Question about HP OfficeJet 6110 All-In-One InkJet Printer
It says "remove and check cartridges" no matter what I do.
I tried new cartridges, shutdown and restart, no help so far. what now?
  • PWTucker Mar 16, 2009
    I have exactly the same problem. Tried a new cartridge. Turning on and off. Everything.
Please give the solution to this problem
Posted on Mar 11, 2009
Tablet only shows half of screen when turned on
Try to fully power the unit off, full shutdown. Then restart. If the battery can be removed, do that also after shutdown.
Mar 01, 2017 | Televison & Video
Error 5100. the ink cradle moves on start up, the ink cartridges are brand new. Won't print a thing... "Check Printer, Error 5100" Canon MX300. Used once.
You need to reset your printer to remove this error. But first, may I suggest that you remove first your ink cartridge. Clean the contact surface using a cotton bud moistened with alcohol. After cleaning return back the cartridge.
Follow these steps:
1. Turn off the printer
2. Press and hold down the Stop/Reset button and Power button for 5 seconds.
3. While holding the Power button, release the Stop/Reset button.
4. While still holding the Power button, press the Stop/Reset button twice
5. Release Power button (wait till you get the lights)
6. Press the Stop/Reset button 3 times each having a 3 seconds gap. (check whether you are getting the orange light or not)
7. Press the Power button and enter data.
8. Remove the cartridge. Leave it for 20 seconds
9. Press the Power button and shutdown printer.
10. Return cartridge and start the printer.
11. Set the language and country.
After the first reset procedure and there is still an error, do this 2nd reset.
When the error is displayed on the display panel of the printer, 1. Press and Hold the STOP/RESET button and wait until it self restart.
2. Release the STOP/RESET button so printer will completely restart. After this, your printer will print again.
Please give this solution a 4 thumbs up rating.
Thank you for using Fixya
May 24, 2011 | Canon PIXMA MX300 All-in-One Printer
There is visibly no paper jammed have checked removing the cartridge.yet I get A msg that the paper is jammed
Have you check paper jam from the fuser? You have to open the fuser door which is at the back (on the rear) of the printer, after pulling out the fuser, you'll be able to do that.. Also check the paper carriage (passage after the Tray).
If there's nothing, then, remove the cartridges and shutdown the printer, leave it off for few minutes and then again restart it while pressing the power button and if the error still there, press the "Go" or "Ok" button and see if it helps or not..
Good luck.
Thanks for using FixYa.
Jun 22, 2010 | HP LaserJet 1018 Printer
Remove and check right cartridge
remove the cartridges from the printer. Then clean the cartridges contacts.
1. Shutdown your computer.
2. Verify that the unit is switched on. Unplug the all-in-one from
power and disconnect the connection port.
3. Wait 30 seconds.
4. Plug in the power only.
5. Repeat steps 2-4 two more times.
6. On the third time after plugging the unit into power, reconnect
the connection port from the all-in-one to your computer.
7. Restart your computer and check the functionality.
If the issue persists :
press and hold the "#" and 6 buttons on
the front panel keypad while plugging in the power cord.
Mar 14, 2010 | HP OfficeJet 4255 All-In-One InkJet...
My HP C6180 is caught in a start up loop...
Hi there, " Unplug the printer cable from the computer. " Unistall the printer drivers from Device manager and also unistall the all the printer appications " restart the computer " try to download drivers from the website " after installing drivers and software it will ask you to connect the printer. " then you can connect the printer and and try to Print the test page.
Print cartridge
When the print cartridge contacts are dirty and the printer cannot detect/communicate with print cartridge.
Clean the contact points on the cartridges with a dry, lint-free cloth.
1. Open the top cover of the printer.
2. Remove the print cartridges.
3. Clean the copper-colored contact points on the cartridges with a damp, lint-free cloth. Use a dry, lint-free cloth to remove moisture from the contacts.
5. Insert the cartridges back into the printer.
6. Close the top cover.
7. Try printing again.
If you still cant communicate try with new cartridge .
Aug 19, 2009 | HP Photosmart C6180 All-In-One InkJet...
Sony vaio pcg-k25 won't stay on after pressing the power button. it powers up to the window to enter my password then turns off on it on. sometimes won't even reach that far, just the led lights go on than...
Please perform the following troubleshooting:
(i) Remove and reseat the RAM modules.
(ii) Remove the Battery and reinsert it after cleaning the metal contact.
If the issue persists even when the AC Adaptor is connected then try to get into the BIOS and check if the Computer restarts or shutdown automatically. Restart the Computer and press the F2 key as the VAIO logo appears to enter into the BIOS window. if the Computer shutdown even when in the BIOS then service will be required otherwise try reinstalling the Operating System.
Jan 22, 2009 | Computers & Internet
Printer carraige of hp photosmart 475 has jammed at the far end
unplug the device and try to move the carriage with your hand ,but do not force to move it .if it does not moves just again plug in the wire and on the printer.and the carriage will move when the carriage comes out.just check out the cartridges that r they properly installed.
Nov 29, 2008 | HP Photosmart 475 InkJet Printer
Remove and check cartridge
For "Guest" who posted on October 30th; try clicking on the following link and going through the troubleshooting suggestions on the web page:
Cartridge Alignment Troubleshooting
As far as replacing a cartridge and getting a "remove and check" error message, there is more to it (at least sometimes) than having the correct cartridge. If it isn't inserted just right, the electrical contacts between the cartridge and the print carriage will not be complete, resulting in an error.
Also, if there is some ink or other matter on the contacts of either the cartridge or the print carriage, you can get the same result.
Try gently removing the cartridge and putting it back in, making sure that you've got a good contact and the latch that holds the cartridge in is correctly engaged. If that doesn't work, click on the link I posted above and follow Step three: "Perform a ink cartridge cleaning procedure". See if that helps.
Quick question for "Guest" who posted on October 31st; you are using an HP 15 cartridge? I own a 6110 all-in-one and use 56 and 57 cartridges. The product doesn't call for a HP 15. Do you have a 6110v or 6110ix?
Post back your results. Good luck.
Oct 28, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Remove and check print cartridge
Remove the cartridges and check them. If faulty, replace them.
Sep 19, 2008 | HP PSC 2210 All-In-One InkJet Printer
Status red and amber Toner light
This problem you are getting is to replace the toner cartridge. Have you recently changed the drum unit as well. If so exchange it back to the other one.
After installing new toner or full toner cartridge and removing the yellow plastic cover press the go button this should start the printer on a cycle and add the toner. If this doesn't work then the toner sensor has malfunctioned and will need replacing. This will in turn out way the cost of a new machine.
Hope this helps and not too late for you.
Thanks Jason
Aug 09, 2008 | Brother HL-5240 Laser Printer
HP OfficeJet 6110 All-In-One InkJet Printer Logo
63 people viewed this question
Ben Johnson
