Question about Bosch 24 in. SHU43 Built-in Dishwasher
Turn on, it hums but no water.. the water line is new.
Dish washer water would not feed
I turned it on,, it has a very soft humming. something is wrking.. but water valve apparently not open. is there a
the model is Shu43c07uc/14
  • Anonymous Mar 29, 2009
    I have a SHX46L Bosch  with the same probem My water line is Flood safe what shall I do? WOuld a new line solve the problem
Many new supply lines have a safety valve built in to prevent flooding in case of major malfuction. Floodsaver is one of the brands. They can be identified by a small silver cylinder at the water valve end under your sink. I have found that then valves can close under certain conditions other than a malfunction. Try turning off the supply valve and then very slowly, reopen it. Sometimes, I have had to turn off the water supply valve, disconnect the line to relieve the pressure, reattach and SLOWLY turn the water back on. If this fails, next try the diagnostic procedures here:
best of luck!
Posted on Mar 12, 2009
Samsung dish washer DD81-01549A_EN How do you reset the dish washer it won't wash it just hums
Humming could be no water going in, check fill hose.Or get a bucket of water put into drum then start machine helping to Flush out.
Oct 21, 2017 | Samsung Washing Machines
Ran dish washer without water turned on.
The first thing these units do is check the pump. Put a gallon of water in it by hand then try to turn it on. See if it makes any effort to drain.
Nov 27, 2017 | KitchenAid Dishwashers
Bosch Dish Washer shx43p15uc/61 will not wash.
you may have something under the water level float
Jan 08, 2013 | Dishwashers
No cold water coming into washer
There is a screen in the water inlet valve that gets clogged. Turn off both hot and cold water, take off the cold water line and clean screen out. If screen is clean, set to cold water wash and turn on the washer. You should hear the solenoid hum. If you hum, check the leads to the cold water solenoid. With the washer set on cold and turned on you should read 110VAC across the wires. If you have voltage the solenoid is bad. If no voltage, broken wire or timer problem.
Dec 31, 2012 | Washing Machines
Moved to new home hooked everything up washer will not fill
ther's something wrong with your water supply to the washer the humming noise is the solenoid on water valve working check water taps to make sure there is water there and hoses are not kinked
Jun 24, 2009 | Bosch Axxis WFL 2060 Front Load Washer
Loud humming noise when dishwasher is filling with water
sounds like it could be furring in your water piping. may need a plumber to check it out.
Mar 16, 2009 | Dishwashers
Loud humming noise when dishwasher is filling up with water
your model is pretty new. just so you know your warrenty is 1 year parts and labor. 2 years on parts. it should not cost that much money.
there are two components that start before the circulation pump.(wash noise you hear)
first sounds you hear will be the drain pump. usually rattling noises if something is in it but it can make a hum noise if something is jamming the drain propeller up. which is accessible with a T20 torx driver. take the filters out and the mesh filter. and unscrew the screw in the base towards the left. pull out whatever is lodged.
the other humming sound can come from the next component that activates is the watervalve. make sure you dont have a kinked water intake line. otherwise its a bad valve. i have had to change a few of those water valves out already but not for a hum noise on your model. you have a new style water valve. when brands make new parts we get problems fast sometimes..
Feb 14, 2009 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Machine starts but after one minute it just hums
Something is locking down the aggitator. The motor will burn up if you keep trying to run it while it is unable to turn so please un jam it then try it again.
Nov 27, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Washer ax6245wv0 roper washer
  Sounds like something in pump.  This is causing motor to hum and not turn.  Motor is going off on thermal overload.  This is why the humming stops.  It may be possible for you to tilt washer back and access pump.  Remove clip on bottom and top and pull pump off motor.  Try and turn pump.  Remove hoses and see if you can see obstruction.
Oct 14, 2007 | Roper RAS8445KQ Top Load Washer
Rinse cycle doesnt work
the humming noise is probably the cold valve operating but no water. check tap not turned off. slowly loosen cold water feed and check if water present
May 02, 2007 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Bosch 24 in. SHU43 Built-in Dishwasher Logo
346 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
