Question about Sony DAV-S500 System
DAV S500 will not turn on from front panel or remote. fuse good
At first it was intermittent but now the red light on the switch stays on and doesnt dim like it used to
SOURCE: Universal Remote
CHAGE YOUR MAINS LEAD
Posted on Apr 28, 2008
SOURCE: Sony AV System DAV-FC7 cannot turn on
Now the solution (rather, a workaround) for this problem is power off the main supply (or remove the plug from the electrical outlet) and then plug it again. From now, on do not power off the unit. If you have to, then you need to perform the work around again.
-Sathish
Posted on Jul 24, 2008
SOURCE: Is Sony DAV-S500 optical input compatible with optical output from Pioneer DVD player DV-566K?
I have lost my remote control of DVD S500 home theatre system,
I want to have a remote plz inform me the exact price of the new remote
Thanks
Posted on Nov 14, 2008
SOURCE: COULD YOU TELL ME IF IT IS POSSIBLE TO CONNECT MY DAV-S500 SYSTEM TO A SONY BLU-RAY A BDP-S300 SO THAT I CAN USE IT FOR THE SURROUND SPEAKERS
you need to go into the settings on the bluray player and go into the audio settings and change the sound output to dts
Posted on Jun 04, 2009
  • 12 Answers
SOURCE: Sony DAV-S500 INSTRUCTIONS AND USER MANUAL.
You can download the PDF document at http://audio.manualsonline.com/manuals/mfg/sony/sony_dav_davs500.html then view it or print it.
GregM23
Posted on Aug 31, 2009
My RCA 52" HDTV Rear Projection TV Model #MM52110JX1 will not turn on. Neither the remote, nor the front panel switch will turn on the TV. When you press the power button on the remote, the red indicator...
you must check the light indicator if how many times does it blink which tell the main problem or the error code of the tv. either the power supply doesn't work normally or the lamp need replacement.
Sep 23, 2013 | RCA D52W19 52" Rear Projection Television
LCT3701AD
may be the front switch panel is blown :(
Feb 03, 2008 | Akai LCT2060 Television
I have a sony DAV s500..now when i plug it in..the red light comes on..but when i press play or turn the machine on..it goes back to the red light right away..so the machine doesnt turn on..but becasue...
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Apr 25, 2011 | Sony DAV-S500 System
I have a Sony DAV S500 AV system and with certain DVD and with the volumn just over 20 (not really that loud), the system shuts down and PROTECT shows in the message window. I read somewhere on the web...
If the subwoofer and other speakers were included with the system, THAT is what they're designed for. Mixing and matching with other products is usually discouraged if not forbidden.
http://audio.manualsonline.com/search.html?q=Sony+DAV-S500
If the problem returns with connection of the sub it may be defective or on its way out. Internal damage to the voice coil from being overdriven could have melted or worn through the insulation and it would cause intermittent undesired electrical contact or load variation under certain conditions, like high volumes.
If your speaker level settings are unusually boosted for the sub you may be overdriving it.
Feb 07, 2011 | Sony DAV-S500 System
Hi,I can play a DVD disc on the system and get sound from the surround sound speakers but I can't get a picture on the tv,Sony Trinitron.The connetions are from the DAV S500:(DVD only)red and white cable...
First try with yellow video output of DAV-S500 in yellow video TV input to get its picture. (yellow output means composite video out)
Green-Blue-Red video output is component output that will be turn on when you switch the unit into Progressive picture mode, that option would be available in Menu of DAV-S500
Hope this info will help you.
Thanks.
Nov 29, 2009 | Sony DAV-S500 System
32 inch ilo LCD wont turn on or anything, no red light or green.
Hi there! You may have had a power surge. Most of these panels are not fitted with a manual on/off switch which can protect it from spikes. If you switch it off using the remote, it is still in danger of getting damaged via the power source. I would personally start with the fuse. If this fails and you are not in the know how of repairing electronics then refer to a repairer. Beware of High Current!!! Unplug from mains and replace fuse carefully with the same rating and refrain from touching anything else as the main capacitor may still be charged. Stand back when you switch on, especially your face as a fuse may explode and send pieces of glass flying. Bset Wishes and Good Luck, JUS004
Aug 22, 2009 | iLO 3200 32 in. LCD Television
Can i use a scart lead
You need Scart to RCA Cable to connect TV with DAV-S500 home theater system.
Thank you.
Nov 19, 2008 | Sony DAV-S500 System
Universal Remote
Mar 23, 2008 | Sony DAV-S500 System
I don't think this has an Optical but a Coaxial connection. You might try a coaxial audio cable not optical.
Dec 30, 2007 | Sony DAV-S500 System
Sony DAV-S500 System Logo
64 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
