Question about SmartDisk FireLite USBFLB120 120 GB USB 2.0 Hard Drive
FAT32 files Computer says that FAT32 files can only use 4g of 120g. Help! Can I divide USBFLB120 to get more on drive?
    Scholar:
  • 150 Answers
One of the limitations of the FAT32 format is that it can only hold 4 Gb in any ONE file. Multiple files can hold more size, but a single file can only be up to 4 Gb in size. If this does not fit your needs, consider reformatting the drive to NTFS, which does not have this limitation.
Please rate, Thanks!
Posted on Mar 09, 2009
How do i remove parameters from a kanguru 4 g usb flash drive?
Which format fat32 or ntfs make sure its fat32 Indeed, FAT32 only supports files up to 4 GB. I ran into the same problem when copying an ~4.5 GB file to an 8 GB flash drive. There is a quicker solution that doesn't require you to reformat or lose data on the drive, using the command-line "convert" command. Suppose the flash drive is mounted to g:\. Open up a command window (start menu -> run -> cmd), and type: convert G: /FS:NTFS. Personally, I don't need the "security descriptors" on the flash drive file system, so I use the variant: convert G: /FS:NTFS /NoSecurity. The conversion should be very quick, and of course it has the benefit of not needing to move any files off the flash drive (since you don't need to reformat it). Hope this helps.
Dec 18, 2012 | Kanguru 4GB FlashBlu II USB 2.0 Flash...
Tip
How to Convert NTFS External Hard Drive to FAT32?
My friend Michael bought an external hard drive last month, yesterday he ran to me and ask how to convert external hard drive from NTFS to FAT32 safely and easily? I was so curious about why does he want to convert NTFS to FAT32; he said NTFS partition can't be read by DOS system. Since protecting data and files, I recommend him to convert external hard drive from NTFS to FAT32 with a third-party software-AOMEI Partition Assistant, which can convert hard drive from NTFS to FAT32 without data loss.
To computer users, NTFS and FAT32 are not strange. But seldom of them can tell what the difference between them. NTFS and FAT32 to partition are what DOC and TXT to text. In text, the file with DOC format can't be read by TXT application. Similarly, in some condition, not all files in different formatted partition can be read by same application. First, you'd better know some knowledge about NTFS and FAT32.
A Brief introduction of NTFS and FAT32
About FAT32
FAT 32 is one of partition format in windows system. It has 32bit file table, which strengthen FAT32's management to partition, and break through the limitation of 2GB space in every partition. Since the production cost of hard drive decreasing, the volume capacity is increasing. After applying FAT32 partition format, a big volume hard drive can be definite as a partition but not be divided into multiple partitions. It is good for management to hard drive. Now, FAT32 is replaced by NTFS.
About NTFS
NTFS is standard file system after Windows NT, 2000, XP, server 2003, server 2008, Vista, and 7. It replaces FAT to offer file system for Microsoft. NTFS make advanced on FAT and HPFS, such as to support metadata.
The difference between NTFS and FAT
As mentioned above, NTFS and FAT both are file system. However, NTFS is produced late than FAT32, but NTFS is more advanced in technology. In summary, the specific distinction are following below:
NTFS can support up to 64GB single file and 2048GB partition. FAT32 supports up to single file with 4GB and partition with 32G.
NTFS does not need Defragment your hard disk.
NTFS support to compress partition, folders and files.
NTFS takes a little cluster, which can help to manage space of hard drive effectively, and avoid wasting space of hard drive at the most extent.
In NTFS partition, you can share sources, folders and set access permissions on files. It is more secured than FAT32 partition.
How to know which partition format is suitable for you
As mentioned above, NTFS and FAT32 have its own advantages. When we choose which file system, you should consider the factors below:
Computer is installed with single system, or multiple systems.
The number and capacity of local installed hard disk.
Whether has consideration about security or not.
If computer is installed single system, and there is security to consider, you can select FAT32. Or NTFS is not bad choice absolutely.
Why need to convert NTFS External Hard Drive to FAT32?
NTFS and FAT32 are two different types of file systems, and both of them are commonly used and contain different characters. You may make conversions between the two types, and here we got several cases that you need to convert external hard drive to FAT32:
If your external hard drive is formatted in NTFS, you would not be able to access some files from DOS mode or Windows 9X, then you need to covert external hard drive to FAT or FAT32.
NTFS can't be recognized by many devices, such as Xbox 360, PS3, etc. in that case, you have to convert the external hard drive to FAT32 so that it can work with your devices.
There are more situations in which you need to convert external hard drive to FAT32, and there are different ways which you may realize the goal.
Methods to convert NTFS External hard drive to FAT32
At present, there are two main ways that you may convert external hard drive to FAT32, one is to convert to FAT32 with Windows built-in Disk Management, and another one is to convert to FAT32 with third-party software like AOMEI Partition Assistant. Let's see the details:
Method1: Convert an External Hard Drive by reformatting
1. Open the Disk Management in Windows.
2. Right click on the external hard drive and select "Format..." in the drop-down menu.
3. Select "FAT32" in the "File system" line and then choose "Quick format".
4. Finally click "Start" to format, and this process may cost you minutes.
Note: If the drive is larger than 32GB, the "FAT 32" option would be invalid and once format, the information or data in the external hard drive will disappear. So, backup the data or partition if necessary and you need to know how to convert hard drive larger than 32GB into FAT32.
