Kenmore 22422 Top Load Washer Logo
Posted on Mar 09, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Clothing in between tub and will not spin at high speed on spin cycle i think i need to remove agitator to remove whatever is stuck around shaft and tub
Anonymous
Level 3:
  • Kenmore Master 3,361 Answers
  • Posted on Mar 10, 2009
Anonymous
Kenmore Master
Level 3:
Answers
3361
Questions
Helped
1029274
Points
10654
Remove the cabinet.
Remove the plastic ring snapped to the outer tub.
Use a wire coat hanger to remove the garment.
Replace the plastic ring and the cabinet.
Kenmore Series 70 Top Load Washer Direct Drive Model # 110.20722991 Serial# CL 1134809 Wet Clothes after Spin Cycle
many machine spin a full tub as they are pumping the water out
this helps to even out the washing load and reduce the unbalance situation
when the water is removed , the machine progresses the program to a high speed spin
call a technician as there may be a problem in the program board
Atlantis MAV6260AWW is not spinning at full speed, its agitating while spinning leaving cloths very wet .
check under lip of washer or around outside of tub. A garment may be in the void between tub and basket. It won't always slow down spin cycle as it may roll around when spin cycle is on but occasionally it will ball up and jam between the basket and tub thus decreasing the spin speed. Socks are a common problem and if you are sometimes whiffing a foul water smell that is the article of wet clothing that has remained wet for some time.
My Whirlpool Ultimate Care II washer goes thru all cycles but will not spin, so clothes are wet. We replaced the motor coupler but will only spin without clothes. Once you put clothes in the tub does
sounds like direct drive gears are bad.. there is a slip coupling that goes over the shaft of the transmission adn assist turning the tub that could be worn or broken. you will have to remove the agitator and check the nut on top of the tub to see if it is tight or to remove the nut and check that coupling.
2helpful
2answers
Kenmore 90 tub spins excessively clockwise during wash cycle.
there should be 2 or 3 springs that hold it, they mite have broke, take off back panel an check.
FWTR445R - won't drain, won't go into high speed spin - Fix This?
If your washer won't drain, check these:
It spins, but doesn't pump
It doesn't spin or pump
It pumps, but the water returns
It spins, but doesn't pump If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out.
To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port.
Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job.
If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump.
It doesn't spin or pump If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it.
It pumps, but the water returns If the water that pumps out of the machine goes back into the machine after the spin cycle, your washer may be siphoning the water from a laundry tub that has a slow drain, back into the washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck in the drain?) Also, check for these problems:
  • If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess.
  • If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly
1helpful
Kenmore Elite Top Load does not spin on spin cycle
Hi, If the inner tub has dropped down, you will need to change the block that holds the tub to the shaft. Remove the agitator cap and then use a 7/16" socket to remove the bolt holding the agitator in.
Lift the agitator out and look at the block holding the inner tub. There should be two slots with two tabs sticking up inside them. You will probably see metal shaving as well.
If this is what you see, please let me know and I can direct you on further repair.
Thanks
Vic
Full of water, won't drain past the agitation stage, just goes dead
It won't drain If your washer won't drain, check these:
  • If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
2answers
Washing machine shaft wont move
hi friend,
hoses
* If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess.
* If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
21helpful
3answers
"OL" error message
I believe that I had this same problem. The machine was skipping the wash cycle. After the water level rose to where you would expect the machine to go into an agitation cycle to wash clothes; it would start a spin cycle and drain the water. In the process of spinning it would stop to display the OL message over and over again as quick as you redistribute the load.
I found the problem to be clothes that got stuck underneath the impeller (round thing at the bottom center of the basket). Somehow I also had clothes get pulled down and got stuck underneath the basket next to the lint filter, these items were shredded to the point that they probably were not causing any issues, none the less they should not have been in there. Even though it was not the problem, I went ahead and took out and cleaned the lint filter since it was within reach.
This machine works a bit different then other machines. The agitation cycle is dependent upon the basket floating up and disengaging from the drive shaft. I guess the clothes that got stuck beneath the impeller did not allow the basket to float high enough to disengage from the drive shaft. Because the basket was still engaged to the drive shaft the drive motor would spin the basket and start a drain cycle rather agitate the load to wash it. The imbalance of the basket caused by the clothes stuck underneath the impeller kicked of the OL error since the basket was spinning at an unacceptable angle. I am not a repair dude but based on my observation of what I did to fix the problem this explanation works for me.
I've attached some pages of a repair manual that I found on-line to illustrate the areas that I am referring to.
Spin cycle...
Sounds like the spin tub mounting block is stripped to me. Remove agitator. Remove spanner nut holding spin tub to basket drive. The block is the aluminum piece joining the basket drive shaft. The aluminum block has two square indentions that sit down on two tabs formed on the basket drive shaft. The soft metal wears out on the block and the drive shaft isnt attached to the spin tub anymore. An easy way to test is remove agitator and put in spin. See if shaft spins but not tub spin.Let me know what you find
Alexander
vince
