Question about HP Compaq nx9010
Hp compaq nx9010 battery won't charge,battery manager says battery good condition when i click next to optimize it says no communication with battery
Maybe the battery is junk. It did charge last summer haven't used it since. Also OS is Windows XP
SOURCE:
  • 55 Answers
SOURCE: Ei systems 4411 Battery driver/not charging
first of all check this battary with another same configured laptop of your's.. i guess this problem should be with your battary...
thanks
Posted on Mar 31, 2008
SOURCE: Compaq laptop problem
Hi WV,
I am still testing on the battery and so far no problems with the flash drive in. The slow booting is due I think to Avast updating the virus database at the same time. Otherwise it boots OK. I am getting an error at shutdown "SynTPLpr failed to initialize properly" I have also noticed that I don't need to click on the user login at boot time, only place the cursor over the name and it takes off by itself.
Posted on Aug 11, 2008
SOURCE: Hp compaq nc6320 doesnt charge
I have had a similar problem and solved by another solution. I think you should try it before grabbing a soldering iron.
In my case my charger was not working from one day to another. So I bought a universal charger of Kingston. Worked without any problem for a long time ~6 months. Then same problem again. Checked voltage of the charger and that was okay. Strange thing with a charger of a friend, my laptop charged again! So I thought I needed to buy another one.
Still it was strange that two chargers broke in such short time and at the same time still have voltage around 19V and charging other laptops! So I checked a forum and there I found the follwoing solution (uninstall the AC adapter and reinstall it again in the device manager):
- go to control panel
- system
- device manager
- batteries
- uninstall the programm for the AC adapter
- go back to control panel
- check for new hardware and install the AC adapter software again
Problem solved! Even my old adapter works again!
Posted on Feb 18, 2010
  • 20 Answers
SOURCE: I need drivers for PCI
Here is the site to download what you are needing for drivers for your laptop.http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=449878&prodTypeId=321957&prodSeriesId=449877&swLang=8&taskId=135&swEnvOID=1098
Posted on Sep 22, 2010
subahar
  • 110 Answers
SOURCE: how to boot hp nx9010
1. The PC has to support booting from a USB flash/pen/key drive. There may be anywhere from 1-3 items to change in the BIOS to make this possible assuming your BIOS supports it. Some bios's may refer to your flash drive as a USB floppy or USB zip. Of course there are exceptions, perhaps some are covered here.
2. The USB flash drive must support booting from it in general.
3. The flash drive must contain the boot/system files.
4. The flash drive must have bootsector area. This is done with special utilities.
5. References to "A:" drive lines in the autoexec.bat and/or config.sys files you copy to the drive after you make it bootable may result in errors.
6. You "may" have to format your floppy disk first in WinXP before you create a bootdisk as XP may "not" like working later on with a disk formatted otherwise.
7. Included below is a bootable ISO of DOS 7.1 which may be used with some of these methods if you do not have a 1.44 drive.
Posted on Nov 17, 2010
Why wont my Compaq cq58 laptop charge
hyjackers. from 2013
Gerrie Kotze wants answers to this question
buy a new battery first. ok?
then post your own new post with all symptoms,
99.90% bad batteries, some as old and 1 year old can fail.
if abused (means excessively deeply discharged over and over)
why wait, ever better why no own a spare good battery.
end the wondering...?
Jan 16, 2013 | HP Compaq Cq58-252Sa 15.6-Inch Laptop...
I misplaced my owners manual. How do I replace it ? Please.
HP Support > HP Compaq NX9010 Notebook PC > Main Support page,
http://h20000.www2.hp.com/bizsupport/TechSupport/Home.jsp?lang=en&cc=us&prodTypeId=321957&prodSeriesId=321850&lang=en&cc=us
Underneath the bold blue subheading -
Resources for HP Compaq NX9010 Notebook PC,
click on Manuals.
Under the bold black subheading - General reference,
click on - Reference Guide
It is a User Manual, and IS specifically for your laptop.
This is a PDF file, and can be saved to a CD-R disk for safekeeping.
Regards,
joecoolvette
Nov 23, 2012 | HP NX9010 Notebook
Hp Compaq nx9010 Won't connect to Internet
install the latest service pack, i'm sure that's probably the issue, the early version of win xp didn't like to cooperate with wpa or wpa2. to check which service pack you're running (i assume xp because that's what came stock on those) click start and go to my computer and right click then go to properties, it will tell you which service pack you're running. the latest is service pack 3. honestly if i were you i'd just do ALL the updates as there are many security updates and patches you should have.
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
Jul 09, 2012 | HP Compaq Business Notebook NX9010
Hp nx9010 error 280
Here is the info for the error 0280
0280 Previous boot incomplete-Default configuration used
Previous POST did not complete successfully POST loads default values and
offers to run BIOS Setup If the failure was caused by incorrect values that are
not corrected, the next boot will likely fail This error is cleared the next time
the system is booted
Here is the direct link to the Maintenance and Service Guide
http://bit.ly/gBwWBa
Good Luck
Mar 07, 2011 | HP Compaq nx9010
How can i get vga drivers for compaq nx9010
Here, check the link below and click on the download button:
http://drivers.softpedia.com/get/GRAPHICS-BOARD/OTHERS/HP-Compaq-nx9010-Video-Driver-80.shtml
This is the VGA driver for your Compaq NX9010.
Thank you and good luck!
Nov 15, 2010 | HP Compaq nx9010
My hp compaq nx9010 wont power up. dc supply is good and the batteries are ok. No led light...
This is a typical symptom of motherboard failure. Your laptop's motherboard will need to either be serviced or replaced.
Feb 16, 2010 | HP Compaq Business Notebook NX9010
HP Nx9010
Is it completely dead?
Jan 25, 2008 | HP Compaq Business Notebook NX9010
Compaq Business Notebook NX9010 runs on battery only???
If it charges the battery but won't run on AC (without a battery) then something on the motherboard is probably faulty.
Nov 28, 2007 | HP Compaq Business Notebook NX9010
Hp compaq nx9010
try and unplug the battery and see what happens when you try to switch it on the external power source.
Oct 20, 2007 | HP Compaq Presario 2500 HP Pavilion ZE...
HP Compaq nx9010 Logo
123 people viewed this question
Top HP Computers & Internet Experts
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
