Question about Magic Chef CYE2000 Electric Commercial Dryer
My magic chef dryer just quit working between loads did seem to be hotter then usual door switch as continuity but nothing I replaced main timer switch 1 year ago due to not shutting off! should i buy another switch? please help Thank you in advance Bob
Replace the fuses and your problem is solved.
Posted on Mar 14, 2009
Nothing comes on. Has power, door is closed, timer seems to be working but nothing happens.
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch.
On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
Jan 09, 2011 | Estate TEDX640JQ Electric Dryer
Magic chef dryer wont start, doing nothing, bypassed all fuses that i know of and door switch, replaced timer, ck voltage both ends of cord, and both sides of timer, what am i missing?
Hi
Thanks for using FixYa. As you have already checked everything else then the issue seems to be with the Thermal fuse going bad needs to be replaced. It is mounted to the exhaust duct inside the back cover panel. Also, often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. You can check it for continuity with an ohm meter, no continuity means it is bad and you need to replace it. If you have also checked this fuse already then the issue is with the control going bad and should be replaced. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Sep 13, 2010 | Magic Chef CYE4000AWW Electric Dryer
Dryer will not turn on after button is pushed.
HI, check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in.
2. Door switch / Door switch actuator lever
The dryer will not start with a broken door switch. Replace the door switch if found defective.
Most dryers have a door switch actuator lever - when you close a dryer door, it presses against the lever, which actuates the door switch. If the lever is broken, the switch would not activate and the dryer would not start. Replace the lever, if broken.
Note: Door switch actuator lever usually comes with the door switch assembly and it is recommended to get the whole assembly since there is almost no price difference between the door switch assembly and just the lever. Check your model for more details.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
4. Timer or control board
Replace if defective (note: uncommon problem).
**The most common issue here will be a defective Thermal fuse
Jan 08, 2010 | Magic Chef CYE4000AWW Electric Dryer
I've got a Magic Chef dryer that will not start. But power is getting to it, I can hear the timer clicking...what should be the first thing I check?
The door switch must be checked for continuity. The thermal overload fuse near the heating element must be checked for continuity. If either has no continuity it is a bad part and must be replaced.
Oct 04, 2009 | Magic Chef Dryers
Won't start
replace the fuses and your problem is solved........
Mar 09, 2009 | Magic Chef CYE2000 Electric Commercial...
Dryer will not start
MAKE SURE YOU HAVE 220 VOLTS TO DRYER SOCKET
Dec 09, 2008 | Magic Chef Dryers
MAGIC CHEF ELECTRIC DRYER DOESN'T WORK. WHEN I PUSH THE ON BUTTON, NOTHING HAPPENS. POWER SWITCH IS ON.
Hello dybarra_fami, first suspect is the door switch. Check the little button on the door & the switch it presses when you close the door. Merry Chrismas.
Dec 05, 2008 | Magic Chef CYE4000AWW Electric Dryer
Dryer quit working
I have a Magic Chef Clothes dryer. Model #YE224LV. Was drying clothes, went back to ckeck and dryer wasn't running. Push botton and nothing. Check circuit breaker everything ok. What do I need to check and how. Just won't start.
Thank you!!!
Nov 11, 2007 | Magic Chef CYE4000AWW Electric Dryer
Magic Chef CYE2000 Electric Commercial Dryer Logo
124 people viewed this question
Top Magic Chef Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a Magic Chef Dryer Expert? Answer questions, earn points and help others
