Question about Philips SBCHL150 Consumer Headphones
Philips shp2000 no sound left ear
I have Philips SHP2000 earphones, and my left earpiece doesn't provide sound, only occasionally when i move the wire.. I think it's some kind of tear in the wire inside my earphone, but i can't seem to pry it open, its hold together by teh thing that goes over your head..
SOURCE: Philips SHE9550 right earphone is louder
Your current solution to solve the difference in volume (the piece of paper) is not far from the problem.
Your problem is earwax. I have the same earphones and had the same trouble. I checked cable and plug but they were all fine. So then I checked for earwax. It didn't look like I had too much on the rubber plugs - removed that. The problem was what was on the nets. There was some visible, I tried my best to remove that with a sharp knife but the problem remained. I tried to remove some more and found that you can remove the nets easily with a sharp item - just pull them upwards.
There was quite some on the inside of the nets. I thoroughly scraped it all off with the same knife. There can very well be better ways to remove it but this worked perfectly for me.
When all was gone, I tried the earphones and was shocked at how much the volume had gone down in both ears (more in one) before the cleaning.
I hope this helps.
Posted on Jun 22, 2010
  • 231 Answers
SOURCE: left ear does not work (very very weak sound)
try a regular cheap set of headphones on that device .If its the same ,then the audio device is the problem.Or try those sets of headphones on another audio device , computer,tv,cd or stereo receiver.If you are using any kind od adaptor inbetween those headphones and the audio device ,then check that..If they sound the same on any known good device..Then its possible they are bad ..let me know
Posted on Jan 03, 2008
  • 313 Answers
SOURCE: left earpiece has no sound.. can that be fixed?
either theirs something that happaned to the wire like it got stretched out and the inside braided wires pulled apart or came disconnected from the piezoelectric elements, or you have blown the side out.
Posted on Dec 21, 2009
  • 6 Answers
SOURCE: left earphone has lower volume than right
Maybe you can try adjusting the plug, or the wire within the left earphone is rusted, or change the sound effects on a computer.
Posted on May 03, 2010
  • 105 Answers
SOURCE: audio jack has malfunctioned in headphones
You might cause more damage to it, please find a local electronic repair shop near you and let then check it.
Posted on Jun 06, 2010
Replacing minijack
I use a multimeter to check the connections to the ear pieces. I set it to the diode function. The meter's test probes also have a very low dc voltage and this causes a 'click' sound in the working earpiece. Some earphones have 3 wires, others have 4 wires. In the 3-wire setup, one wire is the common wire. It goes to the ground connection of the mini plug. The 'click' sound on the left ear piece should go to the tip of the connector. The 'click' sound that you get on the right ear piece should be soldered to the 'ring' of the mini plug. The 4-wire type of earphone/ headphones cable usually have two wires that are the same colour. These are the ground or common connections for both right and left. I hope that this helps. A multimeter or vom is a necessity. Len.
Apr 11, 2014 | Klipsch Image S4a black For Android In-Ear...
My philips SHE9550 ear phones' right end has stopped giving sound output all of a sudden. Left one is fine. Please suggest some solution to rectify this. Is it possible first of all to resolve this or...
It depends on if the fault is on the wire due to a break or snap or if the fault is in the earphone pin. Now both of the above faults can be rectified as the wire can be joined and the pin can be replaced.
Now if the fault is within the earpiece then it must be checked if the unit is faulty- a open coil - or a wire break to the unit.
Now in all the above cases a multimeter must be used to check the continuity from the headphone pin to the earpiece. An open wire can be rectified by replacing the wire, if the earpiece unit is faulty you need to replace.
Jul 28, 2011 | Philips SHE 9550 schwarz Headphones
Lh earphone of my Shure se210 volume is very low. Have cleaned the earpiece multiple time using the supplied tool. It sounds louder in the rear of the earpiece than inside of the ear. Any suggestions?
The dirt is clogged in the front end if the sound is clear at the rear. So it will be needed to clean the earpiece once again taking care to see that there is no dirt/ear wax clogging the sound vent.
If possible use fine bristles to brush out or clear the openings till the clarity improves since you mentioned the earpiece is working well when heard at the rear, if not the LH can be weak.
Sep 27, 2010 | Audio Players & Recorders
Sound quality decreasing
I also had Philips GOGEAR SA52xx. Philips provide In ear earphones for their device. I was also noticing sound quality loss in it. But one day when i cleaned my Inears(earphones) the sound quality was regained. So you will have to clean your ear phones.
You will notice that after removing rubber buds..there is a metal net. you have to clean all the holes in it using a needle or any pointed object. It will improve the sound quality. It may sound weird to you...but trust me it happened to me n i was surprised .....cheers... :)
Sep 24, 2010 | Philips GOGEAR SA6045 MP3 Player
Audio jack has malfunctioned in headphones
Jun 06, 2010 | Philips SHP 2500 Consumer Headphones
One earbud stopped working
what happens is inside the cord where you have your ear phones connecting to your ipod, there is a thin wire that can easily brake. it happens if u for example, rap your ear phones around your ipod. if your rap the chords to tight, the wire can break. it can even brake when you move the cord too much. such as spinning it, shaking it and such.
the wire that breaks connects to one side or both sides of your earphones, which produces the sound. if you can hear only on one side, the cord is damaged and cant be fixed.
i would go and buy new ear phones
i perfer skullcandy in-ear earphones because the wire is secrurly wrapped, and doesnt brake easily such as other producers. the skullcandy ear phones are in my mind are much better then other earphones. you actually feel like your in the room or at a live show.
Apr 20, 2010 | Philips Ear Bud Headphones with Virtual...
Left earpiece has no sound.. can that be fixed?
Dec 21, 2009 | Bose in-ear headphones - Black with...
Doesnt sounds right...
Try a diffrent pair of earphones if that does not work the jack is shorted on the media player and needs to be serviced.
Apr 22, 2009 | Philips DVP3960
Cannot get sound to come out of earpiece after pushing button on top of i870
sir u have to see that earphone i properly plugged to the phone...nor ur ear piece dameaged....
Oct 18, 2008 | Nextel Cell Phones
Cant hear out of one side of earpiece
have you tried using differnt earphones? if the problem is still the same with different earphones then it's the ipod itself that has a problem, you'll have to get it fixed.
Feb 24, 2008 | Apple iPod nano
Philips SBCHL150 Consumer Headphones Logo
1,468 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
