Question about Singer Sewing Machines
Replacing broken gears on Singer Touch & Sew Model 648
With the machine laying over and the bottom cover removed the plastic gear on the vertical shaft to the right is broken. This gear meshes with the gear on the end of the horizontal shaft that works the bobbin/hook mechanism. I need to know how to remove these gears for replacement. I think I have found the correct gears at a Singer Parts Supplier but I can't figure out how to remove the old gears. There is apparently a procedure for this as neither gear can be removed unless one or both of the shafts are moved or ''loosened'' to provide clearance. Also if I make this repair sucessfully, is the timing going to be off or will it ''self adjust'' when the new gears properly installed and meshing as they should. Any help will be greatfully appreciated.
  • lisacasey72 Apr 11, 2009
    Same problem - I'm loosening the set screws, but can't tell how to slide the shaft to remove the broken gear.
Remove the plastic faceplate from the front of the machine. There is a Singer logo button that you will have to pop out to release it, and then the lever nobs to get around to get it off. You can then access the allen screw on the top gear.
Remove all the set screws on both the top and bottom gears on the vertical shaft. Put them in a safe place.
The vertical shaft sits directly below the horizontal shaft, but there is some space between them and wiggle room to do the following. If the shaft does not slip down easily, use a small diameter rod or screwdriver to gently tap the vertical shaft downward until the top gear slips off the end. Remove the gear.
Posted on Dec 17, 2011
  • 1 more comment
  • Diagnosed
    Diagnosed May 04, 2014
    Wow Phil thank you so much for posting this!! I was midway through trying to make a video version of your instructions for everyone but my top gear's allen screws are rounded out in the hex slot :/. The closest fit I can get is with a 1.27cm allen key. You wouldn't happen to have any tips on what to do in this case would you?
  • Diagnosed
    Just to clarify, the part number on mine is 163328 which surprised me as I know the original part for the 648 was No.163987...
  • Diagnosed
    ... I meant 1.27mm allen key sorry
Here is a link to a site where you can get a manual that will walk you through the replacement procedure for $10. I just ordered it and it has good instructions and great pictures.
http://www.tandtrepair.com/600TandSstuff.html
Posted on Apr 12, 2010
  • zplum Apr 12, 2010
    I forgot to mention that it is a downloadable PDF document so you can start using it immediately.
How do I fix the gears on a Singer Touch and Sew 760
why don't you take it to an authorized Singer sewing machine repair shop? maybe it is under warranty
Jan 24, 2015 | Singer Sewing Machines
How do you remove the hand wheel on a singer model #648 sewing machine
Sounds like you might have a broken gear in the transmission. Since the Touch and Sew series (aka Touch and Swear, Sew and Throw, etc.) are so touchy about adjustments, I'd probably take this one to a good sewing machine mechanic and let him/her do the heavy lifting on this.
Parts diagrams: http://parts.singerco.com/CPpartCharts/6_6999/648E3_648E6_648E7.pdf
More: http://www.tandtrepair.com/600TandSstuff.html
(Sorry, but this is the era when Singer suddenly veered into the weeds.)
May 22, 2014 | Sewing Machines
Why will the bobbin race assembly on my singer touch and sew 640 will not move?
This specific model, and most of the Singer Touch and Sew series of machines has several plastic gears that drive either or both the hook, and the feed dogs. Due to age and general wear, these gears eventually break. It is almost 100% likely that one of your gears is broken. It is recommended that you replace all of the plastic gears in your machine at the same time. If you just replace the one broken gear, you are merely shifting the weakest point in the system to another gear, which will also break shortly. If you replace all the gears at once, they will be of equal age and strength. It is best to get this done at a reputable sewing machine repair shop, as this repair involves a complete re-timing of the machine, and can be quite difficult for the novice.
May 06, 2014 | Janome D'cor Excel Pro 5124 Mechanical...
How to replace vertical gear on Touch and Sew 648
Singer upper vertical gears are mated to their main shaft gears at factory.
Jan 14, 2014 | Sewing Machines
Singer Touch and Sew Model 648 will not zigzag
There is an arm in the head that does the zig zag movement and attaches to the needle bar with a pin. If that isn't connected zig zag won't work at all.
Jan 19, 2013 | Sewing Machines
Need to replace the top vertical gear on singer 636
it would be better to take the machine to a sewing machine shop & let
them repair it, they have the tool needed for the job
Apr 30, 2012 | Singer Sewing Machines
How to set timming on Singer Touch & Sew 638 Sewing Machine
I have a timing problem with my Touch&Sew Singer model 638.
Jean
rlacasse@ntl.sympatico.ca
Mar 02, 2008 | Sewing Machines
Sewing Machines Logo
2,914 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
