Question about Propellerhead Reason Adapted
Akai MPK49 USB Midi Controller Keyboard
I am trying to sync my MPK to reason adapted for digidesign and it will not autodetect. I have tried to download the driver from akai, and now that i've done that, Reason Adapted shows the option for my midi device in the preferences menu, but it still doesnt autodetect, or manually detect
4 Suggested Answers
  • 150 Answers
SOURCE: Midi Trouble with Reason
It is possible that your PC is too slow, but there may
(of course) be other causes
I have experienced a situation with Adobe Audition, causing
recording drop-outs when my PC got too busy.
To test this theory:
1) Shut down all unnecessary applications.
2) Go to the command prompt and disable the internet:
type: IPCONFIG /release.
to restart it later, reboot the machine or type:
3) Go to the task manager and stop all unnecessary
press: control-alt-del at the same time and then
choose the "processes" tab
right click on each process you don't need
and stop the process
4) You should be able to reduce the number of processes
into the low 20's, but you need to keep the following:
a) Your midi application (Reason etc) of course
b) alg.exe
svchost.exe (all of them)
system idle process
5) Now go into the control panel --> administrative tools ->
services and stop all unneeded services
(the system will not let you stop anything essential)
6) Don't worry about stopping tasks and services,
they will all restart to normal when you reboot the
7) Go back into the task manager and right-click your
midi-application. Increase its priority to HIGH,
but NOT real time, because this may cause windows
to hang.
8) If your midi acquisition improves, then speed is the problem,
otherwise, look elsewhere:
a) re-install audio and midi drivers
b) make sure the mixer and control applets are correctly
configured, i.e make sure the midi is not muted.
e) make sure the midi application is allocated the
max amount of memory, if it has a setting for it.
9) I am assuming that you are running Windows XP.
If your PC is too slow do NOT use Vista !!!!,
which makes things much worse, at least
by a factor of 4 to 1
Do not install XP service pack 3 either,
its bloated with anti-piracy **** and DRM.
10) Finally, for audio work, I would recommend
a minimum system with:
a) Pentium III 800 MHz or better yet a Pentium IV
at 1.5 GHz or faster.
b) One Gbyte of RAM to make sure your machine is not
disk bound. This is much more important than a fast
Disk is approx. 10 million times slower than RAM,
so this can become a very significant bottle neck.
c) Windows XP pro, SP2 (not 3)
d) Depending on your video card, i.e. the amount of
workload it handles for the CPU, you may also reduce
the screen resolution, and disable desktop effects
to speed thing up.
Adobe audition, for example will perform more reliably
on slower CPU's when the GUI window is kept small
in waveform or spectrum display during recording.
Good luck,
P.S. I use Adobe Audition for most of my recording and
audio processing. System = Core 2 Duo /2.4 Ghz,
4 Gigs of RAM (only 3 Gigs are accessible from 32 bit
windows XP), 1300 Mhz front side bus, 3.5 Terra Bytes
of hard disk, of which 1.5 Terabytes are configured as
Speed and storage is no longer an issue :)
not even for HD video processing.
Posted on Jun 04, 2008
  • 729 Answers
SOURCE: Reasons won't record midi data
Hi Danadepatter,
You have to check were the problems is, with exclude way.
1. you first find out if your "master keyboard" really works: Try to run another program where you can run the the keyboard(you can use a trial and the uninstall it after)
2. if that works then it is another place not the keyboard, then it can bee the program / sound card / configuration . you can find the reason manual here :
Check if the configuration to the midi keyboard is ok.
FOR THE SOUND CARD: be sure that you do not have anything else that can interrupt the sound card. Shut down other recorders and other software that use the sound card and bee sure that you use the same sound card configuration (normally it is realtec the default)
If nothing happens please go to the support here for Reason software :
Hope that helps
Have a nice weekend
Please rate my answer
Posted on Sep 25, 2009
  • 3513 Answers
SOURCE: i have a mac os
Try this. First Edit > Preferences > Page: Audio > Audio card drive : that should fix it. If there is still issues check for the audio card drivers.
