Question about Gateway Computers & Internet
Pc getting no power when power switch depressed
Althought the motherboard light is on
  • Kevin Shafer
    Kevin Shafer May 11, 2010
    You need to replace the power supply.
  • 28 Answers
There is one supply in not active. either +3,+5, +12,-12 or power OK. It need to troubleshoot but if you tired or busy, better to replace the new one.
Posted on Mar 12, 2009
Have dell Inspiron 546 minitower. Been acting up lately where it won't power up. The LED light on PSU below voltage switch is green. Light on MB is orange. No power or indication at all on front...
PSU's put out several different voltages if the 12Vs isn't working it won't power the motherboard. Some outputs may still be functioning therefore you may see some lights on and even some fans running. Replace the PSU.
Jun 29, 2013 | Computers & Internet
P4B-M standby LED lighted and CPU fan jerked a little and stopped when power is plugged into the power supply unit. The motherboard does not seem to power up/ CPU fan remain still even the power switch on...
This is an issue with the power supply (SMPS) in your computer... Replace the SMPS will fix the issue...
It is not adviced to service the SMPS, because servicing the SMPS will not give proper power supply to the board, which may result in damage of Motherboard...
Dec 15, 2010 | ASUS P4B-M (P4BM1400WOLTINY) Motherboard
I have an HP DV9000 that I'm having an issue with on power up. When I plug the AC adapter into the laptop I have the blue light on insert so I know the laptop is getting power. When I depress the power on...
Unplug your battery and leave it off for about 10 minutes. depress the power button(with the battery off) to get rid of excess power. reconnect the battery and try again. If no luck, try with power cable only(no battery) if no luck, sounds like a motherboard issue.
Oct 29, 2009 | HP Pavilion dv9000z Notebook
Dell Dimension 4550 will not power on but standby light on.
In all my years of fixing computers, 98% of the time it is the power supply, 2% the motherboard and 0% the switch. Just because the standby light is on does not indicate that the power supply is functioning correctly. The power supply puts out many different voltages....5v, 12v, 1.3v, and 3.3v. If the 3.3 is working then the standby light will come on but if any of the others are not working correctly then the computer won't turn on at all. You can check the switch by checking the resistance of the two wires that the switch are attached to using a multimeter. When the button is depressed, it should go to 0 and when it is not depressed it should be at 1. I would suggest swapping out with a known working power supply to verify the issue.
Jun 25, 2009 | Dell Dimension 4550 PC Desktop
Computer will not turn on
May sound strange, but is the power supply switch in the correct position?
If the button is pressed, makes your continuity test, and not even the fans come on, check that the switch jumper has not come loose from the motherboard, and finally, if the motherboard is plugged in and no fan comes on when you push the power button, there may be chipset damage from an electrical surge or overheating.
In this case, a new mobo is your only option.
Jan 20, 2009 | Dell Dimension 4600 PC Desktop
ZE2000 No power issue
Check on the motherboard if there is a fuse. It may look like a diode or resistor.
Does it work on battery, if you have a charged one?
Jul 14, 2008 | HP Pavilion ze2000 Notebook
Emachine desktop power switch is shot
I would still try to replace the power supply first,before replacing the motherboard.In 80% cases that you are describing it is the power supply.
Hope this helps
Mar 24, 2008 | E-Machines eMachines Desktop PC
No Power up on depressing On/Off button.
Sometimes if the CPU is overheatign it will power down to stop the cpu from buring out. A power suppluy just supplies power to the motherboard and that's it. If the CPU gets hot it shuts down and wont start till it cools down again.
Nov 04, 2006 | E-Machines EMA IMPERIAL GV (845GV) TG3...
Computers & Internet Logo
117 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
