Question about D-Link 4-Port Ethernet Broadband Router EBR-2310 (EBR2310)
Slow internet connection to my x-box. Problem
Slow internet connection to my x-box. Problem seems to be my router because when I bypass it everything runs fine. I'd like to be able to run multiple devices at a time and having to switch between my modem and router is annoying. Any help would be apreciated.
  • 135 Answers
Try to open the ports of the XBox to the EBR-2310 router.
Ports of the XBox: TCP 80, 3074 and 53
UDP 88, 3074 and 53
You'll needing to access the configuration page of the router (192.168.0.1) and open the ports under port forwarding.
Posted on Mar 09, 2009
Connected to the network but no internet access
tried to hooked up the LAN cable directly to the modem bypass the router if you can get an internet access there.
Nov 02, 2012 | TP-LINK TLWR340G Wireless Router
So I installed the router this morning and everything seemed to be fine except that my internet connection is now extremely slow! I called my ISP and they verified that my router was correctly connected to...
It could be interference in your area from microwave, cordless phone, or other wireless routers nearby. Try changing the router channel from 1,6, or 11. You could also try setting it up as mixed 802.11b,g,n
May 14, 2012 | D-Link Xtreme N DIR-655 Wireless Router
I am using tp link td-w8901g router.my internet speed is of 384 kbps for which i have to be able to download at maximum 48 kbps. when i use internet normally, i am having slow browsing. the download speed...
If you are paying for a downlink speed of 384 Kbps you should be getting at lease around 300. First bypass your router - connect your cable/DSL ethernet line directly from the modem to your PC. Go to http://www.auditmypc.com/internet-speed-test.asp run the speed test and see what your download speed is.
If it's less than 300 call your service provider & ask them to check out your line. If they say that you are getting 300 Kbps or more, you have a problem with the ethernet card in your PC. Replace it.
Of course, if your speed is OK when you bypass the router, you have a router problem. Contact the manufacturer or replace it.
If you have any additional questions contact me by clicking on the "Add a comment" link located under your problem description on FixYa. Also, if you believe that this information was helpful to you, please rate my solution using FixYa's "Solution Helpful" rating scale.
Best regards,
Yavacotech
Apr 30, 2011 | TP-LINK TD-W8901G Router
The internet speeds to the wireless unit keeps going really slow if you reboot everything it works for a while thens slows to a crawl again
Ask you Internet Service Provider regarding this problem. Definitely, it is not a problem from your end like your software or router. It in a slow internet connection from your ISP.
Nov 30, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Can't connect to internet on desktop computer
Most likey the issue is with the network adapter. As it does not work even with the modem and router the card seems to be faulty.
Hope this helps.
Sep 05, 2009 | Computers & Internet
Ethernet speed changes from normal to zero
If you have high speed internet go to your ISP webpage and do a speed test. If You are paying for say like 10 MEGS and are only pulling 1.2 Megs. It probably is your modem. Your speed will slow down to approx 7.5 behind a router. Also Your ethernet cable might need replacing. might also might try resetting your router. disconnect all power even the cable comming in and reset everything. Hope that helps.
May 24, 2009 | Apple eMac G4 Desktop
Where does the phone line go in the lynksys box.
Phone Line?
You need a cable or dsl modem to connect to the internet. From the modem you run an ethernet cable to the "broadband" or "Internet" port of your router.
Also make sure your lynksys is a router, not a switch
Hope this helps
Cor
Dec 31, 2008 | Linksys EtherFast 10/100 16-Port Workgroup...
Internet Connects but disconnects suddenly
Who is your ISP?
It seems you are experiencing intermittent connection. Bypass the router and check if the same problem exist when connected directly to the modem. If the internet works fine with the modem.then you have to configure the router correctly.
Aug 14, 2008 | NetGear RangeMax WPN824 Wireless Router...
Slow link to internet on new Vista Lap top
speed of getting connected is depending on how you have secured the signal.
When connected is everything OK. If Yes try onother channel
If No then I need more information about your settings.
Good Luck,
Pascal
Jan 17, 2008 | Belkin (F5D8231-4) Wireless Router...
Computers & Internet Logo
151 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
