400GB Freecom external hard drive stops functioning itself.
I have a 400GB external hard drive and its been working fine for a long long time since i've had it.
Lately i've plugged the usb part into the usb 2.0 port it works then after a short while it stops functioning itself. Sometimes it says its malfunctioned in the lower right hand corner. But when i wait then connect it back up nothing is lost that is on the external.
The only problem im having is that when i connect it up to my computer it really just stops working.
And i dont know what i can do about this. If anyone can answer id appreciate it alot.
  • Thomas F. Schneider May 11, 2010
    Their is free software available, from seagate.com for example, that wil test your hard drive for you. Sound like your hard driver has been dying for quite a while, and may need to be replaced?  You can replace the HD w/o replacing the exturnal container.
  • 51 Answers
I assume you are running windows operating system. You need to uninstall all your usb devices. Go to computer manager/device manager and select all USB devices and unistall them. Go to the start menu, click on run type compmgmt.msc. Find all your USB devices on the right side. Follow the instructions for each device to uninstall them by double clicking and then select uninstall. once you uninstall, click on the icon to scan for hardware changes located on the sub menu. Your operating system should recognize new hardware or reboot and the operating system should install them automatically again. After you reboot, logon do not connect the harddrive until you are logged in completely. The operating system should recognize a new device and install it automatically. I hope it helps.
Posted on Mar 10, 2009
How do i recover dameged 400gb freecom external hard disk. and which software should i use.
Used this software professionally for years, if it doesn't work, the alternative is very, very costly:
GRCGibson Research Corporation Home Page
Jan 12, 2015 | Freecom Computers & Internet
I am trying to transfer all my photos from my old freecom external HD to a new external HD, but the Freecom keeps switching itself off mid transfer, every few minutes. I'm worried I'm going to
sounds like a faulty drive, afraid without sending it off only way you will be able to get info off is by transfering it bit by bit,
best u use cut files at least u dont have to keep copying same files over and over that way
Jun 16, 2012 | Freecom Computers & Internet
I have an external freecom 400gb hard drive
The chances are that you would have burnt the Power IC's, so there might not be any damage to the Hard Disk itself. you culd try buying a cheap External Enclosure at the closest IT store or moun the Hard drive on to a desktop computer. you should be able to retrive the data.
Mar 25, 2010 | Computers & Internet
Freecom Hardrive "Malfunction"
Not necessarily your information (data) was lost. The freecom hard drive might have some problems installing itself or some connection issues. I would take it to a data recovery technician. Of course there is always a 50 50 chance that you lost it or not. Wish you the best, Good luck
Dec 31, 2009 | Computers & Internet
Freecom 400gb not being detected
you may need to format it via Computer Management->Disk Management if there is nothing in it.
Apr 17, 2009 | Freecom (24358) 160 GB Network Hard Drive
My 400gb freecom external hard drive wont detect on my laptop, I have tried it on another PC but nothing. The light comes on the hard drive but nothing else
if you try to go on-line and search for drivers and system software updates. if thisd doesnt solve the problem then try hardware such as cables
Feb 24, 2009 | Freecom (24358) 160 GB Network Hard Drive
Freecom 400GB Hard drive not recognized.its a Freecom mobile drive xxs 400gb , my pc just cant recgnize the hard drive
I'll assume your using Windows.
I'll assume it's a USB drive.
I'll assume it is an external drive.
And I'll assume it's formatted as NTFS.
Try using the USB (or FireWire) port for anouther drive to see if that is the problem, if it is then reinstall the driver for the port, through the Computer Managment Concole (assuming yur using windows).
If you formatted the drive as FAT, re-format it as NTFS.
Jan 02, 2009 | Computers & Internet
Freecom 400 GB external hard drive not being read by computer an re-installing Freecom Personal suite. When I turn on the external hard drove the power light comes on ( and stays on) and the drive itself...
hi there,
sounds like you have a hardware problem...you should look into trying this drive on another system to see if the same thing is happening without the drive software ...and if it works try to recover all your data from this drive as soon as possible...hardware problems are most time intermittent ... so they work now then say after a while they stop...
Apr 13, 2008 | Computers & Internet
Freecom Hard drive
Backup file in windows is being compressed the bytes from the original file. YOu don't need to worry unless everything doing good.
Please rate me solved if you like my solution.
Best regards,
Philip
Oct 31, 2007 | Computers & Internet
Freecom 400gb Drive
Have you tried to connect those drive individually and checked if they get detected when stand-alone? If they get detected stand-alone, install the Freedom software happen. Cheers
May 23, 2007 | Freecom (24358) 160 GB Network Hard Drive
Computers & Internet Logo
247 people viewed this question
David Payne
David Payne
