The five hp briggs with diaphragm pump suffered from warpage of the fuel pump cover and /or carb body due to heat from the muffler. Try this first. Remove the diaphragm cover and lightly sand it with fine sandpaper (300 grit). Place the sandpaper on a flat surface (I use a thick piece of glass) and sand in a circular motion for just a couple of turns and check to see of it was in fact warped. If it is in good shape it could be the body of the carb. I am assuming that the valves are seating ok. Good Luck with your repair.
