My Cannon i850 printer has suddenly stopped feeding the paper through the printer. I believe the tension on the feed rollers may have lost some of the pressure required to feed the paper. Are there tension springs or bands that need maintaince?
  • 628 Answers
Try cleaning the rollers with a cloth dampened with alcohol. You may have dust on them and the alcohol will remove any dirt or glaze.
Posted on Mar 10, 2009
Always paper jam error on my cannon 3530
Check for a paper fragment at either end inside the printer chamber or underneath the paper feed roller cover plates. Anything that holds a paper feed sensor arm open will give you paper feed errors, and they can be remarkably small.
May 14, 2015 | Cannon Office Equipment & Supplies
Cannon pc 921 won't feed paper from tray or bypass, shows P for out of paper but tray is full I can't find any jam
Try cleaning the feed roller using ammonia solution. The sizing used in the manufacturing of paper has waxy substances that accumulate in the pores of the rubber rollers and reduce the friction on the feed roller..
May 29, 2014 | Canon PC-921 Black and White Copier
I have a Canon Pixma iP1900, it will initially grab the paper but then the paper will just stop but the printer will continue while the paper doesn't move. Then when I cancel the printing it tells me that...
Hello -
From Support information I found on the Canon website, the paper feed rollers of your PIXMA iP1900 may need cleaning.
Source:
https://www.canon.co.uk/support/consumer_products/content/faq/?itemid=tcm:14-609974
The feed roller cleaning function allows you to ckean the paper feed roller. perform feed roller cleantng when there are paper particles sticking to the paper feed roller and paper is not fed properly.
The procedure for cleaning the feed rollers is as follows:
1.Prepare the printer
Remove all sheets of paper from the rear tray.
2.Open the printer driver setup window
3.Click Roller Cleaning on the Maintenance tab
The confirmation message appears.
4.Execute paper feed roller cleaning
Make sure that the printer is on and click OK.
Paper feed roller cleaning starts.
5.Complete paper feed roller cleaning
After the rollers have stopped, follow the instruction in the message, load three sheets of plain paper into the rear tray, and click OK.
Paper will be ejected and feed roller cleaning will be completed.
Best wishes.
Feb 07, 2018 | Canon PIXMA Office Equipment & Supplies
Cannon MP 250 crayon stuck between rollers
Description
Cleaning the Paper Feed Roller - MP250 / MP270
Solution
If the Paper Feed Roller is dirty or paper powder is attached to it, paper may not be fed properly.
In this case, clean the Paper Feed Roller. Cleaning will wear out the Paper Feed Roller, so perform this only when necessary.
You need to prepare: three sheets of A4 or Letter-sized plain paper
1. Make sure that the power is turned on, and remove any paper from the Rear Tray.
2. Open the Paper Output Tray gently, and open the Output Tray Extension.
3. Clean the Paper Feed Roller.
(1) Press the (Maintenance) button repeatedly until b appears.
(2) Press the Black or Color button.
The Paper Feed Roller will rotate as it is cleaned.
4. Clean the Paper Feed Roller with paper.
(1) Make sure that the Paper Feed Roller has stopped rotating, and load three sheets of A4 or Letter-sized plain paper in the Rear Tray.
(2) Make sure that b appears on the LED, then press the Black or Color button.
The machine starts cleaning. The cleaning will be completed after the paper is ejected.
If the problem is not resolved after cleaning the Paper Feed Roller, contact the service center.
NOTE:After the cleaning is completed, press the Stop / Reset button to return the LED to the copy standby mode.
Oct 28, 2017 | Office Equipment & Supplies
My canon i850 is blinking 3 orange lights at me and refusing to print. any ideas. tried turning on and off. removing print driver and re-installing thanks!
3 blinks is a line feed error, something stopping the platen roller from turning, look inside where the paper goes and see if something fell in like an ink pen, paper clip, just something that doesn't belong. The platen roller is the gray roller behind the carriage and sometimes you can see thru under the white plastic guides something jammed.
Nov 25, 2009 | Canon i850 InkJet Photo Printer
Cannon pixma mp 610 printer paper feed making loud noise no feed
Replace the pickup rollers and check the Gears if they become bad.
Best Regards
Mar 11, 2009 | Canon Office Equipment & Supplies
Canon i850 receives message that there is a paper
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button.
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Feb 22, 2009 | Canon i850 InkJet Photo Printer
Stuck paper in printer
the only solution for this is to dig it out
remove the paper feed cartridge, open the printer up and remove all corona wires, and anything that will slide out
look to see the feed rollers and try lifting on the rollers with your fingers to take any tension off of the top roller always try to remove the paper from the feed area slowly work the paper out if you still see small piece of paper try working them out with a stiff piece of index stock
avoid damaging the rubber rollers with a sharp object and by all means do not force the feed rollers they were designed to move in one direction..towards the copy area a pair of tweezers and hemostats work very well
the fact that the paper went in sideways lends me to believe you have a fed roller problem or an obstruction
once you clear the jam cean the feed rollers with soft cloth and alcohol
good luck
Dec 03, 2008 | Brother HL 1440 Laser Printer
Paper won't feed in my i850
CHANGE TO DIFFERENT PAPER PRODUCT
CLEAN THE ROLLERS
GO ON LINE TO
CANON 850i WILL NOT PICK UP PAPER
AND FIND OTHERS WITH THE SAME PROBLEMS
ROD
Feb 20, 2008 | Canon i850 InkJet Photo Printer
Paper Mis-Feeding
Check for any pieces of torn paper in the path, especially on the left side. You can also reach into the slot that the paper feeds into and feel each of the rollers behind the plastic cover; they all should turn freely, pay special attention to the wheel to the left.
Mar 25, 2007 | Canon i850 InkJet Photo Printer
52 people viewed this question
k24674
jasbo
jasbo