Method2: Convert an External Hard Drive without formatting
You can download the third-party software to convert external hard drive from NTFS to FAT32, what is the most advantage is that convert NTFS to FAT32 without data loss. Comparing with disk management in computer, the third-party software will save your time and money. You don't need to buy other external hard drive to store data, just for converting partition format. Of the third-party software, AOMEI Partition Assistant is good choice. The specific introduction of how to convert NTFS external hard drive to FAT32.
As a kind of advanced partition software, AOMEI Partition Assistant can easily convert an external hard drive to FAT32, and you can also convert an external hard drive larger than 32GB into FAT32. This software is running well with Windows platform including Windows 2000, XP, Vista, Windows 7 and Windows 8. Both 32-bit and 64-bit Windows editions are supported. With its help, you need no to format your external hard drive and thus you can convert NFTS to FAT32 without data loss. Now, you may download AOMEI Partition Assistant Pro Edition and have a try.
source from
on Dec 29, 2017 | Computers & Internet
The drive is formated to fat32 and i want it to be formated to ntsf so i can upload files bigger then 4G, how can i do it safely?
You will lose all the data on the drive during formatting so copy it all to your computer before format. Once done, with the drive plugged in simply
  • go to "Computer" / "My Computer" right click on the external drive and select format.
  • Select ntfs for the file system
  • Give it a volume name if you like and just do "Quick Format"
Comment back if you need additional help.
Aug 30, 2011 | Transcend StoreJet 25 750GB USB Hard Drive
111 GB SMARTDISK Firelite with 107 GB of Free Space... File System: FAT32 which only allows 4GB OF Backup... HELP!!!
In a FAT32 filesystem, the maximum size of a single file is 4.2GB.
It sounds like your backup program is backing up the disk to a single file.
To fix the problem you can either
1) Get a new backup program, or change the settings of your backup program not to create files larger than 4.2GB. Unless I know what backup program you use, I cannot help on this issue.
or
2) Convert the volume to NTFS, following instructions at http://support.microsoft.com/kb/307881. Then your backup file can be as bug as the disk itself.
Apr 16, 2011 | SmartDisk FireLite USBFLB120 120 GB USB...
How do I format this hard drive to a FAT32 hard drive?
Go to My Computer, right click on the drive, go to format. select fat32 on the type list. Remember that this will delete all of the files on the Hard Drive.
Mar 03, 2011 | Beyond Micro (BM120MD3U2) 120 GB USB 2.0...
I AM UNABLE TO SAVE LARGE FILE IN MY TRANSCEND HDD. IGET THE MESSAGE THAT THE FILE IS TOO LARGE. THE FILE I AM TRYING TO SAVE IS MOVIE FILE.
Make sure that the Transcend HDD is formatted using NTFS and not FAT32. FAT32 has a 4G file size limit, and NTFS does not.
Make sure also that you backup any data on the Transcend drive before formatting.
If the Transcend drive is using FAT32, you might also be able to just go to command prompt, and type in:
CONVERT volume( the drive letter of your Transcend drive) /FS:NTFS
You can also get additional help using the CONVERT command by going to a command prompt and typing in:
CONVERT /?
Feb 25, 2011 | Transcend Computers & Internet
I have an old laptop with files that cannot connect to internet. It runs Windows 98SE so I need a special driver file for my SmartDisk Firelite USBFLB80-C unit. How can I get the file so I can burn it to...
may you can plug off your hard drive, and tthen connect to the computer that can connect to internet, and then just copy your file to your another one hard drive or you can bur it to cd
Dec 02, 2010 | SmartDisk FireLite USBFLB120 120 GB USB...
Can not copy outlook messages
It looks like your external hard disk in FAT32 system and outlook messages file .PST is more then 4GB.
To know the file system of the Hard Disk right click on the drive select properties.
Check your file system first. FAT32 will not support more than file size of 4GB.
There are 2 options to copy.
1. Split the .PST in to 2 or more outlook data file
or
2. Convert the FAT32 System to NTFS.
To convert from FAT32 to NTFS. go to following link
Mar 07, 2010 | Western Digital (WD3200JS) 320 GB Hard...
Accessing a folder.
This will sound off the wall, but we had something similar to this happen with my last laptop, where it was "access denied" in lots of areas, and we would have to find little backdoor ways to get into control panel and document files. The problem with our computer was that it had previously crashed, and we had rebooted and reinstalled the xp, but didn't have the registration number, so it would run ok, but to get into all those access denied things (which you eventually need to get into) we had to come up with our registration number.
Did it prompt you to enter the product key when you re-installed it?
Jun 27, 2008 | SmartDisk FireLite USBFLB120 120 GB USB...
SmartDisk FireLite USBFLB120 120 GB USB 2.0 Hard Drive Logo
148 people viewed this question
Top SmartDisk Computers & Internet Experts
Sunday Ojelabi
Sunday Ojelabi
 Ian Kayhan
Ian Kayhan
Are you a SmartDisk Computer and Internet Expert? Answer questions, earn points and help others
