place.
The last important point is to always run the machine at 60 degrees or more You need temperature to do the job properly.
Nov 15, 2014 | Smeg Dishwashers
Broken Water Dispenser Arm - GE Monogram Side-by-Side
First, what is the entire model # from the sticker inside the fridge section?
Nov 11, 2007 | GE GSS20IEP Side by Side Refrigerator
Water dispenser is not working and is to lose water is not coming out
Hello. My name is Peter. I am a former Sears Service tech. Your unit must be fairly old, which the older units work better. Hopefully your problem is a broken plastic arm dispenser P/N 2300629, Cost $22.05. It may also be the electronic control board P/N 230067. This board is no longer available. You my be able to find it on the internet even though Sears no longer carries the board.
How handy are you?
First unplug the unit. Next touch metal so you are grounded. Static will kill a board. There are 2 slots under the bottom frame. Using a flat head screw driver and a business card or something to protect
the surface of the refrigerator pop the dispenser frame off. Unscrew the retainers holding the board and other assemblies. Inspect the board for burn marks and the dispenser arm.
Call me if you need help 443-306-21362.
Simple fix if you are handy.
Oct 14, 2014 | Whirlpool GR2SHWXPB 21.7 cu.ft. Top Mount...
How to dispense water through door
if you hear a buzing sound when pushing the water dispenser, replace the water valve and be sure to defrost the fill tube at the ice maker. if no sound, you need to check for power at the water valve while pressing the dispenser. if power present, replace valve. no power, check the switch behind the dispenser arm.
Jan 05, 2014 | GE PFS22SISSS Stainless Steel French Door...
Water dispenser for gsh25JSTA BROKE can I fix
All of you guys are wrong. What that person is saying is that the physical paddle used when you place your glass in the dispenser bay and press against the paddle....That's what's broken the paddle......
Jan 05, 2013 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
How do I shut it off, going on a trip. Ice maker swing arm is broke, it just flops. Thanks
Without that swing arm, the only way you can turn the ice maker off is to remove it from the freezer, or of course replace a new swing arm.
I would also highly advise turning the water off to the refrigerator. this is good advice for anyone leaving their home for a while, whether or not you have a problem with your icemaker or water dispenser system.
Visit my website for service or to ask general refrigerator questions: www.FixMyFridge.net
Mar 17, 2010 | Amana ABB1927DE Bottom Freezer...
MAKING ICE BUT ICE AND WATER DISPENSER QUIT WORKING.
Sounds like a plugged water filter, assuming the water is turned on to the fridge. If you have a manual, refer to the section about water filters. The filter is usually accessible from the front of the fridge at the bottom....requires about a 1/2 turn counter-clockwise. Some units require that the water be turned off first but not all.
If you do not hear a click when activating the dispenser, there could be an issue with the water solenoid (water valve) that opens and closes when you use the water dispenser....agai...check the manual if at all possible.
Apr 17, 2009 | Frigidaire Refrigerators
Ice maker not working but are getting water from dispenser.
IF YOU HAVE THE SAME FREEZER AS MY MOM HAS THEN I MAY CAN HELP YOU OUT. FIRST OFF WHEN YOU OPEN THE FREEZER PORTION (SIDE BY SIDE STYLE) YOU WILL SEE THE ICE DISPENSER. TAKE THE PART OFF WHERE IS SHOWS YOU: TO MAKE ICE MAKE SURE ARM IS DOWN AND TO STOP MAKING ICE RAISE ARM. THAT IS A COVER THAT WILL COME OFF WITH NO TOOLS NEEDED. ONCE YOU OPEN THIS YOU WILL SEE A METAL FRAME WITH A WHEEL IN THE MIDDLE THAT SAYS DO NOT TURN BY HAND. LOOK IN THE MIDDLE OF THE WHEEL AND SEE IF THE ROD IS BROKEN (FOR EXAMPLE MY MOMS HAD A CLIP ON THE ROD THAT WAS BROKE AND WOULD NOT ALLOW THE DIAL TO SPIN WHICH THEN MAKES THE ICE MACHINE SCOOP THE ICE OUT OF THE BOX) CHECK THIS WHEEL TO SEE IF IT IS STILL IN TACT. THIS COULD BE YOUR PROBLEM.
Feb 24, 2009 | Frigidaire PLHS267ZA Side by Side...
Water stopped running in the dispenser
I had a simular problem! I tried multiple things to make it work!
- bought new filter
- open back of the fridge... (dual outlet water valve)
Finally, I went to a different forum and found a unique idea.
First at the very bottom of the fridge theres a cover remove the cover and you should see the water hose running to the door from the back. In the middle of the hose there a coupler where the hose was spliced by the manufactuer. Now this valve once you separate it will not work correctly, unless you buy a new coupler (4$)... I'm el cheapo, I bought teflon tape for 50 cents (from previous project)... Wrapped around about half dozen times and made sure it wasnt leaking...
Secondly, when you disconnect the coupler no water should shoot out, until you press the water dispenser arm. If water shoots out of the hose on the bottom then you problem is really, really, really easy. You have simplely ice/ or another item blocking water hose to the actual dispenser.
I turned off the frezzer left the door open for an hour or so. I also used my wife's blow dryer on hot, and put it where the ice comes out of the ice maker. I would press the arm peridocially to see if the ice blockage melted yet. REMEMBER: door must be closed for pressure to push on the ice blockage. Thinking back, I might have been finished sooner... I was thinking the water dispenser would work with the door open.
If this doesnt work, then you have other problems... Bad water dispenser selonoid (you can hear this little motor turning even without water), dual water outlet valve maybe broken... Going outside my knowldege level at this point.... But i guess you computer board maybe going bad. Not sure if this computer has anything to do with water dispensing....
Hope this helps! My wife left me alone for about a day or two while she enjoyed the water dispenser...And she broke the vaccum.
Dec 23, 2008 | GE GSL22JFPBS Side by Side Refrigerator
Whirlpool Quiet GU2300XTLS2
Could be a a couple different issues.. Not filling with enough water or food chopper broke or food chopper filter screen clogged.
Check water level:
Run the DW and wait for the main wash to start (water will fill. pause then complete fill) The water should be no more than 1/4 inch below the heating element. If not there..replace water inlet valve.
Inspect food chopper:
Remove lower spray arm and rear water supply tube to upper spray arm. Remove torx screws that secure the sump cover. Remove the rounded cover on the left side to expose the chopper assembly. Inspect for breakage of blockage. There may be an additional plastic screen to remove first.
Jun 13, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Refrigerators Logo
62 people viewed this question
Top Electrolux Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Electrolux Refrigerator Expert? Answer questions, earn points and help others
