Question about Sony Ericsson Z525a Cellular Phone
Z525a screen comes on but stays vacant.
Our Sony Ericcson Z525a turns on, but the screen stays gray. We took it to an AT&T kiosk, but all they could suggest was to buy a new phone. We'd really like to recover some video of our first grandchild, but AT&T said their device couldn't help us if there was no display on the screen.
There is no problem removing the battery and SIM chip from the body of the phone. Is there any way to recover stored video/graphics?
  • dpnichol May 14, 2009
    I finally got a data cable off the net for $2.99 including S&H. Downloaded software from Sony Ericsson web site, installed software on my computer, hooked up phone to computer with new cable, and it worked like a charm.
    The problem with Bluetooth is I had never used it before with home PC, only in car, so I didn't want to attempt something with no visual feedback.
    Problem Solver:
  • 8 Answers
If you have access to a laptop computer that has an Infrared Port or Bluetooth communications, you can download your videos and picture files via either of these two methods. I use an old IBM Thinkpad 600 with IR port to download mine. You have to put your z525 phone into Infrared mode first, its kind of tricky with out seeing what you are doing. First, open your phone, press upper right (-) sign to get menu, click joystick control down 2 times then right 1 time. next press upper left (-) sign to select. next joystick right 4 times, and down 1 time. press upper left (-) sign, then joystick up 1 time. press upper left (-) 1 time. Your Infrared Port will now be turned on, and your I.R. enabled laptop can now receive the files from your phone. Close your phone, open it again, press upper right (-) , press joystick down 1 time, then left 1 time, then press the joystick center select button 2 times. Joystick right 1 time, press joystick select 1 time. press upper right (-) 1 time, joystick down 5 times, joystick right 1 time, joystick down 3 times, joystick center select 1 time. Hold the lower left corner of your phone toward the I.R. port of the laptop, it will receive the first photo file in your camera pictures file. Another possible method would be to obtain a usb connector cable for the z525 phone to connect it to your computer. Using the usb cable the computer would recognize the phone, you could click on the phone icon, under "MyComputer" and transfer the files to your hard drive. I hope this helps. -Mike
Posted on Mar 21, 2009
Gray display screen on sony ericcson z310a
maybe try and get a new battery for the phone
Apr 22, 2012 | Sony Ericsson Cell Phones
Insert Smartchip
You have to insert the smart card all the way in on these phones. You can use a pen cap or something to push it all the way in there until it goes all the way in and click and stays there. Then it will not say " insert smart chip" anymore.
Feb 20, 2008 | Sony Ericsson Z525a Cellular Phone
Sony z525a
i had the same problem for a long time. took a piece of paper and wedged it at the top of the battery to force it tighter to the battery contacts at the bottom and the problem went away for the most part. Prior to this fix, my phone would 'reboot' itself or turn itself off several times a day...
Jan 18, 2008 | Cell Phones
White screen
Unfortunately this seems to be a problem that happens to all sony ericsson z525a phones before too long. (And it seems sometimes it happens on the anniversary of the expiration of any and all warranties)
I do have some codes for running service tests on the sony z525 but with a blank screen they wont do you much good. anyway..
I'll post them here and let you know that when I tried them on my phone (when the screen worked) they did exactly what they were supposed to. You can test the screen...but only if the screen is working.
Unfortunately none of these codes will work if you have a phone with a blank screen...
THANKS SONY
Nokia anyone?
To check the IMEI# = * # 06 #
Secret Service Menu= > * < < * < * (< is left, and > is right)
To reach last dialed numbers= 0 then #
Info about Simlock= < * * < (use with caution)
again...none of these seemed to fix the problem of the blank screen...but if you should get another z525a you can use these commands to do what they're listed to do....until the screen goes blank....
Now, to retrieve your numbers you would need to follow these key strokes...
center, toggle down (1 time), center, toggle up (2 times), center, toggle down (5 times), center, toggle down (5 times), center (3 times)
then wait for quite some time...it takes a while to copy all of the contacts...I would say anywhere from 5 to 10 mins...
this should work to save your contacts.
To save your pictures (and any other data you might want to retrieve) you could buy Sony's data cable2.gif for the z525a. I haven't tried this but it should work since that is what the cable is for.
Its called a DCU-60 USB data cable, and is listed as being compatible with the z525a.
You could also try getting a T6 Torx bit screwdriver and taking it appart to replace the flex cable that runs to the screen...but I would suggest getting all the data off the phone first.
Jan 03, 2008 | Sony Ericsson Z525a Cellular Phone
Sony Ericson Z525A blank screen
the instructions for bluetooth were incorrect. Someone please list the actual steps to turn on bluetooth if you can't see screen.
Dec 20, 2007 | Sony Ericsson Z525a Cellular Phone
Turning on bluetooth on a z525a
The Sony Ericsson Z525a features bluetooth. To turn it on, enter the main menu and go to CONNECTIVITY, BLUETOOTH and there turn bluetooth on. Now that the bluetooth is on you can send music files to your phone via bluetooth.
Dec 13, 2007 | Sony Ericsson Z525a Cellular Phone
Sony ericcson mobile
okay well you need to reflash the software or replaced the flex cable on the phones.
Nov 12, 2007 | Sony Ericsson Walkman W810i Cellular Phone
Blank Screen - Sony Ericsson Z525a
The fix for the Ericsson z520/z525 White Screen of Death (WSOD) is to buy a new flex cable and replace it. You can get one off eBay for like $10 after shipping.
Taking apart your phone can be a little tricky. You'll need a T6 Torx bit and a little courage. You can use this site as a start. After that, a pair of tweezers and a few photographs to get you back where you started is all you need. I can post a couple pics I took, if there's interest.
Note this only fixes the WSOD case where the phone still can make and receive calls, you just can't see anything on either screen.
Nov 12, 2007 | Sony Ericsson Z525a Cellular Phone
Screen died
To save your pictures (and any other data you might want to retrieve) you could buy Sony's data cable for the z525a. I haven't tried this but it should work since that is what the cable is for.
Oct 16, 2007 | Sony Ericsson Z525a Cellular Phone
Sony Ericsson Z525a Cellular Phone Logo
167 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
