Question about Kenmore Ovens
Digital temperature will not work we dial in temp starts out at 75 degrees few seconds later goes of  kenmore self clean wall oven  model # 970477111
SOURCE: Self-cleaning feature of GE Built-In Oven does not work
Simply set the Clock and Delay Start to the current time, then set the Stop Time ahead 3 hours. For example, if it is currently 8:00 then set the Stop Time to 11:00. The lights on the console will come on and the cleaning cycle will begin. At some point during the cycle when the oven gets hot enough, the lock mechanism is "fixed" and will not release until the cycle is complete.
Posted on Jun 28, 2008
SOURCE: Oven only reaches temp of 220 degrees.
meter the electric-220 metering the positives...110 metering 1 positive & ground at a time...Ohm the element if shows open(10 dollar multimeter doesn't move) then is bad.Can be reached from the back just above where the power attaches,for safety disconect the power
Posted on Feb 13, 2009
Sea Breeze
  • 4655 Answers
SOURCE: New replacement thermostat needs calibrating on my Kenmore oven
There is no real way to calibrate the thermostat. Most ovens have the same problem. By lowering the setting slightly will help get a closer temperature. Sometimes similar thermostats are substituted and may not be exactly the same as the original that came with your oven. Hope my trying to answer your question was helpful, Thanks, Sea breeze
Posted on Mar 27, 2009
protek480
  • 1723 Answers
SOURCE: My oven burns everything.
Use a 'oven thermometer' in the oven and determine the 'actual temperature' in the oven. Your knob setting is off (not calibrated) and the oven is hotter than the control knob setting.
Posted on Sep 17, 2009
  • 2468 Answers
SOURCE: My oven cooks too hot, about 75 degrees too
find an appliance parts outlet and give them the model number and tell them you need a new oven thermocouple,you maybe able to just replace the thermocouple,or you may need to replace both due to being connected together
Posted on Apr 14, 2010
Whirlpool Accubake Wall oven pre heat but temp goes 350 and downwards when pressing temp up
I am not sure about this, but sounds like a connector is on backwards or in the wrong place.
Nov 26, 2014 | Whirlpool Ovens
Highest temperature during self clean mode?
different brands, different models, different temps. they al range from 900 degrees up to 1300 degrees.
Apr 06, 2014 | Thermador SC302T Electric Double Oven
My Kenmore 911-4298814 oven won't hold broil or bake temp setting. The oven powers on with no error. When I press the "Bake" and dial up a temperature to (say) 350 degrees, the LCD displays...
just had similar problem with frigidaire, temp display would go blank, not even show clock, i took off back of stove, the circuit board would wiggle. when i pushed in on the circuit board it worked correctly.
Oct 30, 2011 | Ovens
Kitchen aid wall oven Model YKEBS2780B1 SHOWS
Hello,4 Digit Failure Code F0 - E0 Analog to Digital Failure Disconnect for 30 seconds - if display re-appears - replace control F1 - E1 Safety flip flop Replace Electronic Range Control/Clock(ERC) F2 - E0 Shorted keypad Replace Electronic Range Control/Clock(ERC) F3 - E0 Oven temperature sensor or oven temperature sensor fuse opened Replace oven temperature sensor or fuse F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace component 2 Digit Failure Code F0 or F1 or F5 Failed transistor Replace Electronic Range Control/Clock(ERC) F2 - E0 Oven temp too high 1. Test operation of door lock on self-clean models
2. Test relay contact operation
3. High resistance in oven temperature sensor F3
Thanks
May 26, 2010 | Ovens
I have an older model double oven by Kenmore - probably 15-18 years old. I was baking bread in foil three days ago and the oven set on bake 325 degrees. (I had been cooking a roast in it for several hours...
Hi.
the oven may have locked in consequence of the self cleaning cycle.
After unplugging, allow the oven cooling down for few hours.
If the is still locked, then the high temperature generated in self cleaning cycle may have damaged temp probe, door latch, or electronic control.
Parts must be tested to discover the fault.
Call Kenmore at the number listed on the owners manual.
Regards.
Mar 03, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Self-cleaning oven F2 error message
Well I found three all same series... If it's occasional I'd leave it 'till was always on? Anyway .....
F2 - E0 Shorted keypad Replace Electronic Range Control/Clock (ERC)
OR....
F2 Oven temperature sensor shorted Replace oven temperature sensor
OR
F2 Temperature runaway detected (Bake/Broil: 600 - 700 F; Clean: 930 - 1000 degrees F). Sounds alarm and resets to non-cook mode. Check relay board for stuck contacts. Check oven temperature sensor for normal room temperature resistance (1085-1097 ohms at 75 degrees F). Check sensor wiring connectors for a loose or high resistance connection. Check electronic range control (also called clock or ERC) functions Replace relay board if necessary. Replace oven temperature sensor if other components check normal. If failure repeats, replace electronic range control (also called clock or ERC)
Feb 16, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
I need an owner manuel for Caloric Range Model # EST 345 I can'g figure out how to run the self cleaning oven cycle.
you might try the following, although it is the instructions for an old model, it may be relevant;
"The actual self-cleaning process is initiated by a simple 5 step procedure: 1. Set the range clock to time of day. Note: on models not equipped with an automatic oven timer, the self-cleaning cycle is preprogrammed for a 21/2 hour cycle. Use Steps 3, 4 and 5 only. 2.Establish the length of cleaning time by:
A. Setting the start time. Press and turn the start dial of the automatic oven timer clockwise to the desired starting time. B. Set the stop time. Press and turn the stop dial of the automatic oven timer clockwise to the desired stop time. Max time is 3 hours miniumum 1/12 hours. 3. Set the oven selector dial on the control panel to "Clean" 4. Set the temperature control dial to "off". If you temperature control dial has a "Clean" position, then set the dial to "Clean" instead of "Off". 5. Remove oven racks, broiler pan and broiler grid from lower oven. Close and lock the oven door by moving the latch lever as far right as it will go - into the locked position. If the lever is accidently dislodged restore it to the locked position. Otherwise, the self-cleaning process will not take place. Shortly after the cleaning cycle has begun, the oven temperatur reaches a degree in excess of the normal broiling temperature. The red "Clean" light will come on and the clean cycle will start. In a few minutes the door lock lever, which you have placed in the locked position, will automatically be secured to prevent the oven door from beging opened during the cleaning cycle. This latch remains locked until the clean cycle is complete and the oven temperature reduces to normal baking and broiling temperaturs. NOTE: Prior to self cleaning cycle operation, the oven and surface lights must be turned offed. The upper oven can be used."
I found this here; http://www.appliance411.com/archive/21155_caloric_oven_lost_cleaning_manual.shtml
Nov 18, 2009 | Ovens
Kenmore 911.30464, 30465, 30469.....Wont ignite at all
there is a second ignitor for the oven unlatch bottom panel remove heat panel there is your burner and ignitor
Jan 15, 2008 | Kenmore 30464 / 30465 / 30469 Gas Single...
Kenmore electric oven
Sears Kenmore Electric Wall OVen, Mod.#9114012192 purchased in 1993. Set oven for 425 degrees, reaches set temperature, stays on about 10 minutes and temp. display goes out and oven starts cooling down. Will not stay on desired temp.to cook. Can you tell me what my problem is? Thanks. Doug.
Dec 02, 2007 | Ovens
Ovens Logo
47 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