Do get back to us for any further query and do not forget to accept it.
Thanks for contacting
Posted on Oct 17, 2010
Some keys on mpk49 do not play unless hit hard
sounds like dust, if you know some one with an air compresser ask them to give it a blow through, if not then it is down to caned compressed air, if that is not enough, you need to open it, and clean the contacts (DVD cleaner is cheap and good)
Aug 29, 2014 | Akai Mpk49 Mpk 49 Midi USB Keyboard With...
How to fix usb port on keyboard controller
I am assuming that you broke the connector off the pcb board? you need a soldering iron about 30W and solder and flux, to remove and short circuit after you solder them back on, using a magnifying glass to make sure none of the 5 termnials are shorted
Can I get my akai keyboard port repaired as its damaged?
I see no reason why not...but that will depend what part of the country you are in...where are you located???
Jan 20, 2014 | Akai MPK mini MIDI Controller Keyboard,...
Akai mpk broken conector
Its a lot simplifier than that really.. all you need to do is unsolder the old one and re-solder the new one.. The pins and connectors are standard.
Dec 30, 2012 | Akai MPK mini MIDI Controller Keyboard,...
Akai MPK mini MIDI Controller Keyboard, 25-Key ... my keysare broken from were it clips on
I have the same keyboard, what do you mean from where it clips on. Do you mean the keys itself are broken? I'm not sure how you did that, but you can contact Akai and see if they will send you a new one. Those keys are supposed to be pressure sensitive and unbreakable. Please rate me for assisting you today! :-) PS I love that little thing!
May 09, 2011 | Akai MPK mini MIDI Controller Keyboard,...
Is the MPKmini compatible with sony music studio8
It should work as a generic midi controller if it isn't listed
Mar 11, 2011 | Akai MPK mini MIDI Controller Keyboard,...
My knobs of my AMAY MPK mini just don't work!
This is likely a software you are using with this is either not compatible with those particular controllers OR is not set up to use those controllers. Someplace those need to be mapped into whatever you are trying to control with the knobs.
Mar 07, 2011 | Akai MPK mini MIDI Controller Keyboard,...
Hello I own an mpk 49 keyboard now I'm new at this and I can't figure out if it's internal or external sound the mpk49 gives off. Long story short how do I get the sound out of the keyboard do I have to...
You could look in the manual on Page 5 for connections to external equipment...
Connect a USB cable from your computer to the MPK49. The unit will be powered through the USB connection. Alternatively, if you do not wish to use a computer in your setup or if you wish
to power the MPK49 externally, please plug in a 6V-1A DC power adapter.
2. If you would like to use an external sound module, connect a 5-pin MIDI cable from the MIDI OUT of the MPK49 to the MIDI IN of the external device.
3. If you would like to use another MIDI controller in your setup, connect a 5-pin MIDI cable from the MIDI OUT of the controller to the MIDI IN of the MPK49.
On Page 13 the first of the FAQ's is:
Question: Does the MPK49 have internal sounds?
Answer: No. The MPK49 is a MIDI-controller, which means that it does not contain any sounds inside but is instead used
to control external sound devices, such as hardware and software synthesizers, sequencers and drum machines.
If you lack the manual you can go to and download it for free after you register.
Feb 02, 2010 | Audio Players & Recorders
When i plug my akai mpk49 into my usb port it asks
me gonna hack a audition bot did not now how to hack?
May 19, 2009 | HP Computers & Internet
Computers & Internet Logo
375 people viewed this question
Top Propellerhead Computers & Internet Experts
Chris Larocque
Nikki  Mclean
Nikki Mclean
Alun Cox
Are you a Propellerhead Computer and Internet Expert? Answer questions, earn points and help others
