Question about Avaya 5400 Series 5410 Phone
Call forwarding only rings once
I forwarded my phone to my blackberry, but it only rings once and then reverts to voicemail. Can I make it ring for longer?
You will have to have the admin lengthen the voicemail answer time, i would add another 15-20 seconds.....but this will make all calls ring your phone longer before going to vociemail
Posted on Mar 10, 2009
How do I increase ring time before phone transfers to voicemail
Which phone are you using - please be specific.
Generally Go To Settings > Call Settings > Additional Settings / Call Forwarding Settings > Voice Calls > Change the always forward Settings, here it will ask you for Number of Rings Before Forwarding. Change that as per your convenience.
Sep 19, 2014 | Samsung Cell Phones
Toshiba DKT2010-sd calls no longer go to voicemail
go to the website http://www.telecom.toshiba.com/ go to the call forward settings in the book turn off Call forward All and turn on Call Forward NA (No Answer) by default it should go to the VM system. If it does not figure out what you dial in the keypad when you want VM to answer.
Nov 22, 2013 | Toshiba DKT-2010 Corded Phone
Voicemail is not picking up for incoming calls...
Sounds like you need to set the call forward no answer to the VM pilot DN for the set with the new mailbox.
May 26, 2010 | NorStar Startalk Flash 2 Phone
What is the feature code for forward to Voicemail? I want to forward incoming calls to the mailbox without the phone ringing.
Try FEATURE 9 8 4
this forwards all calls that ring on your phone to your voicemail. To shut it off FEATURE # 9 8 4
Oct 02, 2009 | NorStar T7316E Corded Phone
Phone only rings twice then goes to voicemail. How do I change settings to allow longer before going to voicemail?
You need to contact your carrier, ask customer service if they will change the ring time. The number of rings before vaoicemail is not controlled by the phone it is set at the cell phone switching office so they have to do it. Some carriers will some won't.
Good luck,
Buddy
Corporate Computer
WWW.CCL-LA.COM
Jul 10, 2009 | RIM BlackBerry Pearl 8100
I have the same problem. Any ideas??
Hi, the setting is controlled by your mobile service provider. You will need to ring them and get them to extend the time which it will ring before going to your voicemail. Another option is to totally disable the voicemail function. On your blackberry, enter the phone screen, then press the blackberry logo button to open the menu then select options. Once in the options, select the call forwarding option. Change all settings to "do not forward". Please rate this solution if it helps. Thanks
Jun 08, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
Phone rings once, then goes to voicemail
Yes, turn off call forwarding or set up longer delay. at least 15 sec.
Apr 14, 2009 | Sanyo MM-8300
Number of rings
Sounds like you have either send all calls (SAC) enabled or your station is call forwarded to voicemail.
Disabling send all calls or call forward (as applicable) will solve the problem.
Feb 19, 2009 | Avaya Definity 6408D Corded Phone
Length of time phone rings with incoming calls
get your mailbox number then type in **61*44then mailbox mumber*11*then a two digit number between 00 and 30 (seconds delay).
Feb 19, 2008 | RIM BlackBerry 8800 Smartphone
Avaya 5400 Series 5410 Phone Logo
752 people viewed this question
Top Avaya Lands Phones Experts
Oloyede Monsuru
Shehu Pro
Shehu Pro
Are you an Avaya Lands Phone Expert? Answer questions, earn points and help others
