Question about Acer (ACERMOTHERBOARD)
Acer 7520 laptop screen extremely dark
I can' t lighten by laptop screen. Only able to use it through an external monitor.
Doesn't seem to be a toggle F5 issue
  • 170 Answers
It may be that your backlight has burnt out, or your LCD inverter has gone bad, if you can hear a high pitched sound coming from the screen it is more than likely the converter, you can order replacements online...
Posted on Mar 09, 2009
Monitor is dark. how to fix?
Walt, hold the Fn key down again, and tap once more on the Acer, F5, Display Toggle-Over key.
There are at least 3 display options available;
1) Internal display of laptop ONLY
2) Internal display of laptop AND external display
3) External display ONLY.
Were you just using the external display for more 'display real estate room', or was/is there a problem with the internal display of the laptop?
Was no problem? Is now? Even when using the guidance stated above for the Fn and F5 key?
Then if your laptop uses a CCFL for a Backlight, it also uses a screen Inverter. Screen Inverter is bad.
If it doesn't use CCFL/s for a backlight, and uses LED backlighting, replace the LCD screen.
The LED backlighting is incorporated in the LCD screen assembly, and you ain't replacing it.
Replace the entire LCD screen.
Post the laptop manufacturer name, and model number in a Comment. Model number is on Bottom of laptop.
Try to hurry as I'm going to a meeting with the head of General Motors, (Obama), and later with Bill Gates.
OH I'M JUST KIDDING!
Regards,
joecoolvette
Nov 14, 2012 | Computers & Internet
Have a Gateway Notebook KAV-60 with a broken screen. Trying to connect to an external monitor without any prompts or commands, as I can't see the screen. With an Acer Netbook I just plugged in the
Make sure the vga cable is in tight on the kav-60 and the external monitor.
Try the keystrokes to toggle the display. Normally you would Press and Hold the FN function key located at the lower left on the keyboard then hit the key F1 thru F12 that toggles the display. The correct F1 thru F12 key to hit will have LCD/CRT on it or it will have the icon of a display. The display toggles in three stages ( laptop only, external only or both laptop and external).
Apr 29, 2012 | Gateway Computers & Internet
As soon as it come on it shutdown and lcd is dark but you still can see in dark lcd
It doesn't sound like the system is shutting down. It sounds more like the LCD display back-light isn't working. Try connecting an external monitor to you system and booting it up. You may find that the external monitor has video. You may also toggle through the three state video selections. Hold down Fn and tap F7. this should take you through all three steps. Good luck.
If this was helpful Please rate the solution high. thanks.
Apr 20, 2011 | Acer Aspire 5100 Notebook
My laptop screen went out on me. When i power it up the status light appears to be booting up normally but the screen is still dark. I've tried to hook it up to an external monitor but still no picture....
Did you hit the keys that makes you toggle to an external display. Sometimes you just can't connect an external monitor, you have to hit keys that toggle between display on laptop only, display on both laptop and external or display on external only.
Feb 22, 2018 | Acer Aspire 9410 Notebook
Acer Aspire 7520 black screen wont boot
Turn off notebook. Remove the battery. Press Power button. Notebook should start working. Wait for 15 secs. If the screen still blank press Power button and hold it for approx. 4 seconds until notebook is powered off. Then press power button again. Bingo, problem should be solved.
Dec 19, 2009 | Acer Aspire 7520-5185 Laptop
LCD is on...seems like backlight is not functional; when external monitor connected, boot-up and bios screen visible. After boot-up, screen goes to "power save" mode and will not return
Use the 'FN' key (blue coloured?) and one of the other blue-coloured keys to "toggle" the video:
1. LCD only
2. external monitor only
3. both LCD & external
After boot-up, Windows defaults to "LCD only", and so the external monitor goes to "sleep".
Dec 11, 2009 | Acer TravelMate 4010 Notebook
Screen goes dark after a few seconds
try fn+f7 that Toggle external monitor,and disconect external monitor before starting
Jun 13, 2009 | Lenovo 3000 N100 0689 Notebook
THE LCD SCREEN ON OUR ACER ASPIRE 5520 IS CRACKED, HOW DO WE HOOK IT UP TO AN EXTERNAL MONITOR SO WE CAN STILL USE IT UNITL WE FIX THE SCREEN
Connect a monitor to connector 2 or 3
Hold down the Fn key and press F5. This toggles between laptop screen and the external monitor.
Dec 27, 2008 | Acer Aspire 5610-4648 Notebook
Acer 4420 Screen going blank
Un-take "Turn off monitor after 5 min" from Power options in Control Panel.
Nov 16, 2008 | Acer Extensa 4620 Notebook
Acer aspire 3680
Display Toggle - <Fn> + <F5> will toggle from external monitor
Screen Blank - <Fn> + <F6> will turn the LCD off
hope that helps.
Jan 27, 2008 | Acer Aspire 3680 Laptop
Computers & Internet Logo
109 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
