Question about Canon imageRUNNER 5000 Copier
I have no manual and I need to figure out how to scan on this machine. Canon Imagerunner 50001.
  • 318 Answers
Download the network scangear from the canon web site.
Install the scangear on all the computers you want to scan to.
On the scangear tool there is a discover icon,click that icon and wait till the ir 5000 is picked up by the network.Select the machine in the scangear tool.Now you will be able to scan to mirosoft word and exel like you normally do with a scanner.
If the scangear tool was unable to discover the machine,the network settings of the IR must be checked.
Hope this help.
Posted on Mar 10, 2009
Got this imagerunner 2200 used and am trying to set it up to network scan, how or what do I need in order to do it?
for windows/Mac user:
instal driver on PC/Mac, instal Canon Network ScanGear software, setup ip to Canon iR2200. Run Canon Network ScanGear software, try to connect to copier. Use a software (adobe) to scan with the machine.
Nov 10, 2010 | Canon imageRUNNER 2200
Error 301
that code is related to the scanning lamp
Mar 22, 2010 | Canon imageRUNNER 400S Copier
We want to be able to use the scanner function on the image runner. Is there something special that we need to do?
1) download scan gear for your machine, from official canon download site
2) then you download manual scan gear and install it acc.
Feb 16, 2010 | Canon imageRUNNER 3300 All-In-One Laser...
Scanning question
The Machine must be connected to a network.Download Network Scangear software driver from the Canon webside,install it on your destop.After installation open the Scangear tool and select the discover button.The scangear will search for the machine on the network.As soon as it has discover the machine the ip address will show in the tool.Select the Machine and close the scangear tool.Select the scan button and set it to online.
Now you can scan in to a program like word or exel by Insert a picture from scanner.
Dec 14, 2009 | Canon imageRUNNER 5000 Copier
Canon ImageRunner 2016 - scanner Not working properly
Ir 2016, can be onlly pull scanner, so that means that you must have installed scan gear, selected in scan gear, and over microsoft word or similar insert scan ( INSERT PICTURE FROM SCANNER OR CAMERA ), but the machine must be in scan mode, put original on platen or dadf, and then "pull it"from PC.
Hope that helped
pls.rate
Sep 30, 2009 | Canon imageRUNNER 2016 All-In-One Laser...
Need a user manual for a Canon IR3300
http://netfree1.blogspot.com/2008/05/canon-ir2200ir2800ir3300-service-manual.html
Jun 25, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
Setting PDF as default scan setting on Canon Imagerunner 3035
Additional Functions (hardware button on the panel)
Communication Settings
TX Settings
Scroll down to 2nd page
Edit Standard Send Settings
File Format: PDF
Scanning Mode: Black 300dpi
Mar 06, 2009 | Xerox CopyCentre C123 Copier
Transferring stored information to p.c.
If you do not have send function, you need scangear software.
From canon download site you can find software and manual.
Feb 13, 2009 | Canon (6981A002AA) for imagerunner 2200,...
Canon imagerunner c3220
Were the heaters at fault. It is more like a thermister problem. Replace the thermisters, both. And I would also change the thermostat as well. When you are sure thatyou have removed the faulty unit reset by doing the following.. service mode/copier/function/clear/error followed byswitching the machine off and turn on again.
Oct 31, 2008 | Canon imageRUNNER C3220 Color Copier
Trouble with two-sided button
do you have duplex unit?
If you have do next:
when you press two sided button next appears 2-1 with arrow you must say ok, book type OK, and once again OK.
Scan first side, display sak for next, scan another side and ok
Jun 25, 2008 | Canon imageRUNNER 2016i All-In-One Laser...
Canon imageRUNNER 5000 Copier Logo
727 people viewed this question
old marine
old marine
