Question about Plumbing
Pegasus Push Button Drain leaks when you push the button
This is the "Decorative Push Button Drain", #241-405 brushed nickel.
It works fine unless you depress the button to allow water to collect in the basin. When you depress the button to drain the basin, the outflowing water leaks from the seal immediately below the basin. Otherwise it works fine.
The instructions caution against overtightening the locknut (which holds the beveled rubber washer against the bottom of the basin). I believe I was careful to not do so. Again, the leak only occurs after pressing the center button to let the water drain out of the basin. There is no leakage with normal use/running water.
    Problem Solver:
  • 3 Answers
REMOVE THE LOCKNUT AND CHECK FOR A CRACK OR PIN HOLE IN DOWN DRIAN USE A FLASH LITE IN DRIAN TURN OFF ALL LITES TO CHECK PUT LITE IN DRAIN AND CK FOR LITE IN THE DRIAN PIPE
Posted on May 07, 2009
Pop Up Drain in vessel sink
Have a look on u tube see if there is a video on it .
Oct 08, 2017 | Plumbing
No hot water?
can only get warm water from shower
Nov 23, 2010 | Pegasus Technologies Pegasus F1225100BN...
When the ignition switch is pushed all the bike does is clicks. It will push start and run with no other problems.
If you push the starter button and the solenoid clicks, the button is good. Take a wire and jump the two posts on the solenoid or touch the two cables together. If your starter works, then you need a new solenoid. If you hold the starter button and tap on the starter with a plastic hammer and the starter works you need new starter brushes. Anything else wrong with the starter and you need to replace the starter assembly , unless the manufacturer sells replacement parts so you can repair the starter. most manufacturers only sell replacement starter brushes.
Nov 22, 2010 | 2001 Suzuki VS 800 Intruder
I push the electric start button not a sound what could be wrong
Check to make sure the battery is fully charged and that the fuses are all good. If you push the starter button and the solenoid clicks, the button is good. Take a wire and jump the two posts on the solenoid or touch the two cables together, if your starter works, then you need a new solenoid. If you hold the starter button and tap on the starter with a plastic hammer and the starter works you need new starter brushes. Anything else wrong with the starter and you need to replace the starter assembly , unless the manufacturer sells replacement parts so you can repair the starter. most manufacturers only sell replacement starter brushes.
Nov 08, 2010 | 1987 kawasaki GPX 750 R
How to remove a pegasus faucet handle, brushed nickel, dual handles
with most fausets there will be a cover hiding the setscrew holding it in place. it'll be right on top and need to be pry'd up. or the piece you'd use to turn the handle with, will unscrew.
Sep 15, 2009 | Pegasus Technologies Widespread Lavatory...
Single handle pegasus kitchen faucet. No water pressure when turn
Kitchen faucet? Remove the internal parts and check for blockages.
Apr 05, 2009 | Pegasus Technologies Pegasus F1225100BN...
Pegasus Push Button Vessel Sink Drain with overflow
Put plumbers putty around the flange that will be in contact with the sink. When you put it into the hole, try to line up the overflow as good as possible. The nut that goes onto the bottom (tailpiece) has a rubber gasket that will go between the nut & the sink. Adding some plumbers putty here won't hurt. After all is secure, just remove the putty that squeezed out from tightening.
Feb 21, 2009 | RTO W/ Overflow Chrome 1 5/8" Vessel Sink...
Philips 170s6fs monitor: OSD menu blocked
.well i had the same problem but my dad fixed it.
.he opened the monitor [like unscrew it.] and just clean it. brush it. and it will work fine.
if it didnt i dont know.
Dec 06, 2008 | Philips 170S6FS 17" LCD Monitor
Plumbing Logo
306 people viewed this question
Top Plumbing Experts
Paul Carew
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
