Question about Fisher and Paykel IWL12 Top Load Washer
Starts to fill with water then beeps and says not getting water fisher and paykel intuitive eco
  • 34 Answers
Undo the water hoses at the back of the machine & check for any blockages between the hoses and the the water inlets.
Posted on Aug 22, 2009
3 Suggested Answers
  • 250 Answers
SOURCE: Fisher Paykel Intuitive Eco Washer is squealing
You need to pull out the washer, TURN OFF THE WATER, then take the water hoses off the back of the washer. Check the screens inside the water inlets for debris. If that doesn't fix the problem you may need to ask fisher paykel if it's safe to put a chemical like limeaway in those holes to remove hard water deposits that have built up inside the valves.
Posted on Sep 20, 2009
  • 30 Answers
SOURCE: Fisher Paykel Intuitive Eco Washer - IWL15: what is error code 136 on a fisher & paykel IW...
fault code 136 is a hard one possible causes are faulty rotor speed sensor on motor,siezed bearings or rotor,motor windings ,or motor control module, would suggest you get a tech for this one to diagonse correctty ,without proper tools to test eg: rss tester you could cot yourself more money... hope this was some help....:)
Posted on Jun 08, 2010
Eco intuitive error 40
Your machine cannot detect correct water level
The clear pressure tube has come off or got a hole in it somewhere.
Mar 21, 2014 | Fisher and Paykel Fisher Paykel Intuitive...
Water sensing level not working on Fisher & Paykel Eco Intuitive washing machine . The water just keeps filling up until I stop it manually . We can't use the machine to wash clothes as the Service...
Your pressure value switch is malfunction. First thing you can try that is cheap to fix is to try clean the hose that connects to the outer tub. A lot of times there is algae develops after years of washing.
May 07, 2011 | Fisher and Paykel Fisher Paykel Intuitive...
Morning, I have a Fisher and Paykal intuitive eco washing machine that continually beeps 'No cold water'. What would cause this. Thanks
Hi just read your posting.Now have you removed the cold water inlet hose from the machine end and checked to see if the water is coming from the tap and throe the hose?If you have then the fault could be faulty Water Valve,or faulty Control Module.Please reply and confirm whether you have cold water coming from your cold water tap or not and I can guide you throe the repair of this fault.
Jul 27, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
Sep 20, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
After filling, stops, lights up cold temp and beebs
are you using the pre soak cycle ? if so it wil start up after the soak time cycle is up.otherwise skip this function.
Jul 03, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher & Paykel Intuitive Eco switching itself off during cycle.
Could be a bad drain pump or controller or rotor position sensor. You will need a Tech to take a look. Unfortunately with these machines there can be many reasons for a failure. Call F/P to get a certified technician out there.
Jun 14, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher and Paykel 6.5 smart drive washer
My F & Paykel washer did this. There was a baby sock under the wash basin. I called for repairman and he found the problem.
Jan 05, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Washer
If your washer does not stop filling, you have a problem with your inlet water valve at the rear top of the machine. You simply have to replace this.
Nov 30, 2007 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher and Paykel IWL12 Top Load Washer Logo
181 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
